Question about E-Flite Eflh1057 Hp6dsm 6-ch Transmitter Dsm2 Blade Sr
Do you know of a link where I can download a user manual for the HP6DSM 6-Channel RC Transmitter?
US Army 3.5 Channel Sky Runner Gyro RC Helicopter. Where can I download an owner's manual?
Excalibur Sky Runner User Manual
Try to read the pdf of the user manual of Sky runner.I hope it can help you to solve your problem. thanks
Apr 10, 2016 | RC Toys
Tip
Onkyo TX-SR605 Manual Download
Download Onkyo TX-SR605 Manual
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo TX-SR605 Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
________________________________________________
RC-682M Remote Code List & Programming Guide Here.
on Apr 20, 2010 | Onkyo TX-SR605 Receiver
Tip
Onkyo RC-682M Remote Codes
Download Onkyo RC-682M Remote Codes
4 Digit Onkyo Remote Codes
Have you misplaced your Onkyo RC-682M Remote Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo RC-682M Remote Users Guide?
I hope that helps.
Download Onkyo TX-SR605 Users Manual Here.
on Apr 20, 2010 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Why does my Hubsan H107c only blinks blue LEDs and won't start up anyone know how to solve this problem?
Sounds like it has not bonded with the transmitter. Check the manual for bonding. Should be something like " switch on quad..holding throttle button down (pressed in) switch on transmitter ,wait until lights stay steady.Release throttle and set to lowest position." but check the manual as different units have different bonding setups.
HTH
May 24, 2014 | HUBSAN H107 X4 4CH Super Mini RC...
Why wont my RC helicopter respond to the controller
The Helicopter channel/frequency may need changing to match the channel/frequency on the transmitter.
OR change the transmitter channel/frequency to suit the helicopter.
Feb 06, 2013 | Toys
Tip
I hope that helps.
Cannot find an english version for JVC RC-EX30 manual
From this link you can download the user manual for JVC RC-EX30B. Don't forget to vote for this device in order to start the download.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 12, 2010 | JVC RC-EX30 Radio/Cassette/CD Boombox
Hi, My philips 42'' plasma won't turn ON. I went to turn it on and the ''on'' button flashes red 7 times 4 seconds apart
I just had the same problem. I downloaded a service manual and give this a try http://www.servicemanuals.net . Turn on your TV and with the remote do the following Key in the code “123654” via the standard RC transmitter. This get you into a customer service mode and you can check your error codes.
After I got out this mode my TV worked. I think the TV was stuck in protection mode for some reason and by entering the service menu's it reset it.
I then entered the SAM Mode
How to Activate SAM
Via a standard RC transmitter: key in the code “062596”
directly followed by the “INFO” button. After activating SAM
with this method a service warning will appear on the screen,
you can continue by pressing the red button on the RC.
It will give you more info.
The TV worked fine after I exited these menu's.
I also did a software update as per the user manual and the TV seems to be working fine again.
Hope this helps
Sep 09, 2009 | Philips 42PF9631D 42 in. Plasma Television
E-Flite Eflh1057 Hp6dsm 6-ch Transmitter Dsm2 Blade Sr Logo
Top E-Flite Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you an E-Flite Toy Expert? Answer questions, earn points and help others
