Question about Cycling
How much air should a bicycle tier has ? Which air pressure ?
    Problem Solver:
  • 11 Answers
Your tire's specification but doesn't exceed it by more than 5 PSI.
Posted on Mar 22, 2011
After i put air in tiers how to i make low tire pressure light go off in 2007 eddie bauer expedition el
Go to the "Discount Tire shop", and they will do it for you for free. Then learn how to spell. ??? air in tiers ???
Feb 24, 2015 | 2007 Ford Expedition Eddie Bauer EL
How do i reset tier pressure
You dont have to reset it just put the proper amount of air in tires it should reset its self. If that does not work look at the owner Manuel it will tell you how to reset it. Good Luck
Oct 11, 2014 | Dodge Ram 1500 Cars & Trucks
Do not know, meaning... Can someone please explain...
This is your automatic tire preasure system.Check your tiere pressures.
Oct 04, 2013 | Cars & Trucks
Tyre pressure for yzfr125
tier pressure should be front 25 psi rear 29 psi weight load 0-90kg
front 25 psi rear 33psi weight load 90-185kg both on cold tiers,
Mar 31, 2013 | 2008 Yamaha YZF-R125
What is the air pressure or psi for a schwinn bicycle called discovery 700c
All tires have the maximum inflation pressure molded into the sidewall.Try inflating to about 5psi below the max as a start.(My 26" tires are "MAX INFLATION PRESSURE 65PSI",I like it at about 50psi.
Sep 17, 2012 | Pacific International Mens Schwinn 700C...
2008 rear shock won't dial in to a firm ride as it use to. It only goes up and down freely with weight and not just at impact. what needs to be done?
I would highly suggest you take the bike and shock into your local bike shop to have the diagnosis the problem. Other than suggesting checking the air pressure if your shock has an air valve, there are far too many potential problems to go through in this format.
From your description it sounds like a shock with no air pressure, but...
Dec 27, 2010 | Specialized Bicycle Components Specialized...
Air does not come out of bigger hole, what's wrong?
THE TRICK TO SWITCHING OVER THE OUTLET FOR THE PUMPED AIR IS BACK PRESSURE. IF WHAT YOU ARE FILLING IS COMPLETELY FLAT, BLOW INTO THE FITTING YOU WANT TO USE AND IT WILL SWITCH OVER.
Aug 01, 2010 | Schwinn Bicycle Aluminum Frame Pump
How do i change the rear tier of my razor mx350?
I would take it to a shop only because the tire has to be on almost perfect so there is no wobble.They have the proper equipment to make sure it is aligned properly.If you are going to go around 40-50 mph alignment is critical.Even jumping moguls and turning alignment is critical.
Jul 22, 2010 | Razor MX350 DIRT ROCKET - BLUE
Air Shocks
There is a shock pump tool you can buy either at a bicycle shop or online that will let you add air to your shock or fork. Make sure you research your model's specified volume/pressure before you go for it so you do not damage anything.
Nov 18, 2009 | Marzocchi Cycling
I need removing tier pressure indicator for toyota tandra
go to your tire stem.......
Take the plastic or metal cap off of the stem (where you add more air) then take a pen, pencil or your car key and hold the centre stem down and you will hear the air coming out.
Don't stand in front of it or you will smell like stale rubber air!!! lol
Take a reading of your air pressure and when it's where it should be replace the stem cap.
Good luck!!!
Jan 13, 2009 | 2007 Toyota FJ Cruiser
Cycling Logo
24 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
