Question about Asrock ConRoe1333-D667 Motherboard
I am having a desktop of basic setup (and a bit older too) having a Intel E2140 Dualcore CPU running on [URL="http://www.asrock.com/mb/overview.asp?Model=ConRoe1333-D667%20R1.0"]Asrock ConRoe 1333-D667 motherboard[/URL]. It's a 20 pin ATX motherboard actually. Today I purchased a Corsair VX450 PSU for my desktop. But it refused to run after installation on my board. It shown no sign of working not even a slight spin of fan, no sound nothing. It behaved as if there is no power supply to it. But my system worked fine when I reverted to my old PSU again. (a stock psu of some generic brand that came with the cabinet). The first thing that came to my mind was that may be mine is a DOA. Then on second thought I thought may be the PSU is not compatible with my mother board. (Link to the product page is given above). But how to confirm it? I googled for it and read here that all Corsair PSU's are backwards compatible to ATX 12v 2.01. Does my motherboard not fall to this category? Sorry I am not very much tech savvy so I need your help on this. Will somebody out here willing to help me setting this up?
antiochpc
  • 1314 Answers
SOURCE: asrock dual core 775 vsta motherboard
Since the only thing connected is the power suppy and the CPU, this is often caused by a power supply unable to provide the power to the MB. You will need to swap out the power supply and that should take care of the problem.
Posted on Jun 22, 2007
SOURCE: P4i65G - brand new want start.
What kind of P4 3.4Ghz is it? if it has 2mb of L3 cache, it doesn't work with that motherboard
Posted on Oct 25, 2007
marked
  • 6487 Answers
SOURCE: Asrock K7VM2 Motherboard Memory Upgrade
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
Posted on Jun 06, 2008
SOURCE: No beeps on boot up with asrock mobo? help plz
well i have done all barbones tests and the mobo is now on its way back as its a dud :( even with just cpu in and mem it doest beep to say theres no graphics.
Posted on Jun 11, 2008
marked
  • 6487 Answers
SOURCE: VGA Driver
You can go to this link for the driver download for your Onboard VGA http://www.asrock.com/mb/download.asp?Model=ConRoe1333-D667%20R1.0
Hope that helps..............
Posted on Aug 27, 2008
Intel lga775 motherboard drivers dul cpu e2140
E2180 and E2140 should be installed in a "Socket 775" motherboard. Go to the website of the manufacturer/brand name of the motherboard and click on Support. Locate your exact model of motherboard and click on Download drivers. Then select which operating system you are using (example: Windows XP or Windows 7 64-bit, etc.) There will be a list of necessary drivers for you to download and install. The motherboard manufacturer always has the drivers for their brand name.
Jun 22, 2014 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Can I Play games that require 2.2Ghz in 1.6Ghz
If its a free download or you already have the sim, then try it, otherwise if you must fork out your hard-earned cash, probably not advisable.
The 'need for speed', or higher CPU clock-speed, is to allow the sound, video frames, rendering and algorithm calculations to all run smoothly in sync.
Check if they specify 'Absolute Minimum Requirement'.
On my old PC, an iNtel P4 1.6GHz single processor running Win XP, 2GB RAM, I barely managed to run intensive resource-hungry games, but often ended up with a frustrating 'slide-show' or total freeze.
After upgrade to 64-bit 3.58GHz core-2-duo, 8GB RAM, i'm thrilled at SMOOTH performance.
Dec 19, 2017 | Intel Computers & Internet
Can i use intel motherboard z68 series with my intel processor E2140 dual core .
No you can't fix E2140 CPU in Intel Z68 motherboard. E2140 compatible with LGA775 and Intel Z68 for LGA1155.
Feb 17, 2012 | Intel Computers & Internet
2.6 dualcore not working for intel d101ggc.. why?
This motherboard appears to be very selective of the CPU it will use. in the 2.6 category the only process it shows to support is an intel 805 2.66. Check this site it should be able to clarify the issue somewhat:
www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-025906.htm
Dec 01, 2010 | Intel D101GGC Motherboard
Intel pentuim dual cpu e2140 no drivers how i can download
CPU's don't need drivers, if you're looking for chipset drivers then you need to find the model number and name of your motherboard.
Nov 15, 2010 | Intel Pentium Dual Core E2140 / 1.6 GHz...
I have an Intel D845HV motherboard running with a
In short, yes you can upgrade to a P4 cpu but from the compatibility chart at Intel support, it looks like the upper limit for this older board is the P4 2.6GHz.
Note: Even at that, running the P4 2.6 would require a BIOS upgrade to P12 or greater.
Luckily, the following link has the information you seek: (for BIOS info, click the "BIOS Version" link in the upper right corner of the compatibility table provided)
Intel D845HV CPU Compatibility
I hope this info is helpful!
Mar 08, 2010 | Intel D845HV (735858149143) Motherboard
I have not vga(video) drivers.....pls help me
we can use three type of mother board on dual cpu. that are 865 chipset , 915 chipset , 945gz chipset, u can download thease driver from intel . enjoy good luck. plzzzzzzzzzz vote me for increase my rating
Jul 28, 2009 | Intel Pentium Dual Core E2140 / 1.6 GHz...
We would like to download intel e2140 pentium dual cpu drivers
First you should install Intel's Processor Identification Utility, to find out exactly which processor you have. Then you can go to their downloads page and find the downloads available for your processor.
Dec 30, 2008 | Computers & Internet
Windows xp and dualcore usage
If you mean dual core cpu, I built my system over a year ago and it runs just fine, and better than any system that I ever had. BTW I am running an Intel dual core, but an AMD doesn't make a difference.
Sep 30, 2008 | Medion MED-1511 PC Desktop
Asrock ConRoe1333-D667 Motherboard Logo
95 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
