Canon dc2018 fax machine - error code c6400 - Office Equipment & Supplies
  • emoving Mar 24, 2011
    Thank you, the solution was very helpful and I now can continue to fax !!!!!
  • 3,530 Answers
Welcome to Fixya
C6400 Zero-cross signal error means:
While fuser heater ON/OFF control is performed, the zero-cross signal is not input within 3 s.
Try this troubleshooting procedure.
Turn off the machine. Open top toner cover. Turn machine back on. When you see message "close top cover" press "system menu" button. Scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time. Then scroll down to "maint mode"
press "enter" then enter 163 press" enter " turn off machine then turn back on and close toner cover.
Thank you for using Fixya!
Posted on Mar 22, 2011
How can I fix the error c6400 on kyocera taskalfa 221?
Hi
I found this explanation of your error, although my understanding of it is not entirely clear.
Code: C6400
Description: Zero-cross signal error
Interrupt of the zero-cross signal does not occur more than 1 s.
Causes: Poor contact in the connector terminals.
Defective power source PWB.
Defective engine PWB
You can find this here:
Error Codes Kyocera Mita TASKalfa 221 Code C6400
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 17, 2014 | Kyocera Office Equipment & Supplies
ADD TONER ERROR
Good day, if your error is toner then make sure the small white gears on the back of the toner cartridge is turning, if they are not then replace toner bottle, if they are turning ask a technician to test the toner motor. If your machine displays error C6400 then enter service mode by pressing 10871087, now press 163 and OK, now restart your machine, if the code is still there then you should replace your fuser/fixing unit.
Apr 03, 2014 | Kyocera TASKalfa 180 Copier
What is Canon error code #085
#085 mean your fax was sending a colour document to a machine that cannot print in colour!
Jan 13, 2014 | Canon Office Equipment & Supplies
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
C6400 error code km1635
you have a fuser problem, burnt out heater lamp needs to be replaced. call service representative for parts
Mar 17, 2009 | Office Equipment & Supplies
Error code e100 on canon laser fax L100
E100 means that you have laser trouble, probably laser pcb is bad. Replace it.
But also check the laser shutter.
Jan 30, 2009 | Canon FAX-L1000 Plain Paper Laser
Problems with Canon 7500 Laser Class fax
I have Canon 7000 Laser with Error message #330 which said
SET DOCUMENT??? HELP?
Dec 03, 2008 | Canon LaserCLASS 7500 Plain Paper Fax
Error Code for Fax Canon L220
You need to service machine and may be your fixing unit is problem
> If that replace Fixing Unit
Jun 19, 2008 | Canon L220 Plain Paper Laser Fax
57 people viewed this question
k24674
jasbo
jasbo
