Question about McCulloch MC1275 Steam Vacuum
Mcculloch chainsaw 2416
Chainsaw will not idle once running
how do i adjust the idle speed
  • 32 Answers
All you have to do is call 1-800-521-8559 and select U.S. then select the parts department, have your model number ready and ask them for a PDF of the owners user manual to be emailed to you, they will normally be sent in 1 hour for free.
Posted on Feb 19, 2009
Try turning in the idle adjustment screw a little at a time until you get the saw to idle but not move your chain.your manual or an online manual for your saw should show where the idle screw is located.
Posted on Sep 18, 2008
  • 876 Answers
Here is a free site that provides instructions for fine tuning your idle and mixture to get your engine running and idling smoothly:
http://en.allexperts.com/q/Small-Engines-Lawn-1746/2-cycle-engine-tuning.htm
I hope that youy find the help you need here. If you do not please let us know and we will further research your problem.
Thank you for using Fix YA and please rate this solution. Have a great day!
Posted on Aug 21, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 21, 2008
    Here is a site where you can download a manual for Mcculloch Chainsaws: When you get to this site a video will be loading, however such open the tab above it marked download and right click on the type you want (I prefer txt) now click on "save target as" to begin the download. Eventually it hsould as you where to save it and you can wither save it to the Desktop or to a folder anywhere on your hard drive. (C). I just thought this might be good for you to have.
    http://www.scribd.com/doc/3097717/CHAINS...
  • 797 Answers
Most chainsaws I have used and fixed have three adjustments.
One adjusts the speed the saw will idle at, communally called an idle screw. You adjust this screw for the speed at idle.
Another screw will adjust the air.
One more will adjust the gas.
All saws may not have these last two screws, and may only have one for the air/fuel mixture.
I would suggest that you use the users manual then find the correct settings and where the screws are located.
The engine may not idle smoothly if the two adjustments which affect the air/gas mixture are not correctly set. This will depend on the way the gas/oil has been mixed as well.
If the engine will not idle correctly and the engine continues to run roughly or will not idle at all, then you may have to have the carburetor repaired. If the float is faulty, such as a hole, dirty, or the float shutoff pin is sticking, then repair needs to be done.
You can usually find repair kits for these at repair shops which carry parts for these saws and other small engines as well.
Another thing which is common is water in the gas causing rough idle or the engine not running at all.
Water can get in gas from cans sitting or the saw in an area which can have rain or temperature changes which can cause water from humidity build-up in the tank.
Posted on Dec 05, 2008
Plainer won't adjust up and down
Wood chips are probably jamming the height adjustment, and need to be cleaned out. Lubricate the machine once it's clean.
Feb 01, 2014 | Dewalt DW735 13-Inch Two Speed Thickness...
Is there a source to find out how to use the attachments for the McCulloch steamer?
Hi winnons2...
The only thing I could find on McCulloch is a phone number.
I am sure once you reach this number they would be able to help you farther.
To receive a user manual or parts.
You need to call 1-800-521-8559, ask for guidance to help with obtaining a USER manual and it will tell you where the parts go and what their name is and what you will use is for.
Ask for a PDF Manual, you will need the model number of the Steam Vacuum
They will email it to you for free
Please take time to rate me
Sep 11, 2011 | McCulloch MC1275 Steam Vacuum
Snowblower when running it backfires nonstop
THE MOST LOGICAL CAUSE IS THE CARBURATOR NEEDS REBUILT. IT IS DIRTY AND RESTRICTING FUEL AND AIR FLOW. HAVE A GOOD DAY! it may even be as simple as a new spark plug. try turning the fuel adjustment on carb, all the way in and back it out 1-1/2 turns. the idle screw should be screwed all the way in and backed out 1 turn. if it has a screw on bottom of float bowl or carb, it is the high speed jet, try adjusting it, in or out.
Nov 27, 2010 | Craftsman Vacuums
I have a McCulloch Model PM 310 , Gas Chainsaw. How would the spark plug be accessed?....Rich
Storing a chain saw for longer than 30 days requires storage maintenance. Unless the storage instructions are followed, fuel remaining in the carburetor will evaporate, leaving gum-like deposits. This could lead to difficult starting and result in costly repairs. Never store a chain saw for longer than 30 days without performing the following procedures:
Remove the fuel tank cap slowly to release any pressure in tank. Carefullydrain the fuel tank.Start the engine and let it run until the unit stops to remove fuel from carburetor. Allow the engine to cool (approximately 5 minutes).
Using a spark plug wrench, remove the spark plug.
Pour 1 teaspoon of clean 2-cycle oil into the combustion chamber. Pull starter rope slowly several times to coat internal components. Replace spark plug.
Store the unit in a dry place and away from possible sources of ignition such as a furnace, gas hot water heater, gas dryer,etc. When removing the unit from storage, be sure to perform the following procedures:Remove spark plug. Pull starter rope briskly to clear excess oil from combustion chamber.Clean and gap spark plug or install a new spark plug with proper gap.Prepare unit for operation.Fill fuel tank with proper fuel/oil mixture.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 15, 2009 | McCulloch MC1275 Steam Vacuum
My eager ****** chain saw will not stay running ?
The 3 adjustment screws are Idle, high and low.
First figure out which screws are which adjustment. Tighten the screws then turn them 1 full turn.
Then start the saw and get it warmed up. Work on the high adjustment. This does take a little while. after you get the saw running at high speed work on the low speed.
Apr 25, 2009 | McCulloch MC1275 Steam Vacuum
Parts for Mcculloch MC 1275 steam cleaner
You can find your parts on amazon. take a look here Amazon com Mcculloch MC 1275 parts. I hope this was helpful. cheers
Nov 15, 2008 | McCulloch MC1275 Steam Vacuum
Mc Culloch chain saw
You will need a parts breakdown and exploded views to start with as well as a manual , All you have to do is call 1-800-521-8559 and select U.S. then select the parts department, have your model number ready and ask them for a PDF of the owners user manual to be emailed to you, they will normally be sent in 1 hour for free.
After that is done then you can see the fuel filter and line inside the tank you will need to replace, take your printed views and manual to the nearby lawn mower shop and they will help you get the parts you need even if the original ones are not available. blow out the carb with chemtool and install the parts, use NEW GAS, NEW OIL and from that day forward never leave fuel in a unit for more than 3 months. Good Luck...
Aug 18, 2008 | McCulloch MC1275 Steam Vacuum
McCulloch Steam Cleaner Problem
does your motor run if not there is a service switch to the motor inside the unit that has to be adjusted
May 16, 2008 | McCulloch MC1275 Steam Vacuum
McCulloch Chain Saw Manual
Found all the mcculloch manuals you could ever want on mcculloch product information site. Its run by mcculloch an you put the product weather chainsaw or strimmer whatever an the type in the next collum an press download then print it off all very easy. My manual was in german so made up i found stumbled on this.
Jan 14, 2008 | McCulloch MC1275 Steam Vacuum
McCulloch MC1275 Steam Vacuum Logo
1,398 people viewed this question
Top McCulloch Vacuums Experts
Bill Boyd
Terry Weaver
Terry Weaver
Are you a McCulloch Vacuum Expert? Answer questions, earn points and help others
