No full screen display on my digital display when using hdmi output on my hp pavilion dv3 2105es
  • 69 Answers
Click Fn + F7 after attaching HDMI Cable.
try this one, twice or thrice u will find a solutions.
Thanks.
Posted on Mar 22, 2011
Hooked up my HP pavilion dv7-1240us (Vista) to our HDMI cable, then into the TV, as usual. Slept he computer, then disconnected the HDMI cable. Since then, I cannot get any screen at all. Have tried...
restart pc in safe mode, change video back to standard VGA of HD VGA video. PC has to be in HDMI mode and your TV has to be PC mode. Use a DIV to HDMI connector or better yet HDMI to VideoPort if your TV supports it, HDMI almost never gives you the screen output you really want anyway.
Jan 17, 2014 | HP Pavilion dv7-1240us Notebook
Screen frame broke
Screen frame being the Display Bezel.
http://h10032.www1.hp.com/ctg/Manual/c01573159.pdf
With the laptop closed, the top cover is the Display Enclosure.
Is it broken also?
http://www.lapzone.com/servlet/the-54572/HP-Pavilion-G70-17-dsh-inch/Detail
Can you say OUCH! That's the cheapest I found, but it was a quick search. Hopefully you'll have better luck in searching.
The HP part number, for the Display Bezel of the HP G70 series, is;
HP 488386-001
The HP part number for the Display Enclosure is;
HP 488379-001
Base Enclosure;
With built-in modem, Digital Media slot, AND -> with HDMI port,
HP 489114-001,
http://www.impactcomputers.com/489114-001.html
Base Enclosure:
WITH built-in modem, Digital Media slot, and NO -> HDMI port,
HP 501252-001,
http://www.ebay.com/itm/ORIGINAL-COMPAQ-CQ70-Case-Bottom-Covers-501252-001-Grade-A-/330628933816?pt=LH_DefaultDomain_0&hash=item4cfb0528b8
Hinge Kit; (2 each Hinges),
HP 488384-001,
http://battery-adapter.com/product_info.php/products_id/3900/vSPS:+488384-001
You have more damage than just the Display Bezel, I feel.
Access what damage you have, and I'll step by step guide you in replacing.
Just post back in a Comment.
Regards,
joecoolvette
Jan 29, 2013 | HP G70-250us Notebook
Hdmi not detected by HP Pavilion dv5-1235dx Entertainment Notebook PC
You may want to check your dispaly properties to make sure that your display is set to HDMI instead of laptop display in the control panel under display properties. On many laptops, this can be done by pressing the "fn" key and a key with a blue symbol of two screens on it. This toggles between your primary display and external ones.
Nov 23, 2012 | HEWLETT-PACKARD Pavilion dv5-1235dx...
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
Just bought HDMI cable to be used on dv9700 got the picture on my tv, but no sound go to sound option but not able to see any HDMI sound output I got only 2 options on my sounds: 1. Speaker 2....
We might need to change the audio settings from Sound and Audio device properties window.
Open Control and double click on Sounds and Audio devices to access the window.
Change the audio output from analog to digital.
Make sure that HDMI audio is enabled in the sound device.
If the source device menu has adjustment for PCM frequency, set the frequency to 96khz or less than that.
Sep 01, 2010 | HP Pavilion dv9000z Notebook
HDMI, and VGA on HP Pavilion dv6 1359wm, S-Video on Emerson 19' TV, need to connect?
you need something like this http://www.amazon.co.uk/VGA-to-S-Video-RCA-Adaptor/dp/B000P3UB24 - but you may also need to see if the VGA display adapter supports the output, sometimes this also needs to be enabled to get it to work - other times it works just by using the VGA output switch - which will be one of the F keys look for a symbol of a screen and then use that F key and the FN key together to toggle the output from <laptop only><laptop and VGA output><VGA only>not necessarily in that order. The HDMI is a digital signal out and to convert to analogue for the TV will need an expensive convertor
Apr 21, 2010 | HP Computers & Internet
No sound from the HDMI
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector for connecting a monitor or TV. If you use HDMI to connect your display, you must activate HDMI sound by adjusting your Windows settings . If HDMI is not activated, you cannot hear any sound. Because of this, HP recommends that you connect analog speakers to the computer to hear sound during the initial setup of the computer. Use the following steps to activate HDMI sound on your computer: NOTE: If you ever perform an HP system recovery, you must repeat this procedure to activate sound for the HDMI connector.
  1. Right-click the Volume icon by the time in the lower-right corner.
  2. Click Playback Devices . The Sound window opens.
  3. On the Playback tab, click Digital Output Device (HDMI) if it is listed. If it is not listed, click Realtek HDMI Output . Figure 1: Digital Output Device (HDMI) selectionc01503048.gif Figure 2: Realtek HDMI Output selectionc01063625.gif
  4. Click Set Default .
  5. Click Apply .
    • If you used Digital Output Device (HDMI) , click OK to close the window. This completes the steps to activate HDMI sound.
    • If you used Realtek HDMI Output , continue with Step 6.
  6. Double-click Realtek HDMI Output . The Realtek Digital Output Properties window opens.
  7. Click the Supported Formats tab.
  8. Place a check in the 48.0 KHz check box, and make sure that there are no checks in the Dolby Digital check box and all other check boxes. Figure 3: Supported Formats settings in the Realtek Digital Output Properties windowc01503049.gif NOTE: For most TVs to play back audio, the sample rate must be 48.0 KHz.
  9. Click OK to close the window.
Nov 23, 2009 | HP Compaq Computer Speakers
How can I view my pc on tv using an hdmi cable and a comcast digital cable box? My tv does not have an hdmi input.
The hdmi port on the Comcast box is an output only and cannot be used as an input from the general public. If your tv has a DVI output, there are DVI to HDMI adapters that can make the hook up....other than that, there is the super video cable but you will still have to run audio through a seperate line.
Oct 11, 2009 | HP Pavilion dv9000z Notebook
NO SOUND WHEN USING HDMI FROM PC TO HDTV (RUNNING VISTA)
When using an HDMI to DVI cable their is no audio that comes through that cable. Even if you use HDMI to HDMI most computers only have video output from HDMI. You will have to use a seperate audio cable for you to be able to get the sound to work. Depending on the output you have on your laptop you may have to resort to hooking up a pair of speakers to the headphone jack.
Hope this helps.
May 27, 2009 | HP Pavilion dv9030us Notebook
HDMI connection on HP Pavilion dv9000
try going to windows mobility center & click connect displays
Feb 03, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
181 people viewed this question
David Payne
David Payne
