Question about Lexmark T654DN MONO LASER PRINTER
We have Lexmark T654dn which is assigned IP and connect into network. How do I connect the this nerwork printer from Client Machine.
    Problem Solver:
  • 5 Answers
Select add a printer in printer, select local printer, create a new port --> pull down menu to
standard tcp/ip port, printer name input ip address and it should find the printer, then
select the correct driver and that'sall
Posted on Mar 24, 2011
Printer offline and not printing
Since this is a network printer there are a few potential sources for problems.
  1. IP address conflict. When items on a network are powered on and off sometimes the auto-assigned IP addresses aren't refreshed. The router may think the printer isn't there and re-uses the IP address for a new device on the network, but the printer is still trying to connect with the original IP address.
    1. Log onto your router. See if the printer shows up in the DHCP Client Table of your Local Network - it may have names or just MAC addresses depending on the router. You can print out a test sheet from your printer and see what *it* has as it's IP address and see if that's assigned to something else.
    2. If you do find a conflict, the easiest solution, IMO, is to assign a static IP address to the printer.
  2. Bad cable or hub. Both can go bad and a problem with either will cause the printer to appear to be offline.
    1. Check for lights at both ends of the ethernet cable.
    2. Try a different port in the hub or router
    3. Try a different cable
  3. An recent update corrupted your printer settings.
    1. Uninstall the printer, then reinstall it
Nov 13, 2013 | Brother MFC-7460DN Multifunction Laser...
Connection using ip address for bizhub 350 from desktop
If you want to check the connection from desktop ten follow this.Click on start menu.In run, type cmd and press ENTER.Now in dos mode type ping>space>ip address of machine which you want to check. press enter.If it shows TTL=32 or ttl=64 then it means OK.Your machine is connected with desktop.
Now if you want to put your machine on network and want to assign IP to machine then do these steps1-Connect the network cable to machine.2-Assign an IP to machine.3-To assign the IP, Simply press "Utility/counter" button.4-press "check details" button on LCD panel.5-Now press Admin management.6-Enter password. 123456787-select ADMIN 28-select Network settings.9-Select DHCP.set it to manual instead of auto obtain.10-Now assign the IP in IP address option and after entering correct free ip restart the machine.
Jan 17, 2012 | Minolta bizhub 350 Black and White Copier
Where do i find the ip address for my lexmark z705 printer
This may help.
How do I find IP address of a network printer?
Often times we see a networked printer suddenly stop working and you need to find a static (private) ip address of the printer to diagnose further. How do we find IP address of a networked printer? There are a few different ways to go about finding it.
1. A network printer with built-in ethernet port usually provides a menu button that will allow you to display IP address assigned to it. You may also try printing self test or configuration page from your printer.
2. If you can't find an IP address of a network printer from the menu display or your printer is connected to a printer server with no display, you may find its address from any networked computer configured to use the printer. To find the printer IP address from a Windows machine, perform the following.
  • Start -> Printers and Faxes, or Start -> Control Panel -> Printers and Faxes
  • Right-click the printer name, and left-click Properties
  • Click the Ports tab, and widen the first column which displays IP address of the printers
3. If your networked printer uses DHCP, you may connect to your router and find the IP address of the printer from DHCP status page. The router displays all host machines that are assigned dynamic IP addresses.
4. You may also try pinging your network from a computer connected to the network, and lookup an arp table. On your computer, click [Start] -> [Run...] and type "cmd" and [Enter]. Type "ipconfig" to find your network address. The network address is found by performing a logical AND operation on your IP address and the subnet mask. For example, if you IP is 192.168.1.101 and subnet mask is 255.255.255.0, then the network address is 192.168.1.0. Ping your network using a broadcast address, i.e. "ping 192.168.1.255". After that, perform "arp -a" to determine all the computing devices connected to the network. One of the IP found is your networked printer.
5. You may also use "netstat -r" command to find an IP address of all network routes. However, if your printer has problem communicating with other network devices, you may not be able to find IP address of the printer using "netstat" command.
Thank you for choosing FixYa! have a good one!
Aug 05, 2011 | Lexmark PhotoJet Z705 InkJet Printer
WHAT DOES IP CONFLICT ERROR MESSAGE MEAN ON A DELL 2335 PRINTER
This means that another device on your network has the sames address as your printer, if the address of the printer is fixed / manual then you will need to find out what other device is using the address and restart it.
Mar 10, 2011 | Dell 2335dn Multifunction Laser Printer
I have a Belkin router N300 do I just plug in the printer Lexmark cable to the router and that is it.
To make my Lexmark e250DN work on the network using my new Belkin N300, I had to do this:
1. Install router as per Belkin instructions. 2. Power off printer, then connect Lexmark printer to the router. Power on printer. 3. In a Browser, go to 192.168.2.1 which is the Router's IP address. 4. Click on DHCP Client List. You will see a list of the "computers" connected to the router, which includes the printer. Your printer will have a very long alphanumeric Host Name (mine began with E00000) Note the IP address (something like 192.168.2.4) That is the printer's IP address. 5. In Control Panel, Printers & Faxes, a) if the printer was previously installed with a different router, edit its settings to use the new IP address; b) if the printer was not previously installed, ADD a Network Printer at address http://192.168.2.x (x being whatever your DHCP client list showed).
That should do it.
Jun 25, 2010 | Belkin (F5D7230-4) Router (587009)
Wireless printer gets ip address different from my routers ip add
Check on the wireless network the printer is connecting to. Make sure it is your router.
Feb 03, 2009 | Lexmark X4650 InkJet Printer
Need set up Lexmark C534n to our office network.
Does the printer have an IP already assigned to it?
Print out a network settings page:
Printing a network setup page
If the printer is attached to a network, print a network setup page to verify the network connection. This page also
provides important information that aids network printing configuration.
1 Make sure the printer is on and Ready appears.
2 From the control panel, press .
3 Press until Reports appears, and then press .
4 Press until Network Setup Page appears, and then press .
After the network setup page prints, Ready appears.
Note: If an optional internal print server is installed, Print Network <x> Setup Page appears.
5 Check the first section on the network setup page, and confirm that Status is “Connected.”
If Status is “Not Connected,” the LAN drop may not be active, or the network cable may be malfunctioning.
If that is an IP not on your network, then you need to change that IP to an unassigned IP that is on your network.
You can do that by typing in the IP of the printer into a web browser (example: Http://ipaddress)
Then you should be able to modify the IP address from here.
Once the printer is on your network, make sure you have drivers for it installed and then just map any worksttaion to it.
Dec 11, 2008 | Lexmark Office Equipment & Supplies
Lexmark T654DN MONO LASER PRINTER Logo
268 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
