Question about Samsung Televison & Video
HOW TO ACTIVATE THE HD tuner on my TV - Samsung Televison & Video
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Go to menu and search.
Posted on Aug 03, 2008
HD Tuner
The Gateway GTW-P42M303 can display HD content. However, you will need a set-top box to get that content. The TV only has an analog tuner (NTSC or PAL, depending on the area where you purchased the TV). Thus, you will need to connect a digital-to-analog converter to get most over-the-air stations. (Only low power stations are still broadcasting in analog.) Most of the common d-t-a converters only provided SD (480i) output. There are some HD tuner boxes available; you may have a hard time finding them.
If you have cable or satellite service, then you can get the HD programming package and view it on this TV.
I wish that I had better news for you.
Apr 26, 2013 | Gateway GTW-P42M303 42 in. Plasma...
I have an LCD HDTV BLA. I have Freeview and
Hi.
If you are using an external freeview box you need an HD box (See available products).
If you have an LCD TV with built-in HD tuner (TV will say HD Ready and will have internal tuner), then you can use the TV internal tuner.
The best way to get HD is via satellite. Althought HD Freeview is theoretically available since end 2009 I have not been able to receive any HD channel using Freeview tuner, and I live in a London area where HD FV is supposed to be available since 2010.
Even with Free Sat the choice is poor. You get steadily only BBC HD, where at most you can watch some documentary or drama series (it is a kind of sample channel). ITV HD, BBC1 HD and the rest frequencies on Astra change Sat quite often. I am a TV technician and the sat tuning job is not difficult to me but retuning every month was still an awful waste of time.At the end I gave up and I only watch HD through Sky.
At the end of the day the only efficient way to receive HD TV is still through Virgin or Sky.
Regards.
Ginko
Sep 01, 2011 | Samsung Televison & Video
My Brand New 40" westing
To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
Learn more about Clear QAM cable signals:
http://en.wikipedia.org/wiki/QAM_(television)
Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
Pt-50lc13 is it a HD tv?
It is a HD ready TV meaning that it may not have a HD tuner. If you have cable this should not be an issue but if you want to receive HD channels through the air, then you would need a HD tuner.
Mar 01, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
May 26, 2009 | Philips Televison & Video
Philips SAA7130 TV Tuner/FM Radio/Video PCI remote stopped working
PLEASE THE SEND THE TV TUNER CARD DRIVERS I AM LOST THE TV TUNER CD
May 04, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
How to view TV in a Desktop PC via a USB TV Tuner?
Depending on which kind of tv tuner you are looking (analog basic cable) or HD tuner, the higher end tv tuners will usually handle both basic cable or connecting via satellite or some sort of set top box.
I would look for the ATI TV wonder HD, your going to want a tv tuner that can do hardware encoding on the actual tuner itself, older tuners will rely on your pc to process a lot of the data.
Mar 18, 2009 | Compaq Computers & Internet
Sony projection tv with dual tuners; only one tuner appears to be working now.
To verify that the tuner is the problem, move the cable from the second to the first. If you don't get a signal, the tuner is bad. The main tuner is part number 859843000 and is available for $47.38 from tritronicsinc.com
Dan
Oct 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Maxent lcd
Your TV is an "HD-Ready" television. What this means is that your TV is ready to accept HD input from an outside source, but doesn't have the ability to produce the content itself. It is a monitor and does not have a digital tuner. Without a digital tuner (or for cable a QAM tuner) you will not receive OTA broadcast HD.
You need to purchase a High Definition capable set-top converter box. The converter box will have HD component out and may have HDMI out, either will feed your HD Ready TV.
Apr 08, 2008 | Sony WEGA KLVS23A10 23 in. HDTV-Ready LCD...
Televison & Video Logo
15 people viewed this question
Henry  Thomas
Henry Thomas
