Question about Hotpoint Aquarius WMA56 Front Load Washer
I went to use my machine "hotpoint aquarius" turned on the power and it made a bang. the noise came from the back of the machine. It never blew my electric and i checked the fuses. Machine is now "dead".
    Brigadier General:
  • 6,277 Answers
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB. I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Mar 22, 2011
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wma34 washing machine - flooding and clicking
Sounds like it could be relatively expensive to put right.
Personally, I think you would be better in investing in a new washer, more so in view of the fact that is 7 years old.
There are numerous possibilities for the symptoms you describe.
Hope this helps you to come to a decision.
Dec 29, 2009 | Washing Machines
Hotpoint aquarius banging about when spinning
hi take the top of the machine and check the brick at top or bottom of the machine they sometimes come lose .
Sep 30, 2009 | Hotpoint Aquarius WF220 Front Load Washer
My hotpoint aquarius front loader has power but wont work.
Most likely the Door interlock is faulty or has fallen apart (through the banging of the door)
Aug 21, 2009 | Washing Machines
Hi,i have a hotpoint aquarius wf340.which makes a very loud banging noise every time it spins,it works fine otherwise!
I had the same issue with a similar machine. Need to replace the spindle assembly (or otherwise make sure) that the belt is tight. Try replacing belt first.
Make sure machine is level. test it by putting some stuffed sockes in the machine, let them get thrown around. Listen for the banging noise, apart from the soft socks hitting the tumbler.
Aug 08, 2009 | Hotpoint Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Wf540 hotpoint washing machine making a banging noise
remove lower front panel pump right of center turn small plastic handle counter clockwise pull out
May 31, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA56 Front Load Washer Logo
73 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
