Still having problems with Samsung DVD-VR375. I bought a RF Modulator due to my problems with...
(More)
Still having problems with Samsung DVD-VR375. I bought a RF Modulator due to my problems with comcast box, but the thing STILL won't work!!! The dashes where the clock is are flashing, so I know it is getting power, but I can't get it to work. The user manual did not match up to the machine so I finally found that it is a dvd vr 375A/XAA. Did Samsung make it hard on purpose?
Cannot open disc compartment. No response on any of the 5 buttons. Samsung DVD-C621 Multi-disc...
(More)
Cannot open disc compartment. No response on any of the 5 buttons. Samsung DVD-C621 Multi-disc player
Hi I have a Sanyo DVR-DX600 DVD recorder and a 50" Samsung Plasma. My DVD player has been...
(More)
Hi I have a Sanyo DVR-DX600 DVD recorder and a 50" Samsung Plasma. My DVD player has been working fine on the TV for the past 6mths up to now. What happens is when I turn on my TV and DVD, I switch from HDMI to AV on the TV, no signal is being received from the DVD on the TV. I swapped the composite cables with a different set, and still no signal, so I don't know what else to do. But when the DVD is turned on, everything seems to be working, it can read a DVD inside and it can change channels and I can see all this on the LCD display on the DVD that this seems to working fine. Only problem is howcome all of a sudden my TV can't get the DVD signal? It has been working fine the past 6mths up to now. The DVD I have owned for 1YR6MTHS and the TV 6mths.Let me know what can be solved.
I hooked up the dvd player directly to the tv using rca cables from the red/white/yellow dvd out to...
(More)
I hooked up the dvd player directly to the tv using rca cables from the red/white/yellow dvd out to the tv red/white/yellow tv in. The power on the dvd comes on and its little display screen shows it is working and playing a disk, but the picture on the tv does not change from the cable input. Pressing setup on the dvd displays setup in the dvd window but not on the tv. The tv is tuned to channel 3. The vcr starts playing a tape properly when play is pressed, but the dvd does not. There is no separate input button for the tv, so I assume when you change from cable to vcr or dvd the picture will change accordingly automatically.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
