I cant find a driver to run my ilo 27 inch tv for my computer the screen is fuzzy when i hook it up through the s-video.... how do i use it as a crystal clear monitor as i understand it is capable of? i have n-vidia 6200 oc video card 2.4 gig comp w/ 1 gig ram
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Try differ input.
Posted on Aug 03, 2008
I have a 32 inch flat screen Ilo and bought a new computer with Windows 7 but it doesn't come on. Where can I find drivers to fix it?
You do not need monitor driver, but you must make sure to set the computer video out put to feed yourr TV to be at native resolution, you need to find out what that is, otherwise you will get resolution not support on the screen.
Nov 19, 2009 | iLO 3200 32 in. LCD Television
CANT USE DIGITAL TV OR HDMI MODE - SCREEN NOT SIZED
Give FUNAI a call they can walk you through the problem. There info is...
FUNAI CORPORATION Customer Service
Tel :1-800-605-8453
http://www.funai-corp.com
Feb 15, 2009 | iLO IWT3206 TV
Ilo tv stuck in widescreen
LOOK EITHER ON YOUR REMOTE FOR ASPECT OR IN YOUR ON SCREEN MENU FOR THE PICTURE SIZE OR ASPECT RATIO FUNCTION TO ADJUST IT BACK TO THE SIZE YOU REQUIRE.
Oct 22, 2008 | Televison & Video
Ilo 27
If you have the original remote, try the "picture size" button.
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Ilo 27" flatscreen
I moved and the manual and remote got lost. I bought a ONE FOR ALL remote that has the iLO printed on the add but I can't get the tv to work, I tried all the codes but nothing worked. How can I get a manual from the computer to work this iLO tv, which I am unable to use. Maybe I should have purchased a Sony.
Sep 30, 2007 | iLO Televison & Video
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Ilo 27inch hdmi hd tv monitor
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
32" hdtv ilo- connect to pc problems
I have the same problem. I got this for a alturnitive montiore for my computer and it has been nothing but problems. And I have the same video card as you. I guess Im out 700 bucks. makes a nice paper weight.
May 23, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
