Question about LG 37LC2D Television
I have purchased a 50inch plasma tv which does not have a headphone socket. I wish to use headphones with this tv - can I use the composite audio red and white jacks on the back to plug into a headphone female socket? Is the audio red and white out socket live all the time or do I need to go through remote?
    Scholar:
  • 150 Answers
Hello smiths47 34:
What you will need is a Stereo RCA to stereo 1/8" cable that will connect you to your TV. You can get it at any radio shack or electronics parts store.
You might also like this which is a wireless headphone setup for your TV or phone system.
"CLICK HERE"
If the link doesn't work then copy and past this:
http://www.radioshack.com/product/index.jsp?productId=11300844#tabsetBasic
If this helps then click the thumbs up.
Sincerely, Peter N.
Posted on Mar 22, 2011
How can I listen to headphone on sharp aquos LC-26GA5U
Try to check is the is any Earphone sockets i your tv. If its there you can use headphone to listen to it. If its not there and is there is any audio out put sockets the you can buy a headphone amplifier and use it in between headphone and that audio output connector.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 31, 2016 | Sharp Televison & Video
How do I get headphones to work on my tv
Faulty headphone socket. If anybody have serviced this set before; might have short circuited the internal contacts of the headphone socket. You have to replace the socket. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 28, 2014 | Televison & Video
How do I hook up headphones to panasonic TV?
If there is a socket at the front panel of the TV; marked as 'headphone'; you can insert the headphone pin into it; and can listen the audio by it.
Jan 25, 2014 | Panasonic 50in Plasma Hd Display 3d Lcd...
Where can I purchase the Audio Video Connection for my dvd player I want to hook it up to my TV but can't find the correct cable Thank you Sandy
For the COBY TF-DVD7500, the video is carried on a single RCA plug cable. You can make due with a composite video cable (with three RCA plugs on each end) or get an RCA cable. The audio output can either be digital audio (which uses a special coax cable) or a headphone connector (analog audio).I believe the headphone jack is a 3.5 mm connector. If you use a composite video cable to your TV, you can connect the red and white plugs to an adapter (3.5 mm M to 2 RCA F). Then the TV speakers will get the audio track; otherwise you can use the DVD player speakers or the digital audio out.
I hope this helps.
Jan 24, 2011 | Coby TF-DVD7500 Portable DVD Player with...
Whereis the headphone socket in panasonic viera th-42pz85u?
hi,
ur tv doesn't have a headphone connection. it only have an RCA audio out. if u wish to use head phone with ur tv, then bought a head phone amplifier and connect it to the audio output of ur tv.
ok
Dec 17, 2010 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
I just cooect headphone to VizioP50 HDTV & can't hear anything. is there some step I must do on the remote? Can't seems to find anything about this on the manuel.
You have to check if the headphone is functional and try inserting it 4 times to clear the headphone socket from any obstruction. When the headphone is inserted to the socket there must be no audio output in the speaker of the tv set.
Nov 04, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Innovage wireless headphones/how to connect to TV?
I have a plasma, and found when I plugged my HDR65 to back of the plasma audio out, it worked fine. does this help?
Jan 06, 2009 | Audio Players & Recorders
WHERE TO PLUG IN HEADPHONES
I GOT IT FREE FROM LG TECH SUPPORT. NOT $19.99, OR 29.99 FREE!!!!!
Feb 17, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
314 people viewed this question
