Question about Microwave Ovens
Hi There How do I change a light globe in my Ilve rangehood? Also the fan only works on one speed, can I fix this?
2 Suggested Answers
SOURCE: parex beta 90 ss rangehood
Unfortunately didnt do anything about this for years. Managed to take off the white box behind the front panel swithes. Opened this up and "hey presto" the circuit board is faulty. Wouldnt it be nice if De Longhi sent out another one free of charge as this is obviously faulty, looking at some of the same complaints that have been posted. Imagine all the people that dont use computer or internet. I soldered wire between the points and it worked straight away.
Posted on Oct 13, 2011
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
Parex beta 90 ss rangehood stopped working Lights on switches work but not the fans or lights
Jun 10, 2011 | Microwave Ovens
I have a qasair rangehood (uv-1200-2) with 2 lights. The lights have not worked for a year or so. I have now replaced them (following http://www.qasair.com.au/images/installation_inst/QAIInstr_Lamp.pdf )...
First, turn off power to the rangehood. Check the contact resistance of the light switch(es) with an ohmmeter. It should be less than 0.1 Ohms. If you get a substantially higher resistance in the on position, the switch contact is burned out. Also, inspect the wiring harness connector and the connections to the light fixtures. If they show signs of overheating, the connection resistance is too high. You can try polishing the connector contacts to remove oxidation. I use a pencil eraser for mild cases and a non-metallic dry scouring pad (3M Scotch-Brite) for more severely tarnished contacts. In the worst case it will be necessary to replace the terminals or connector.
According to the drawing for this series on the Qasair website, the unit uses fluorescent lamps rather than the halogen lamps referred to in the lamp installation instructions. If this is true, it is likely the ballast has failed (if the lamps have separate switches, they probably have separate ballasts also). If the original ballast model is no longer available, make sure the replacement has at least as high a maximum temperature rating as the original. This is especially critical for electronic ballasts. You can extend the life of the new ballasts by making sure the fans are running before turning on the lights - this should reduce the ambient operating temperature inside the hood.
May 25, 2011 | Microwave Ovens
Baumatic rangehood bah9005 the switch pushes in and the lights dont work , motor works when electrical switch at wall is on
Thank you for using FixYa. It sounds like there is obviously power getting to the rangehood ( the motor works) and I would suspect that it is just the bulbs that have blown.
Mar 16, 2011 | Microwave Ovens
The blower and the light does not work.
the light is simple take the back of and rplace the globe as for the fan i have looked a t the scematic and i cant see that it runs in line with the globe but it might meaning ounce the globe is fixed the poer will pass through it to the fan if the globe is replaced and the fan does not come on then you have a fault in line to it and it will need further investigation
best of luck happy christmas
please remember to rank my advice
Dec 02, 2010 | Maytag MMV5156AAS Microwave Oven
How to install new light bulb
unlike the older models were there was a small compartment were you could take of a small covering and unscrew / replace the globe they are now a sealed unit if you take the entire top of youl see the globe and black globe holder dont try to unscrew it they dont unscrew if you can order a new globe holder included then simply install as per removal but be carefull microwaves hold a lot of power even when disconnected from power dont touch the capacitor or it will shock you
good luck
please rank me ..
Jul 04, 2010 | Microwave Ovens
I have an Emerson microwave MW8119SB and the light doesn't work inside anymore. I just got it the end of 2008. Other than that it seems to be working ok but a light would be nice so I could see things...
Most microwave ovens are easy to change the light globe.
If you can get the cover off where the light is, you should be able to 'unscrew' the light globe itself.
Then simply go to an appliance repair shop and request a new globe.
Hint: Sometimes you can get a globe from an electrical store.
Jun 17, 2009 | Microwave Ovens
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Light and fan trouble
Fan works when component heat is higher so its normal.
Mar 01, 2008 | Samsung SMH7174BC Microwave Oven
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
