Question about Asrock P4I45GV R5 Motherboard
My CPU keeps showing BIOS checksum error when booting up even i changed the battery with a new one
  • Handi Tang Mar 22, 2011
    i have changed the BIOS battery with a new one, and its still RESET the BIOS when i boot up
  • 32,281 Answers
Remove the BIOS battery fr approx. 15mins (this will reset the BIOS back to the default settings) then insert the BIOS battery and configure the BIOS Date and Time etc.
Posted on Mar 22, 2011
Testimonial: "i have tried that, but when i powered down, it happen again. seem the motherboard was error on charging the bios battery"
P4M900T-M2 Intel Pentium R dual CPU E2160 1.8 Ghz default BIOS Setting
The CMOS Checksum Bad Error during the pre-booting process only indicates that the CMOS battery is exhausted and it can not no longer save the current BIOS settings, Time settings and many more things.
The first and and the only way, according to me, to solve this problem is to replace the CMOS battery.
Please let us know, if this solution have helped you.
Hope this helps, Mrityunjay.
Jun 18, 2012 | EliteGroup ECS P4M900T-M2 Socket 775...
Hello, when I put my pc running it says CMOS checksum error press F1 to enter or Del to enter setup, but I press Del when I save changes "save and exit" the computer restarts, but this time...
The Checksum error basically shows that boot settings which were previously set has been changed or reset. This usually happens when the battery loses its charge and thus fail to retain the CMOS settings. This can also be caused by a power surge or a damaged motherboard. But most of the times it would be the battery problem.
You can try replacing the CMOS battery and enter the values back into CMOS or reset values to default. Then switch off and boot up again.
Hope this works. Good Luck. ~SmokinJoe~
Apr 28, 2011 | EliteGroup KM400-M2 Motherboard
Can you please help me how to fix the BIOS ROM CHECKSUM ERROR. TO MY MOTHERBOARD (TRINITY 400 S1854 AGPX4-PCI-ISA) i reformat the windows NT version 4, and after i restart, the message come bios rom...
turn the computer off
now turn on and hold down the delete key until the bios screen appears
in the boot tab select first boot as the cd disk, install the cd for win nt in that drive
close down the cd and then restart and it will boot from the cd
BY reformatting the hard drive win nt you have wiped the win nt operating system from the hard drive
Feb 17, 2018 | Tyan Trinity 400 S1854 Motherboard
Always start up with cmos checksum error, cpu ratio has been change
A BIOS checksum error is most likely caused by a flat BIOS battery.
Replace the battery with a new one (it is usually a coin size battery - type CR2032) and then boot up and go to the BIOS configuration and set the Date & Time setting etc.
Jun 30, 2010 | MSI K8MM-V Motherboard
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Hard Drive will not boot in Compaq Presario C700
BIOS checksum errors occurs when either the BIOS chjp is faulty or most likely the BIOS battery is nearly flat and the stored info changes and doesn't match the checksum info.
Replace the battery with a new one, leave the battery out for 1/2 hour before inserting the new battery. The BIOS will be reset to the default settings, you need to configure it again eg, datr and time etc.
Feb 22, 2009 | Compaq Presario C700T Notebook
Error message
Open Your system and there is a Battery which looks like a Coin. that is CMOS Battery (CR2032) Change that battery and then Reboot your system and try go to BIOS menu with DEL , F11 , F1 or F2. Either of these Buttons can Work.
This will resolve your issue
Nov 26, 2008 | Computers & Internet
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Asrock P4I45GV R5 Motherboard Logo
147 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
