Question about Black & Decker 3 x 21 In. Dragster Belt Sander
CHANGE THE SANDPAPER IN THE BELT SANDER - Black & Decker 3 x 21 In. Dragster Belt Sander
  • 604 Answers
There should be a lever that will loosen the tention on the belt so you can get it off. be sure to put the new belt on with the arrows facing the rotation (some sanding belts do not need to be oriented this way, but check) otherwise the belt will come apart after a few rotations.
Posted on Mar 22, 2011
What is the usages of a PALM SANDER?
What an odd question .....
To sand small areas that are otherwise inaccessible to orbital sanders.
Apr 07, 2018 | Tools & Hardware - Others
I need a drive belt for a Stanley belt sander
Unless there is a model that I have never seen, the sandpaper is the drive belt on belt sanders.
Jul 04, 2014 | Hand Tools
Towel caught in front roller
Well, it sounds like you have a belt sander. I would start by sacrificing the towel and the belt. Even if you tried all day and were able to save them they would probably look like they got caught in a sander. Get a utility knife and change the blade, you will want a brand new sharp blade for this. Start by cutting as much of the exposed towel off as you can. Remember, at this point the only thing you might be able to save is the sander. Cutting off the belt will relieve the tension. When you cut the belt give yourself enough belt on ether side to get a good grip. You might need to pull the belt back and forth as you remove small pieces of the towel. A good pair of pliers might help grip the towel fragments. When you finally do remove all the towel and the belt, take some time to look around the drum for fibers that might be stuck in the bearings and pull them out. You may need needle knows pliers for this. Keep the towel shreds for sating rags to finish the project you're working on so it will not be a total waist.
Good Luck
Ray
Apr 28, 2014 | Makita Tools & Hardware - Others
Need part for Mastercraft belt sander 54-7240-8 I need to replace the belt on the motor that drives the belt drive assembly. The motor runs ok but, the wheel that drives the sanding belt doesn't turn...
Anyone has a broken belt sander 54-7240-8 within Canada? I could use a particular part from it to fix mine. If you do, email me at mstevlik@zoznam.sk
Thanks.
Sep 27, 2011 | Tools & Hardware - Others
The sandpaper keeps sliding off the sander everytime I turn it on. Even when I turn the dial it to tighten it or move it over it keeps on sliding off.
You need to turn the dial slowly. If the belt starts to come off turn the knob in the other direction,slowly until the belt is centered. Doing it slow is the trick.
Jun 04, 2011 | Black & Decker 3 x 21 In. Dragster Belt...
How do you replace he belt on a 7447 Sander
To change belt:
1) Put front roller on floor and push down until roller locks back.
2) Put on new sand paper.
3) Loosen tracking screw until front roller is released.
4) With sander running, use tracking screw to center belt.
Oct 10, 2010 | Black & Decker BR300 3''x18'' Belt Sander
Sandpaper does not stay in place
re align the end rollers as one of them will be out
Mar 22, 2010 | Black & Decker 3 x 21 In. Dragster Belt...
How do I change the sandpaper in my Black & Decker Sander 7448? I lifted the two levers and the sandpaper came out but now I cannot get them to close tightly around the replacement sandpaper.
there are many types of sizes for this sander check you have the right size first,,, after that check that the return springs in the belt tenshioner are poping out fully
Nov 15, 2009 | Tools & Hardware - Others
Sandpaper sliding off
there isnt enough tension on the belt, hence the side to side movement. keep tightening the spring until it stops
Jul 22, 2009 | Tools & Hardware - Others
Black & Decker 3 x 21 In. Dragster Belt Sander Logo
661 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
