No problem. i dont want it at present time - Computers & Internet
    Guru:
  • 1,833 Answers
Please let me know what is the problem.
Posted on Mar 22, 2011
I want to update my tom tom as i dont have a signal now
Sorry to say tom tom's are worthless. Throw it away and get something else on eBay for under 100$.
Jan 06, 2015 | GPS
From the of the engine is there anything wrong with it?
metal sound is suspicious.. check by removing belt and running temproarily short time (1 MINUTE) dont drive it .. if sound has changed and no metal sounds present inspect to discover which pulley/accessory / idler /tensioner is causing the grinding
Sep 30, 2012 | Cars & Trucks
I need puk 1 but o2 dont know my number because i have not used it for a long time
sir please call to the related simcard customercare and say the last 6-digit number which is present before the simcard. then they will give the pukcode number to unlock the cellphone...........
Jan 11, 2011 | Sony Ericsson K800i Cellular Phone
Document feed takes more than one page at a time
please follow these steps to solve your problem:
1.Fan the papers before loading them in printer tray.
2. Dont use papers that has lot of wrinkles
3. Dont insert your papers too long into your printer. Just load them with optimal distance.
4. After the papers were loaded, adjust the paper hold knob present on either side of the paper such that it holds the paper firmly on both sides.
Now your printer will take one paper at a time for printing.
I hope this is helpful to you. Please provide your rating and comments for the solution provided.
thanks
Mar 08, 2010 | Office Equipment & Supplies
How do I replace the water pump on a 2003 Chrysler Sebring Convertible with 2.7 liter engine?
Dont try this at home. Get a shop to replace it and check the timing chain components. If its not done right, bent valves wil be your New Years present. I recommend this. http://www.fix27engine.com/
Dec 30, 2009 | 2003 Chrysler Sebring
Windshield wipers dont work 2001 audi tt
most likely the wiper signal arm itself if you have tilt wheel over time the wires stretch wear and break causing a short otherwise have a test light handy and with the wipers on position check for power at the wiper ,motor if none is present its the switch if it is present its the motor
Sep 22, 2009 | 2003 Audi TT
Im replacing my piston and rings and i took the cylinder and cylinder head out and i dont know how to time the engine , the sproket has a mrk on it and i dont know if i shuldput the piston all the way down...
Below is a generic diagram. If only one mark is present it points upward and in line with the crankshaft center line. If two marks are present they line up with the gasket surface of the cylinder head. The piston should be on TDC and the cam lobes should be pointing downward. Be sure the chain is on the crank sprocket, not wedged between the sprocket and the balance weights. Also be sure that the chain is taught on the front side of the engine. Any slack should be at the back side of the cylinder so the chain tensioner can work properly.
Can I get a “very helpful” rating on this answer?
Aug 23, 2009 | 2005 kawasaki KDX 220 R
Batterie
Your internal CMOS battery(button battery) needs to be replaced. That keeps your date & time always working. Therefore when your main Battery runs out and external power is not present the date and time goes back to the date of manufacture.....sodeep
Mar 24, 2009 | Computers & Internet
How can open the monitor Body (Cover)
hello,
it seems that you open any monitor first time i suggest you to if any screw is not present then not to try to open and if screw is present then remove the screw and remove the base also. then see any lock present on the cover. pull the housing upwards and plz unlock the cover very safety and this you may remove the cover
thanks
ramesh722
Nov 13, 2008 | LG L1717S-BN 17" LCD Monitor
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
