Question about Electrolux Ovens
My electrolux EOD 3360 bottom oven is getting too hot. The oven temperature light stays on even at the lowest setting or defrost setting. The inside of the oven is literally roasting hot, and anything I cook is burning straight away. The fan is working and the interior light is on, but the oven doesn't seem to recognise that it has reached the set temperature and is continuing to heat up. Any help or suggestions would be greatly appreciated. The oven is about 3 years old and is cleaned and mainatined regularly. Thank you.
    Sergeant:
    Champion:
  • 240 Answers
1 . If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
2 . If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
3. A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Posted on Mar 22, 2011
Oven temperature
have a service technician examine the oven and in particular the digital controlled thermostat
from what you describe the thermostat setting is not constant (loose connection etc) or faulty digital control unit
Nov 07, 2015 | Electrolux Ovens
WE HAVE AN ELECTROLUX DD060GA DOUBLE OVEN THE TOP OVEN IS WORKING BUT THE BOTTOM OVEN DOESN`T EVEN COME ON WHEN YOU TURN THE KNOB THERES NO GAS AND NO SPARK AND THE LIGHT WONT COME ON EITHER, CAN YOU...
Good Morning Friend,
I understand that your Electrolux double oven, model# DD060GA, is having trouble with the bottom oven coming on. I also see that your top oven works just fine. This appears to be a UK Electrolux double oven. I suggest contacting the manufacturer directly. They will be able to better assist you in getting your bottom oven functioning correctly.
-Best Regards-
WP
May 21, 2014 | Electrolux EOG7330WN Gas Double Oven
Beko OFT12300X double oven top oven getting exceptionally hot inside when only the bottom oven is on
I know of nothing unusual about this, the oven vents some through the top burner.
May 19, 2017 | Ovens
Electrolux EOD 985 bottom oven over heats burnng food
thats because the heat sensor isnt working properly need to replace
Apr 25, 2012 | Ovens
We have an electrolux E30EW85GPSS double oven. The lower oven appears to work properly. However, the upper oven will bring itself up to the set temperature but after reaching it, does not stay on and...
Hi
This means a loose/broken wire on the oven temp sensor or the sensor is bad and should be replaced. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control board however, as the issue is only with upper oven it is most likely that the temperature sensor is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 17, 2011 | Electrolux E30EW85GSS Oven
Model EOD 43102. The Fan oven will not reach required temperature. I have just had the thermostat replaced. Still the same. 3 years old. godden1@ntlworld.com
see if u have a limiter ...its like a bullet (covere in white cover ) it will have a burn mark on end if you have one. u need to take the top cover off also when you are there take the control switch off see if its melted were the pins move up and down ... (contacters).... other wise take therear cover off inside main oven and inspect the fan element.
Feb 27, 2011 | Electrolux E30EW85GPS Oven
Simpson Evolution 904 wall oven cooks very unevenly
I agree, the heating is very uneven in our oven, however, when I calibrated the temperature with a thermocouple, I discovered that the temperature gauge was 25C too hot! That is, if I set the oven temperature gauge to 155C, it was actually 180C inside the oven! Taking this in to account, it is now much easier to cook things without them burning.
Sep 26, 2009 | Ovens
Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
Ovens Logo
202 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
