Question about Sport & Outdoor - Others
Hello, I have a FRIGIDAIRE lawnmover model BM155M107 (93) and it's impossible to find any technical data about it here in france. If you have an illustrated parts list for this model i would be gratefull if you could send me a pdf copy, so that I can identify and order the necessary sku's to repair it Thanks for your help regards
MicrowaveSvc
  • 9098 Answers
SOURCE: Frigidaire Microwave plmv169dcd Start Capacitor
The starting capacitor is used to start the hood vent fan motor. It's also called the hood capacitor.
On page 8 of the document you refer to above, on figure O-1, you will find the hood capacitor. It is shown on the control unit (circuit board). I've attached a snapshot of that area below.
Its leads connect to terminals A1 and A3. The hood fan red wire goes to A1, and the yellow wire goes to A3.
That part is not shown in this document as a separate part, so you will have to get it generically from an appliance parts store or electronics supplier, but you will have to order it by value.
You need to look on it and it will say something similar to this:
"7 uF 230V". In this example, that would be a 7 microfarad, 230 volt capacitor.
It's okay to get a capacitor with a little higher voltage rating, but not lower.
The capacitor, if truly bad, may not look bad. It can be quick-checked with an ohmmeter to see if it will charge and discharge (the meter will first indicate low resistance then go high to infinity). This is not a full-blown test, but for this kind of capacitor it may be enough.
You should check the solder connections, also. It's a large part, and sometimes they don't get enough solder on them. The connection may be cracked and just need to be resoldered.
Since a new thread was started, it makes it harder to follow along the saga...
But this problem could be a bad (or jammed or obstructed) hood fan motor, a flaky relay on the control board, a bad cap, or bad wiring.
Microwave hood fan motor starting capacitors usually look something like this, and may be red, blue, green, orange, etc.
Posted on Dec 05, 2007
  • 5 Answers
SOURCE: simmons crib parts list
You might want to check out this really great website I found. They seem to have all types of parts for any kind of crib. This may be what you are looking for. Good Luck!
http://www.productsamerica.com/index.html
Posted on Jun 22, 2008
SOURCE: illustrated parts list for john deere 102 riding lawnmower
Go online to www.johndeere.com click on residenial tractors,then click on services and support. You should be able to get an answer there. Otherwise contact them through email.
Posted on Apr 08, 2009
SOURCE: Frigidaire gltf2940e front loading washer - dispenser drawer magnet replacement
When you are looking at the drawer, the magnet stands upright on the far right side just inside the outer front casing about halfway down. There is a small plastic clip that holds it in place. You don't need to take anything apart to reinsert the magnet, just open the drawer, but it may be easier to see the location if you pull the drawer all the way out of the hole.
Posted on May 16, 2009
  • 1218 Answers
SOURCE: I need a parts diagram and part no.'s list for a
To order parts give Royal a call at 1-800-524-0799.
Posted on Aug 22, 2010
Can't connect wifi
Some things to check
  1. Make sure WiFi is powered on
    1. Go to Windows CE desktop
    2. Click on wi-fi power icon
    3. Click 'Turn on'
  2. On Windows CE Task bar
    1. Double-click on WiFi (First from left)
    2. Click on 'Wireless Information' tab.
    3. Select your network from network list
    4. Double-click on i
    5. Enter your network credentials
    6. Press OK
    7. Right-click on your network name
    8. Press connect.
Dec 18, 2014 | Motorola Mc2180 Data Collection Terminal...
I need a manual for the Frigidaire FAFS4272LW Front Loading Steam Washer
Hello Ann Todd - I located the manual on the Frigidaire website. Here is the manufacturer link and according to your model it seems like the direction of the door swing cannot be change. If you have difficulties pulling up the requested information, I recommend taking off the last letter of the model number so you can pull up the data.
Feb 16, 2013 | Frigidaire ATF6000ES Front Load Washer
How do you clean automatic soap dispenser?
Hello Sherri Ortwerth - I located the manual on the Frigidaire website. Here is the manufacturer link and it provides step by steps instructions in how to clean the soap dispenser drawer. If you have difficulties pulling up the requested information, I recommend taking off the last letter of the model number so you can pull up the data.
Feb 15, 2013 | Frigidaire ATF6000ES Front Load Washer
Replace part on hard disk controller board
i have the same issue with my hdd. same drive only the 160gb one. you may be able to buy a replacement PCB board. check out:
hddzone.com
Jan 05, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
120v ac o.k., but panel does not light up frigidaire atf7000eg0 washer
Sorry but with such a fault it is impossible for anybody on this FixYa forum to guess remotely what is wrong with your washer.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 19, 2011 | Frigidaire Washing Machines
Need a belt diagram for figidaire dryer model number fex831cso
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer technical manual' and you may be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct. You may find, however, that it will supply only to service engineers but good luck anyway.
John C.
Apr 06, 2011 | Frigidaire Washing Machines
Motor wireing diagram for frigidaire GLET1031FS top load stacked washer/dryer
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and helping for free on the web ;-0)
I understand that manufacturers often supply technical diagrams to service engineers only.
I can only suggest you go directly to the manufacturer's web site and try
Good luck,
John C
Feb 27, 2011 | Frigidaire GLET1031FS Top Load Stacked...
Frigidaire refrigerator FRS26H6CBO
I will be more than happy to help you out with this.  Get your model and serial number and chat with me one on one.  I am an authorized factory servicer for Frigidaire.   Frigidaire Technical Support
Thanks, Bill
Jul 22, 2008 | Frigidaire FRS26H5AS Side by Side...
Front loading washer
I don't see either of those error codes in the frigidaire technical data for this model. You can look here:
http://www.frigidaire.com/support/ResultsPage.asp?strModel=atf6000es&User=&Search=Search
I've heard EFO has to do with oversudsing so if you're using HE soap use less, if you're not you should switch.
Nov 03, 2007 | Frigidaire ATF6000ES Front Load Washer
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
