Question about Maytag Dryers
We have a westinghouse ld505e clothes dryer that runs ok, but does not heat. is there any kind of thermostat reset....or any other ideas?
    Problem Solver:
  • 6 Answers
Take off the big rear cover, and access the heating element, two screws. Disconnect and take it out. On this you will see two small thermostats, small black units connected by wires. Test these with a multimeter with the leads off. The ohm meter should show zero. There are two of them, if one is blown, ie doesnt read zero or continuity, then replace both of them. Search dryer thermostats white (dot) on ebay, about $18 for both from the UK. drill out the rivets and replace. Make sure you replace both even if one is blown as they work off each other, one 120 and one 140 I think.
Posted on Feb 01, 2013
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: westinghouse ld505e clothes dryer runs
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Apr 12, 2011
How do you start a Westinghouse dryer Ld505E sensor dryer
if their is no start button push in on the main timer knob on some dryers
Dec 30, 2016 | Westinghouse Dryers
I have a Westinghouse Sensordry LD505E Dryer which has suddenly stopped heating up
Either your dryer vent is clogged or your heating element / ignition coil has failed. It's called a hot surface igniter
May 19, 2014 | Heating & Cooling
My Westinghouse LD505e suddenly stopped working during a drying cycle and it won't start. Would anyone be kind enough to guess what could be the problem and advise a solution. It's 4years old
Probably a blown fuse due to a heater element problem or maybe a bearing problem. I recently worked on one and did a movie which shows the fuse location and all:
More here
Oct 21, 2012 | White-Westinghouse Dryers
Westinghouse dryer ld505e on/off button wont stay on when l push it
If it has dampness sensor strips inside the machine they may be coated with dryer sheet wax or some other mess. Clean them with windex and retry. As the clothes rub against these sensors the dampness causes the dryness board to keep the machine a going. if no dampness is detected the dryer shuts down. Supposely to save power.
Jun 18, 2012 | Westinghouse Dryers
User Manual Westinghouse LD505E
go to www. fitness.manualsonline.com or www. retrevo.com or www. manualsfactory.com
God bless you
Jun 03, 2012 | Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
Westinghouse ld505e clothes dryer runs ok but know heat so whats the problem.
Check your Wiring
wire is attached.
Apr 12, 2011 | Maytag Dryers
Westinghouse ld505e lights up for will not start
Try opening the door, spin the drum by hand, then qi\uickly close& press start. If this works, then the capacitor has failed. About $30, easy to replace.
Apr 02, 2009 | Dryers
Dryers Logo
144 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
