Question about Desa International White Wireless Plug In Door Chime
Receiver WDC813 RX. What are the jumpers for? Howcan I eliminate theWestminster Chime?
I have an (obviously) ancient but still reliable rx-v990 with the ddp 1. I would like to use it as part of a consolidated set-up with a samsung 550. any recommendations on making this work?
What's a Samsung 550 (no letters)?
The DDP1 is a Digitasl Processor, no amp.
The RX-V990 is an AVR receiver.
What role do you want each of these pieces to play?
The Front channel amps of the RX-V990 could be slaved to the DDP1 (or any other volume-controlled Line level source) by simply removing the jumpers in the RX's Front Pre Out/Main In and driving the Main In.
Mar 07, 2011 | Yamaha RX-V990 Receiver
Change ring tones on wireless ringer SL-6166-RX-A Door Chime
The chimes have jumper plugs to select the preset songs.
You CANNOT load your own like cell phones allow.
Jul 22, 2010 | Music
Yamaha Receiver RX-V3800 Rear Left surround click sound
It's possible it is some sort of interference pickup, but another possible I've come across a number of times on Yamahas is poor earth connections via the back panel.
All the circuit boards have earth connections on them and the screws holding them to the back panel form an earth bonding connection. Tighten all the screws on the back to eliminate this possibility. Costs nothing to try and may just solve it.
Jul 19, 2010 | Yamaha RX-V3800 Receiver
JUMPER SETTINGS FOR SL-6151-RX-A
I just solved a similar problem with mine. I found a PDF of the instructions for changing the frequency and the tone: http://heath-zenith.hcents.com/data/manuals/598-1034-02.pdf
May 14, 2010 | Desa International White Wireless Plug In...
How can I eliminate my high and mid range frequencies going to my 12 inch speakers from my stereo receiver
You cannot do that with this unit. You would need an external crossover connected between it and your speakers to do so.
Mar 08, 2010 | Sherwood RX-4105 Receiver
Hello I have now got 2 (two) of these units over the past 8 months and neither work----changed batteries--interchanged push button---changed main unit--nothing works----but when my neigbour across road has...
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
Jan 04, 2010 | Desa International White Wireless Plug In...
I have a ge wireless doorbell and I need to change the codes. there are 3 dip switch setting and 4 removable switches
The 3 dip switches set the different chime sounds. The 4 jumpers set the code....you will need to change the jumpers on the back of the receiver to match as well
Nov 26, 2009 | Desa International White Wireless Plug In...
Dings sometimes with out pushing the button ??
I believe there are either dip switches (or old-fashioned "jumpers" in both the button (the 'transmitter') and the dinger (the receiver). See if this is the case, and that the dip switches (or jumpers) are in the same position in both units. Then, simply switch one of the dip switches (or jumpers) to another 'position' in both the button and the dinger. There ya go...
Mar 05, 2009 | Desa International White Wireless Plug In...
'Doorman' chimes keep chiming, without bell being pushed
I had the same problem - turned out to be a cordless phone nearby. If you have one, try moving the bell away from the phone or vice-versa. Another possibility is a neighbour with the same code. There are some jumpers you can move around to change this.
Jan 19, 2009 | Desa International White Wireless Plug In...
Desa International White Wireless Plug In Door Chime Logo
146 people viewed this question
Top Desa International Home Security Experts
Eric Kalman
Eric Kalman
Level 1 Expert
Mike
jasbo
jasbo
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
