Question about Car Audio & Video
I need the wiring diagram for a panasonic cq-c8303u car stereo system
    Brigadier General:
  • 6,966 Answers
Any developments?
Cheers.
Posted on Aug 03, 2008
Panasonic car stereo wiring diagram for model CQ-DF203U
Go to web site for unit's manual . It will have the wiring schematic for you.
Aug 23, 2017 | Panasonic Car Audio & Video
Wiring diagram panasonic cq c100u
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Wiring diagram to many popular car audio systems are given.
Jul 19, 2014 | Panasonic Cq-c1101u In Dash Cd Player...
How to install a panasonic cq-c8303u
You might need a few things to install your radio. You will need a wiring harness, install kit, and instructions. You can find specific wiring harnesses and install kits at www.crutchfield.com and you can purchase instructions at www.sound-repair.com Hope this helps
Aug 23, 2011 | Car Audio & Video
I took my panasonic cq-c8303u out of my jeep and put it in my civic hooked all the wires up right but no power to my deck whats could the problem be?
Check the in line cylinder fuse for the radio, cause they blow easy. Also, check the radio fuse under the dash or wherever your fuse box is located. Make sure you solder the connections for a good contact, cause just wrapping electrical tape around the wires will cause you problems down the road when you go over bumps.
Nov 11, 2010 | Panasonic CQ-C8303U CD Player
Panasonic cq-c8303u wiring diagram
Here's a link to download the manual for your radio just copy and paste it in to your web browser and download the PDF file. You will need the reader to view it. If you don't have the reader you can download it for free at www.adobe.com
http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-C8303U
Oct 09, 2010 | Panasonic CQ-C8303U CD Player
Panasonic CQ-C8303U. Hooked up an amplifier and it works with the radio but when i put in a cd the amp doesn't work. the receiver just plays with normal sound.
Verify your wire connections are correct. Keep in mind that if your amp is hooked up to the radios power antenna wire this is the problem. When you insert a cd the radio is designed to lower the antenna. If your amp is hooked up to the antenna wire the radio is shutting off the amp when you put in a cd Panasonic does this on most of all their units. You may have to hook your amp up to a separate switch to turn the amp off and on or hook it to your ignitions acc wire, if you hook it up to your ignitions acc the amp will stay on as long as your key is on even if you turn off the radio.
Bought a panasonic radio model # CQ-4400U did not have a wire diagram with it
You can find a generic color code diagram for most/all aftermarket car stereos (including Panasonic) here:
http://www.siocommunications.co.uk/Wiring_files/audio_wiring.jpg
This picture should cover just about everything. If the picture has a wire that your stereo doesn't, just ignore it. Not all stereos have all color wires, and some stereos have colors or RCA jacks or plugs that aren't in the diagram. Those are usually connectors for amplifiers, CD changers, satellite radio, or something like that. The basics should all be included in this diagram though. Good luck!
Jun 16, 2009 | Panasonic Car Audio & Video
Navigational system
I don't have the wiring diagram for panasonic CQ-VD6503U car stereo with DVD and navigational system ready. Could you tell me where I can get one? Can you also tell me if this stereo is also navigation ready? I don't know if need a software cd and if I do could you tell me where I can get it too?
Jan 13, 2008 | Panasonic CQ-VD6503U Car DVD Player
Panasonic cq-c8303u Car stereo problem
There is for sure a hook up problem my friend. There should be a memory wire that always has power to it even when the car or the ignition is off. Then there is a switched type wire that only comes on when the cars ignition is on. Check both of these wires in the car. Check the car wiring diagram to confirm this. To confirm the wiring in this vehicle, I Good Luck with this install. And if all else fails, don't take a chance and blow out the unit, take it to a pro to be installed. Good Luck found the right wiring diagram for your car. Confirm this wiring diagram with this one you have. Go here:http://www.the12volt.com/installbay/stereodetail/955.html
Jun 19, 2007 | Panasonic CQ-C8303U CD Player
Car Audio & Video Logo
148 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
