Question about Compaq Computers & Internet
My computer boots up to a black screen with a white cursor and that is all. earlier today when i first turned it on, it said it was replacing registry files. it also wont let me do a system recovery. ihave a compaq presario
    Brigadier General:
  • 6,966 Answers
Initially, on powerup, enter the CMOS/BIOS configuration page and manually detect the hard disk. If it could be detected, then most likely for some reason the partition was deleted and you have to re-partition/format/install. If it could not be detected, then a replacement would be required.
In some instances, it could be that the files were so messed up/corrupted and therefore would require re-partition/format/install.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 03, 2008
Dell windows vista has screen with arrow and wont boot
This can happen due to many causes... Because of Virus problem, Hardware Failure etc.
First thing you can do is try to start window in safe mood. to do that you nee to laptop and press F8 button. after this slect open window in Safe mood.
If you are able to start window in safe mood then try to restore your computer to earlier day by going to start-programms-accessories-system tools--system restore.
Now here select the earlier date which is highlited and resote it.
Jul 30, 2012 | Computers & Internet
Windows is not loading have black screen with white cursor then goes to acer and fast out again to white cursor
Hello, doing a "last known good configuration" Works most of the time. Here is how to do it:
1. Make sure your computer is powered down.
2. Turn your computer on and immediately start pressing F8 on your keyboard repeatedly until you see a black screen with white writing that gives you a list of boot options.
3. Use the down arrow on your keyboard to select the Last Known Good Configuration (Advanced) option.
4. Press Enter on your keyboard and cross your fingers.
Good Luck!
Mar 31, 2011 | Acer Computers & Internet
I have an aspire one netbook windows 7 has stopped working after error msg i am left with a black screen and white curser, i know i need to reinstall os so I have bought an external unit to do this but all...
to solve your black screen with just cursor
1. disconnect all (external) devices on your netbook 2. remove battery and adapter then press and hold the power button to drain flea power for about a minute 3. put the battery and adapter back in. 4. power on (as soon as you hit power button tap "F8" key) 5. advance boot options>safe mode (after loading still black screen and just cursor: press alt + ctrl + del then access task manager - new task > run > explorer.exe (should bring up your desktop) 6. access system restore under start > accessories > system tools > system restore 7. restore to an earlier time
to solve your re-installation of OS
1. boot to bios by pressing "F2" or "Del" (depending on your manufacturer) 2. once in bios look for restore defaults 3. save and exit 4. boot options under "F12" highlight media drive press enter and continue pressing enter until you see windows loading screen
Mar 23, 2011 | Computers & Internet
Laptop turns on but screen stays black with a blinking white cursor and wont boot up
Hi. Turn on the computer then keep on tapping the F12 key while computer is starting up. Once you are prompted with the boot menu select the harddrive (ussually the first item) then press enter.
Oct 13, 2010 | Computers & Internet
I have a Toshiba Satellite U505 pc laptop that was working earlier today. I was in the middle of showing a video to a friend when it just shut down. I turned it on again and the Toshiba screen showed up...
If that was a video over the internet you may have downloaded a smart virus. ( ie/ tricks the computer in thinking it is safe ). Shut the computer down and restart it in safe mode. F8 or F11 while it is booting up, ( I could never remember! ). Close all residual tabs/web locations and all other programs. Go to the START icon and restart in normal mode. Me thinks that should do it for you.
ash
Sep 25, 2010 | Toshiba Satellite U505-S2940 Notebook
My guess is that the disk-drive inside the computer has "died".
So, the copy of Windows cannot be read from the disk-drive.
So, all you get is the blinking-cursor.
Take your computer (and the original "System Restore" disks) and your power-adapter to a qualified technician, for trouble-shooting, and probable replacement of the disk-drive, and reinstallation of Windows.
Sep 25, 2010 | Toshiba Computers & Internet
Sony won't finish the start up. Freezes at black
use system restore to restore your computer to a earlier time either you can use the disk that came with the computer or you could do it when you start the computer it should say press so and so buttons to enter the system recovery then use system restore to restore windows to a earlier time so it will start up and boot into windows after you do the system restore
Jul 05, 2009 | Sony VAIO® VGC-LS37E PC Desktop
I am trying to replace the hard drive in my compaq evo n1020v. The problem I am having is that when I turn on the computer, it doesn't seem to be booting from the windows CD. It just sits there and does...
you need to set the jumper setting from your Hard Drive as Master Drive and the CD/DVD player is Slave then go to Bios settings then set 1st boot CD/DVD to boot the windows installer..good luck and have a nice day..
Jun 27, 2009 | Computers & Internet
Computer displays black screen with blinking cursor
Its seems its not booting correctly. Just Insert Windows CD and fix the windows. Another solution is to press (I think) F1 or F11 or F12 (depending on the model) when booting the machine. It will take you to recovery mode. Use it to restore the boot section ONLY.
Mar 06, 2009 | Sony VAIO VGN-CR220E/P Notebook
Computers & Internet Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
