Hi i get an error 4220 now when i try and burn a cd on itunes,can you help please.
  • 21 Answers
In iTunes, go to 'Edit' -> 'Preferences' -> 'Advanced' -> 'Burning', and on the 'Preferred Speed' drop-down menu, reduce the speed from 'Maximum Possible' to something lower, like '8x'.
Posted on Mar 22, 2011
Just recently, when i try to burn a CD in itunes, it starts burning the first song, then cancels and pops up with "an unknown error occured (4900)" Then, it freezes itunes until i manually eject...
http://www.pc-library.com/errors/error-code/4900-0x1324/ theres your answer please rate me 4 thumbs up for doing the research for you. I hope this explains everything! Have a wonderful day.
May 10, 2011 | Gateway GT5220 PC Desktop
Trying to burn a playlist from my itunes account and get 4261 error message, what does this mean?
The ITunes error 4261 appears when attempting to burn CD's. The error code can appear for several reasons, including a faulty CD-RW, used CD's or a slow speed burner.
The error may also occur when you are trying to burn a file that has Dynamic Random Memory from ITunes & you have exceeded your permitted attempts.
The error can also happen if you are accessing the files from a different PC than where it was registered.
Try slowing your burn speed to 16x or even 12x or use Nero Express or Windows Media Player to burn your MP3 files. Other techniques for resolving this error include using new CD's & activating DLA in the Drive Properties.
I truly hope that one of these solutions clearly resolves your problem. Good luck.
Kindest regards,
Ste
Apr 01, 2010 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Burning a disc
please 1st you install a burning software and then burn you disc.
Aug 11, 2009 | Apple iTunes
ITunes registry error/CD-DVD not being recognized
I had the same problem with iTunes and installing the GEAR driver fixed it. If the drive itself is disappearing then the problem is probably more than iTunes. Try updating the actual CD driver at the Dell Support Page then install the GEAR driver again.
Feb 14, 2009 | Apple iTunes
I found the solution at Gearsoftware.com
The Audio FIle System (AFS ) driver is not compatible with Windows Vista.
I changed the driver file name as instructed and TaDa...it fixed my problem with itunes and Windows.
Hope this helps you.
Dec 14, 2008 | Apple iTunes
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
My cd burner wont burn a music cd, itune displays an 2113 error
hi there,
have you tried installing the version 7.6 on your system... this might fix any problems with the old installation ... and add support for your cdrw drive...
use this link:- http://www.apple.com/itunes/download/
but here is a small tip ... if you can burn cd's on your system using other burning software then its your itunes which has a bug.
Apr 26, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
944 people viewed this question
Alun Cox
David Payne
David Payne
