Impossible to find a radio station. I only hear background noise
    Scholar:
  • 150 Answers
Hello tack_veroniq:
Make sure there is an antenna connected to your receiver. If you have cable and there is a cable connection to your receiver try hooking that up to it. If not cable then try just any piece of wire to your antenna connection on your receiver and you should be able to pick something up.
If this helps just click the thumbs up. Good Luck
Posted on Mar 22, 2011
Lost am radio but still have fm
AM and FM radio use different aerials. You need to check the AM aerial is still connected. Some radios mute the background noise of no tuned stations, but if the aerial is good it could be a fault on the radio.
May 08, 2018 | Audio Players & Recorders
Why do radio stations have static?
Why are all my radio stations static? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Feb 20, 2014 - on all of the radio stations in my car, there's a static background noise. no ... It sounds like the receiver has lost it's sensitivity. either that, or the ... Why am i still getting static on my radio?
Sep 16, 2013
Why are all my preset radio stations static?
Sep 3, 2012
Why do AM radio stations have so much interference and static ...
Jul 2, 2009
My car radio makes so much static noise with engine running, but ...
Jan 17, 2007
More results from answers.yahoo.com
Dec 12, 2015 | 2005 Dodge Durango Limited
On AM radio, there is often a sound, like a hammer hitting a 55 gal. drum interrupting the program. Does not do it on portable radio carried in the car.
all stations AM?
is the engine running?
for get the portable, some have vastly better a/m radios than any car has. in fact many cars radios a/m OR of horrid quality.
i can tell you why but its boring. (AGC, read up on that)
did you try the radio in car, parked say across town.?
did you try all stations
are you like 1 block away from an AM radio station, overloading yours.
AM radios are basically noise making radios., that is why FM was invented to stop that noise, (i cant hear it so.........?????)
are you listening to far away stations, this is normal
in fact you might hear 2 stations on same channel (freq)
and they will beat against each other.
on case of is in S.Calif where your station is clobbered by high power mexican stations 50,000 watts. strong.
and worse a night, does it get better in the day?
here is my advice, many AM stations have a rebroadcast on FM.
go there and listen. (use SAT radio?)
AM radio is subject to vast sources of noise.
ignition noise., high voltage power transmission line noise.
machinery noises, (electric)
or even illegal transmitters in your hood.
many new cars the AM radio is junk, they use this very cheap
chip inside that does this very poorly, but allows them to say
it has AM. ( for $1 cost)
the FM side is 10x better, or more. move up to FM like we all did back in 1967. (i used to build and sell converters back then)
answering for , all other modes work perfect, but AM radio..
Oct 28, 2015 | 2015 Jeep Grand Cherokee
Radio works but can transmit and only hear ocassional traffic
thats happening a lot today.I don't think its your radio ,I think its just background noise because there is no one on the radio but you at the time .There is so much skip working all the channels that it creates a sssshhhhh noise in the radio and it gets real loud at times. some times going over an s 9 and if that is the case you won't be able to hear or talk on the radio .
Apr 12, 2014 | Radio Shack Radio Communications
Background noise problem with motorola radius cp200 and also crackling status during transmissions
Bill,
If the crackling and static are coming from the radio, it could mean 1) Something in your environment is putting out RF (radio frequency waves). 2) You have an old battery. 3) You are at the edge of the radio's range. 4) You have a bad speaker in the radio.
Possible solutions for you could be:
1) Have the radios reprogrammed to have Private Line (PL). This would block out RF noise on your frequency. Also, within the factory if there are devices putting out RF noise, there may be some solutions for them.
2) Replace old batteries. (Try a known good battery and see if it helps.)
3) Check to see if you have the same problem when radios are within a closer range. If it is a range problem, education yourself and other users to hold the radio upright (perpendicular) to the ground. You will get the best range. Tilting the radio can reduce range as much as 2/3s. Even the bodyfluid of a person wearing the radio can absorb range.
4) See if you have the same problem with another radio, or if the crackling static is just with the one radio. It may need repaired.
Another solution for you might be a noise canceling remote speaker mic. This would put the speaker of the radio up on your lapel. And these mics also have some noise/wind canceling ability.
There are a few programming things you could have your local dealer try. They may be able to tighten up the squelch and knock out some of the noise.
Best regards.
Mar 11, 2013 | Radio Communications
2007 Chrysler 300 , AM radio not working , but FM works fine
Usually when you lose only AM it is an antenna issue. Check for a loose antenna plug on the back of the radio or connection to the antenna.
Nov 15, 2008 | JBL - MR4W Am/Fm with CD Player White
Degen DE1103 background tone
the background tone is due to frequency static...the design of the stereo is not good... it lack of noise destortion cirquit..and almost all stereo that is analog usually poor in in design..change the stereo.try stereo that is digital in design..
Oct 13, 2008 | Kaito KA1103 SW/FM/AM Radio
Uniden Phone 5.8 Ghz- I hear a spanish radio station
depening on your location if you have no interuption from other freqency from other leaking environment you r hanset may have a manufacture sorftware or hardware problems if you try another hand set wiht same problem posible a decfive ..
Oct 01, 2007 | Uniden TRU8885 Cordless Phone
26 people viewed this question
 Grubhead
Grubhead
