Question about Weber Q200
Can i get a replacement switch for the ignition weber 200 switch will not ignite the gas there is no spark coming from the switch
  • 47 Answers
First, you want to make sure the end of the piezoelectric switch is close to enough to something metal to spark. Maybe it got displaced when you cleaned the bbq?
If it is close enough to arc, but doesn't spark, you can replace the switch with this kit here:
http://www.grillparts.com/weber/Q200.asp?product_id=QSPARK
Good luck, and if this helped, please rate my response! Thanks!
Posted on Mar 22, 2011
Why won't my weber q grill light
Check to see that wire from igniter switch is connected to the igniter itself. If it is check to see that there's a spark from the night. If there is a spark but still low flame ignition try adjusting the igniter so the spark is closer to the burner. Most likely, the igniter is no longer any good.
Jul 27, 2014 | Weber Grilling
I have a 3week old Webber Q220 bbq and it does not ignite - Plenty of gas but igniter does not work - what to do please?
If it's no longer sparking, then it sounds like your igniter battery is dead. Unscrew the igniter button and replace the battery.
Jan 01, 2014 | Weber Genesis Gold B Grill
3 burner - front and rear ignite,middle does not. Replaced all 3 burners. Still does not light. Suggestions?
It might be an igniter problem. It might be a problem with the gas tank (either empty or not releasing the gas). It could be a problem with the control valves or even with a safety mechanism that prevents relighting the grill after multiple tries because of a possible gas build-up. Make sure the gas tank is full and releasing gas - you should be able to hear a hissing noise in the burner compartment. If you can hear the noise then you need to check the igniter and make sure you are getting a spark, and that the spark is reaching the burner. If you can't hear a noise then either the control valves are the problem or the safety mechanism is operating. You can also call Weber and they are pretty good at helping you figure out the problem.
Jul 23, 2011 | Weber Genesis Silver A Grill
Replacing the crossover ignition system in my weber genesis silver b grill. it has a propane tank. the small metal cover over the spark ignitor has rusted out.
What you're referring to is called a Collection Box. It traps gas so it will ignite. You can purchase a new one directly from Weber or from Appliance Factory Parts http://www.appliancefactoryparts.com/
Hope this helps you get the part you need. Happy Grilling!!
May 19, 2011 | Weber Genesis Silver B Grill
Weber genesis gas grill. Battery lighter not working. Any tips?
You can try using a light sandpaper to polish the tip of the igniter where it comes close to the burner. There should be an 1/8th in gap between the tip and the burner. If you try it WITH THE GAS SHUT OFF and see a spark then you may need to just adjust the gap. This is an easy to replace part if it original spark lighter isn't working at all. I have seen Weber lighters at Lowe's hardware stores.
Mar 06, 2011 | Garden
The electronic ignition on my grill no longer sparks to ignite the gas. I replaced the battery and cleaned the contact points but there was not any improvement. Can the entire assembly be replaced?
Yes you can replace the entire assembly.
However you can try adjusting the spark gap to see if this will resolve the issue.
Heat will often expand the spark gap thus rendering a spark impossible.
Small adjustments and be careful not to break the ceramic insulator.
Many gas grills use a static ignitor that does not require a battery.
Big red button you push that causes a snapping noise. This makes a spark and lights the gas. These can last quite a long time and inexpensive too.
Oct 03, 2009 | Weber Genesis Silver C Grill
How to replace ignition switch
where does the ignitor switch plug into ? genesis ....came unpluged
May 21, 2009 | Weber Genesis Silver B Grill
Weber q 200 all of a sudden won't ignite- just clicks away
Most ignitors work of a battery which makes it spark. find the battery and replace it
Apr 20, 2009 | Weber Q Grill
Weber Summit Grill Igniters
I contacted Weber and they sent me a complete igniter system. I will have to install it.
Oct 06, 2008 | Weber Genesis Gold B Grill
Grilling Logo
252 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
