HP Officejet Pro K5400 prints a test page after EVERY print job. I have just installed a new KY print head ink. How do I stop this?
    Problem Solver:
  • 14 Answers
Go to printer settings in control panel. Uncheck clean head on each print in maintenance section
Posted on Mar 22, 2011
Black ink not printing properly on HP Officejet Pro K5400. It's a new cartridge, have tried another cartridge too but same problem.
The print head may be blocked.
Run the cleaning cycle a few times on the machine.
This can be done through the software drivers loaded on your computer.
If this does not help, you will need to replace the black print head.
Feb 14, 2011 | HP Officejet Pro K5400 All-In-One InkJet...
OfficeJet Pro K5400...ink cartridge
Er, NO.
The answer to the above question is clearly misleading.
If you consult the documentation for your HP K5400, which can also be found online, you will find that the printer cartridge lights also blink when the print heads require replacing.
If you have replaced the cartridge and the light still flashes, this is the most common solution. Replace the print heads.
Unfortunately because the printer is badly designed, there is no way of indicating this, and you will have troubles if you attempt to get the HP Toolbox or any other diagnostic tools working.
Feb 12, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
HP K5400 will not print black
Check the black/yellow print head.If necessary replace it.It's part number is C9381A, #88
Oct 13, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
HP k5400 KY printhead always reports bad on Monday morning
Remove the Printhead and clean the contacts on the back of the printhead and also in the where the printhead mounts.
Try leaving the printer turned on over the weekend as the fault maybe caused by the ink drying out.
Jun 22, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Flashing KY. I cleaned the print heads and
this is the time the board of your printer short circuit. theres is not problem with your ink or even you replaced it is still there... try to look for technician.
Jun 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Hp officejet, pro k5400 printer,when printing i get lines top to bottom on print,about 1 inch apart,tryed print head cleaning,changed the cartridges .need help ,top to bottom,only on...
That is ink or dirt on the rollers, you need to clean them by lifting the lid, as if you were putting new ink in, and wipeing the rollers that the paper runs through.
Jun 09, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Can not get the hp k5400 to print blue put in new ink cartridge says it see's it but wont print
This printer uses Printheads. Print a quality diagnostics page from tools in the setup menu. If there are lines (or no color) in the blue box then replace the C/M printhead.
Jun 05, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Officejet K5400 Won't print black
  • If there are defects on the page, run a Level 3 clean from the control panel of the printer. Follow the steps below:
    1. Press and hold the Power button.
    2. Press the Cancel button one time and the Resume button nine times.
    3. Release the Power button.
May 15, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
My KY yellow light is blinking. What should I do?
The k5400 is not recognizing that the ink cartridge is installed. Clean the contacts on the back of the ink cartridge and also the contacts in the K5400 printer. I always use 91% isopropyl alcohol, Hp says to use distilled water. Do let the contacts completely dry before reinstalling.
Feb 24, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
HP K5400 - print pausing
print as image tick it than it will work
Jan 19, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
472 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
