Question about Bosch WFMC 2100 Front Load Washer
The door fell off of my washer and it is broken on the white plastic part of the door that holds it to the hinges. What can I do to fix it?
2 Suggested Answers
  • 6277 Answers
SOURCE: Door Fell Off and broke off the hinges Not the
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number. You could also try the Bosch site direct.
Good luck,
John C
Posted on Mar 21, 2011
Dyson 35 fell over and the trap door that opens to let you empty the dust fell off .
Very hot water to soften it a little. Put the one part in at an angle and then move it to level as the pegs drop in.
Nov 20, 2016 | Refrigerators
Door Fell Off and broke off the hinges Not the hinge itself but the white plastic part of the door that attaches to them How can I fix it
Spares Suppliers
Good luck,
John C
Mar 21, 2011 | Bosch WFMC2100UC Nexxt Essence Washer
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
My petrol flap fell off, one of the lugs on the
you can get a new hinge for the gas door at the dealership use a small punch in the center of the plastic rivet tap with a hammer the center will come out after attaching to fuel door the center of rivets are sticking out use 1/4 inch extension tap with hamer until flush and voila
Aug 06, 2009 | Volvo XC70 Cars & Trucks
Ice in bucket freezes into a lump, mechanism freezes
it sounds like the ice chute door is stuck open. on this model it can slip off the "hinge pin" or the plastic that holds the pin can break. if the flap is broken it is replacable. the pin can be put back in. if the plastic that holds the pin is broken, you need to replace the whole door. expect to wait 6-8 weeks for a new door, sooner if lucky. cost is $400 +++ more for stainless.I hope the pin fell out. hope this helps
Jun 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Door hinges broken and door fell off
yeah very easy and it should only cost at most about £10 undue the old hinge with the 2screws now the door will have two little covers that held the old hinge in place take these out and make sure u get the broken pieces out of them once u have the new 1 put it on the washer and screw down first and then place the covers on the ends of the hinges and put the door in place now redue the screws on the door
Jun 01, 2008 | Candy CN146 Front Load Washer
Washing machine door hinge
I cant find much on this unit. the back can be remove but will likely not help you .
remove the top access panel ,
remove the front control switch panel.
then you can remove the whole front door and all.
its really not that hard just be careful of the plastic items.
Feb 27, 2008 | Creda W100FW Front Load Washer
Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Open Questions:
Bosch WFMC 2100 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
