Question about Samsung SyncMaster 940MW 19" LCD Monitor
Smasung model la32c630k1mxrd takes 5 minutes for the picture to clear up, then crystal clear until i turn off. Then need to wait 5 mins again for the picture to come right. powersupply fault??
  • 11,361 Answers
Power supply is always the first palce to check, unstable DC can cause a lot of problem. You can have problem in the T-CON or the main board itself. You may have to use the cold spray for electronics troubleshooting to locate the bad component.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Mar 22, 2011
Shredder jammed now will not turn on
If it is run for more than 4-5 minutes the motor cuts out. You have to wait until it cools down - maybe 15 mins. Then run in reverse to clear
Apr 06, 2014 | Fellowes Office Equipment & Supplies
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
Error code 501 solution
To clear error 5100 clean the surface of the copper contact of the ink cartridges with a moistened cloth and let it air dry. Fix the cartridges to the holder and return properly the cover of the printer.
These 2 reset procedures will help you clear the errors displaying in the control panel of the printer and let you print again.
To clear U053, U051 and U052
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
To clear error U162 or U163
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
Aug 10, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Chevy cavalier wont start randomly! makes one click and a humm sound my lights come on the radio comes on but the car just wont start, ive had battery replaced along with the ignition switch, fuel pump,...
Ok then, from your description and the
make/model/year of the car you have there,
it appears you've reset the VATS.
The car's security immobilizer
reader at the key switch
does not recognize the coded
chip in the ignition key any longer.
You can try to put the key
in the ignition, turn to the on position &
wait at least 10 min like that.
(Do not turn off the key switch before
10 minutes as elapsed!)
Once done, the key is re-programmed and
should allow the fuel injectors to work again.
The car would start now if corrected.
In some cases, the VATS (GM'S VEHICLE ANTI THEFT SYSTEM)
will re learn the code this way, and will then
allow the restart, however if this does not work,
then you can simply tow it to any GM vehicle dealer
to have the service department re code it.
There is a permanent solution though.
Adding the PLJX Self learning Bypass module (59.95)
will bypass the PASSLOCK system in your vehicle
for good. See this at www.PASSLOCK2.com
Good luck I hope method 1 does the trick!
Here is the 30 min relearn:
Ignition keys relearn takes about 30 min to do. 30-Minute Learn Procedure 1. Turn ON the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON; the vehicle will not start. 3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF. 4. Turn OFF the ignition switch, and wait 5 seconds. 5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password. 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles. Without a scan tool you may have momentary starter interruptions while history clears itself.
Dec 22, 2009 | 2003 Chevrolet Cavalier
My LC-26sh12u takes 10 minutes to
I had a similar problem where it displays "PLEASE WAIT" for several seconds alternating with blocky colors for several seconds and continuing anywhere from 5 to 30 minutes.
I inferred from a couple of sources that the TV is booting up when it says "please wait" by reading data from flash memory. I was able to fix my problem by resetting the data in memory to factory default values using this procedure from the service manual (wait until the TV is working before trying this):
Turn on the POWER.
Set the VOLUME to minimum.
Press both VOL. DOWN button on the set and Channel button (1) on the remote control for more than 2 seconds.
After the finishing of the initializing of shipping, the unit will turn off automatically
Nov 21, 2009 | Sharp Televison & Video
RCA 24V414T KEEPS TURNING OFF tv works great,channels, color, remote control etc just turns on about 5 mins and then shut down, again 2 minutes off, and then turns on back again, sometimes work all the...
it could be a ghost but most likely a bad solder connection , crystal(controls the eprom)(menu chip) , or the eprom chip itself will need to be replaced
Dec 01, 2008 | Televison & Video
Tissot t touch
there are sync instruction on the manual page on the web.
http://www.tissot.ch/data/usersmanual/138-en.pdf
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
Jan 12, 2008 | Tissot T-Touch T33159851 Wrist Watch
TV picture goes out
The tv is shutting down because of a power problem. It could be the power transformer or a color gun overheating. Expect at least a couple of hundred dollars to fix it. Some shops will do house calls for around $65 and can diagnose the problem and give you an estimate. Usually they can just remove the board, take it to the shop and repair it, then reinstall it.
Nov 03, 2007 | Televison & Video
Samsung SyncMaster 940MW 19" LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
