Dirty sludge on washing despite running cleaner through.
  • Mark Davis Mar 22, 2011
    do you use fabric softer?
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 22, 2011
Engine quits running like it runs out of gas?
Many small things can cause this...dirty fuel, water in tank, fuel pressure regulator going bad, air filter clogged, throttle body dirty, clogged catalytic converter. First try fuel injector gas tank and line cleaner...least costly...use 2 bottles of STP concentrated injector cleaner...also add a bottle of liquid heet...to absorb any excess water or sludge in tank...worst cause could be low fuel pressure caused by bad fuel pump...Hope this helps.
May 31, 2014 | 2004 Chevrolet Impala
Lg wd 1049c
There are cleaners you can get at the grocery store in the laundry soap section.
Jan 23, 2014 | Washing Machines
Sometimes the clothes come out of the washer dirtier than when I've put them in! Brown streaks that sort of come of with my finger - sort of like wet dryer lint or sludge. Rewashing takes them away,...
Your washer has too much build up of sludge from excessive use of detergent and fabric softener. You will need to purchase a package of washer machine cleaner from the local hardware store and run the washer on either "clean tub" setting or "sanitary" setting without any clothes in it. Use the cleaner at least once a week for one month and then once a month for maintenance.
Use only 2 tablespoons of detergent per wash.
Good luck
Jun 17, 2011 | LG WM2301HW Front Load Washer
I have an LG washer/dryer combo wm3987h. I had the OE error which I followed instructions on how to fix now my machine comes on but it does nothing despite me picking a cycle. It does not wash, dry or...
OE = Drain error. Cause: not fully drained within 10 minutes
Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Dec 05, 2010 | LG WM-2277HW Front Load Washer
Sludge build up in the agitator caused by the water softener
I use ammonia and hot, hot water to clean the film or sludge from my washing machine.
Add (2) cups of ammonia, set the washer water temp to hot and fill it to high or large/extra large load. Agitate for (5) minutes and let soak over night.
Skim off any sludge that is floating then allow the washer to run through the rinse cycle. Re-rinse a couple of times to clear the system.
Good luck and let me know.
Regards,
Oct 12, 2009 | Speed Queen Washing Machines
Bmw 323 'r' reg e36 engine oil light flashing
your oil pressure switch is a great place to start. since the oil was really thick you could have a horrible oil sludge problem. about 50-100 miles before your next oil change take a bottle of Transmission Fluid and dump in with your oil. and Drive for the remaning 50-100 miles with the Trany fluid still in the oil. The Transmission Fluid is a great Cleaner for sludge.
hope this helped you
Apr 29, 2009 | 1999 BMW 323 Series
Car stalls and turns off at stop light and has to be restarted
Dirty fuel injectors will cause this sort of symptom. Purchase a bottle of Chevron Techron fuel injection cleaner and put it into the fuel tank. If dirty injectors are the problem, this should clear it up in a few days. What is the mileage on this car. Above 60,000 miles, sludge will sometimes cause the idle control motor to stick, which will also cause this problem. If the injector cleaner does not work, remove the idle control motor and clean it with aerosol carburetor cleaner.
Charlie
Jan 16, 2009 | 2007 Chevrolet Aveo 5 Hatchback
Grey sludge on my washing
Hi, I had the same problem.
The waste is blocked, check the drain pipe from the machine and also where it drains out to. (thick sludge)
I ended up unclipping the pipe from the drain motor (Bottom rear) and passing a garden hose throught it to flush it out.
Jan 07, 2009 | Zanussi FJ1254W Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
