Ph dv5 no screen only beep sound - Computers & Internet
  • 31 Answers
Beeps are telling you that you have a problem with a hardware component (i.e. keyboard, RAM, motherboard). The most common problem is with the RAM. Try taking it out and putting it back in. If that doesn't work try different sticks of RAM.
Posted on Mar 26, 2011
My pavilion dv5 laptop does not boot up at all! it only shows curtsey light when the battery s pluged in. The screen does not come on at all.
Sounds like a dead motherboard to me (turns on, but no one's home). Just in case, remove the battery, disconnect from power, then reattach both, and turn it on and see if it makes a difference.
Aug 22, 2011 | HP Pavilion dv5-1125nr Notebook
I have a HP PAvilion dv5-1125nr and I recently encountered a problem where on startup it shows a white screen. I tried looking at it from all angles to see if there was a faint image but there was nothing....
no photos of white screen presented or posted.
is it white in a dark room???????????
DV5-1125nr (9 years old (first made date) RTC COIN cell time? sure. page 59 tells you how.
http://h10032.www1.hp.com/ctg/Manual/c01550108
lacking any photos , it be impossible to fix this talking in text box.
no?
as they say ,seeing is believing, what you call white I call black.
white on sunny beach, or black in dark room, can be the same.
PAvilion dv5-1125nr
always post what a pC does in the dark, its best.
all text seen , all logos seen (hp or compaq)
any boot screens, any log in screens.
and if the "hit F10 key to enter HP setup" is missing on said screen as seen now for 9 years running.
if that text is missing,
remove the big battery in rear of LP,they short, so get it out now
and first., do that first. always,,,
then run on AC power,
do the HP long reset? (battery out, ac pack pulled
push power button 10 to 30second, not use the ac pack only
it can run on AC forever, end ever , no problems.
do so now.
got that that 9 year old text now? in the dark, ok?
The F10 is BIOS hot key, power on and quickly hammer F10
bingo for BIOS. see that? see those screens, those are first.
if BIOS is dead, it can not boot any OS made.
BIOS does the booting job, see?
here is your support page. at HP, Fixya is NOT HP. so....
https://support.hp.com/us-en/product/hp-pavilion-dv5-1100-entertainment-notebook-pc-series/3744201/model/3795325/manuals?jumpid=reg_r1002_usen_s-001_title_r0001
this OLD PC, is CCFL back lighted, all are.
2010 year is the magic hear we went to LED backlamps.
but your PC is 2008, see?
CCFL do these things
dim, go yellow, do dead, go intermittent and blink(strobes)
if dim, AS I SUSPECT , then its that. (brightness set to max)
CCFL tubes are 99% caused
the HV inverter is 1%
here is the tube sets.
https://www.ebay.com/itm/CCFL-Backlight-for-15-4-LCD-HP-Pavilion-dv4400-dv5000-dv5100-dv5-1000-1100-1200/401259562873?hash=item5d6cef0779:m:mcD2SCb17BxyIvQPKdpd78A
here is the inverter (high voltage inverter for HV CCFL tubes)
https://www.ebay.com/itm/HP-Pavilion-dv5-1125em-dv5-1125eo-dv5-1125es-dv5-1125nr-laptop-LCD-inverter/121175375836?epid=1758409030&hash=item1c369d7fdc:g:CXEAAOSwRbtaAU5l
if you tell what it does in the dark , all things
good or bad,.
answer get 10x smaller, or in fact , dead accurate.
why not just get it fixed by a tech.
all old laptops do this, EVERY SINGLE ONE.
Dec 14, 2017 | HP Pavilion dv5-1125nr Notebook
Hi there I have a HP pavilion DV5-1250us. When I turned it on sometimes it didn't start up at first and the capslock and numlock leds were blinking in loop. I needed to restart it to start up. But...
Hello, Try to unplug AC charger, remove the battery and keep press the power button for 1 minute. after one minute, connect the battery and AC charger and start up the system
Aug 03, 2017 | HP Pavilion dv5-1250us Notebook
My hp dv5 bronze model is having a screen problem. it makes a hiss sound and flickers slightly. more concerned about the sound .
screen cable is lose... open the on/off swicth button cover remove the cable of screen and fix again properly.. hope it will be okie...Thanks
Sep 05, 2010 | HP Pavilion dv5-1000us Notebook PC
I bought an HP Pav dv5 for a womens shelter where i volunteer,when you try to turn it on all it will do is beep 3 times,it is 1 year old,hp told me the problem is the motherboard,can fix it?
That sounds right, if the screen doesnt come on and it beeps. it probably is an issue with the motherboard..
If its only a year old, you may still be under the extended warranty.
You should go to the link below, and enter your information to see if its still under warranty.
http://www13.itrc.hp.com/service/ewarranty/warrantyInput.do?admit=109447627+1271991602012+28353475
Apr 23, 2010 | Computers & Internet
HP Pavillion dv5 startup problems, no screen 3 beeps in loop
Hi, you need do follow things:
1) check RAM in the back small cover of laptop, clean RAM pins and slots set back or change RAM position each other ,or replace other RAM(same model) if old RAM not works.
2) take out the wireless card in the back small cover that is MINI PCI slot, then turn on. sometimes it cancause this trouble.
help you fix it, and any question keep in touch please.
May 14, 2009 | HP Pavilion dv5-1000us Notebook PC
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
