Question about Nintendo DS Console
My DS Lite when powered up will show the green light, it then gets brighter and then the system shuts down. I have checked and replaced the fuses and checked the cables just in case but still the problem remains. Can anyone help ?
    Scholar:
  • 60 Answers
That sounds like the behavior of a fault resistor. I would get a new board. They are surprisingly cheap.
http://cgi.ebay.com/Used-Nintendo-DS-Lite-NDSL-MainBoard-Motherboard-Tested-/270696614064?pt=Video_Games_Accessories&hash=item3f06c688b0#ht_2279wt_905
Hope This Helps.
Posted on Mar 22, 2011
  • andrewgra278 Mar 22, 2011
    it makes a clicking/popping sound if I listen closely when it goes off, maybe this can help you but a new board me thinks is the answer
    thanks for the advice.
  • Dane Andreasen
    Dane Andreasen Mar 22, 2011
    Yeah, Unless you have a bunch of scrap board to swap components back and forth your really going to have a hard time. Either way. I've repaired about 15 to 20, and they never seem to get any easier...
    Good luck.
My sond ds lite wont turn on and the charge light
Yes, this problem is normally caused by one or both of the fuses have blown on the logic board.
Feb 17, 2010 | Nintendo DS Lite Console
My ds wont charge the orange lite wot turn on and the charger slot on my ds is wied looking
my ds lite wont charge i get a flash of the orange light then nothing can you help me please
Jan 05, 2010 | Nintendo DS Lite Console
Nintendo DS Lite, Dim Green Light, Brigher Green Light then off
If the green light reacts as you state then the chances are the fuses are fine.
Again, with the reaction of the green light being as you stated i'm going to assume you have a problem with one of your screens, tell me... when the green light comes on does one of the screens flash? If it does then we have found the answer...
The screen that doesnt flash is the one with the problem, you can try taking the DS lite apart and re-connecting the screens ribon to see if that sorts it, if it doesnt then im afraid you will have to buy a new screen. These can befound on ebay for a reasonable price.
I have written some guides on how to change your screens and how to disassemble the DS lite, these will guide youthrough the processes you need to take. These can be found by clicking on my name and then scrolling down to "tips and tricks", press the "view all" to see all of them and find what you need.
I hope this helps.
Regards,
SOD69
Jan 03, 2010 | Nintendo DS Lite
Ds lite charge, but green lite will not come on
You have damaged the L2 fuse just below the power button. It is vary delicate and easy to knock of off its placement despite being soldered in.
Double check this fuse to make sure it is still in place and soldered to the contacts on both sides of the fuse.
Sep 08, 2009 | Nintendo DS Lite Console
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
DS Lite will not power on
blowin F1 or F2 fuse or both inside your nds. can be fixed by runnung a bead of solder the blown fuse so it bridges the fuse (idealy you would replace fuse but its very tricky) first of all if you have a multi meter check the fuses before soldering them. anyway i advise not to use the homebrew card especially on your nds when you bridge the fuses as once the fuses have been bridged there is no saftey shut off to stop more sever damage. oh by the way just youtube F1 and F2 fuse location to find out where they are. oh and use a 15watt solder iron to be on safe side (less chance of overheating any components near fuses when soldering). its not that hard to do really (i did 2 of them with a gas solder iron due to me not having a 15watt iron) also replaced cracked screens. my next job to do is replace a L2 inductor on a friends nds (symptom for this fault is nds charges but will not power up, not even a blink of green light) for anyone who has this symptom its the L2 inductor thats broken away
Mar 28, 2009 | Nintendo DS Lite Console
Power light/ no image
Call Nintendo for your best luck with fixing the prob.
Aug 25, 2008 | Nintendo DS Lite Console
Nintendo DS lite
Baakie,
You turn de DS Lite on, the green light flashes and the unit turned of. Is that correct?
The DS Lite checks some things before he starts-up. One of these things are the screens. the DS sends a signal to it and expect an answer back. When this answer is not received, it shuts down.
The most common problem in these cases is the flatcable of the upper screen.
Question is, did you replaced the housing? If so, you might dammaged the flatcable of the upper screen. If not, the flatcable might be defective because of using the DS Lite a lot (open /close the unit).
So first check the flatcable of the upper screen (google and you will find manuals how to open the DS Lite but be carefull!!!!)
Second, on the mainboard are two fuses (F1 and F2) . Check these! One of them might be defective
Success
Jul 19, 2008 | Nintendo DS Lite Console
Nintendo DS Lite will not power up
This can sometimes be caused by the single smt capacitor on the board in the top half that the screen cables plug in to. Try replacing the cap or the entire board.
Feb 25, 2008 | Nintendo DS Console
Nintendo DS Console Logo
180 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
