Question about ViewSonic PJ503D Projector Lamp
I have a pj 305d projector that won't emit light. The green indicator flashes when pressed for about 1 minute, then goes back to orange. The red bulb light comes on after about one minute. There is no sign of heating or a broken wire on the bulb
  • 255 Answers
You need to replace the bulb for your projector.It would solve your problem for sure.
Posted on Mar 22, 2011
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
PJ-TX100 Projector won´t start up out of Stand-By
Hi Mario
If there is no response on the Projector it normally means that the Mainboard is faulty.
Check if your machine is still under warranty because this quite expensive to replace.
As far as the schematics are concerned - I'm unfortunately not able to help you out with that.
Apr 02, 2008 | Hitachi PJTX100 Multimedia Projector
LG RU-44SZ63D
Hi there
This could possibly be your Ballast ( lamp's powersupply ) that is faulty.
It will either need repair or replacement.
Mar 31, 2008 | LG DLP Projector 1400Lum RD-JT30...
Green light flashing and then shuts down
Hi Gary
Have you resetted the lamp timer ? It must be done when a new lamp is inserted into the unit.
You can reset the lamp timer by holding the up arrow key on the Projector in until a online message appears. Then just follow the on-screen instructions.
If the problem persists , you will have to replace the Ballast wich is the lamp's power supply.
Mar 16, 2008 | BenQ MP610 Multimedia Projector
Problems with keeping the projector on!!
if it is blanking orange:1- if any objects are blocking the air inlet or outlet grille remove them.2- do not expose the air outlet to hot air emitted from heating appliance.3-check whether the filter is clogged with dirt-clean the filter if clogged.
if it is blanking green:-after status indicator stop blanking press power.if you unplug power cord while the fan is rotating the lamp may be not turn on for one minute next time you plug the cord.
press power button several times.
Dec 08, 2007 | Mitsubishi HD4000U Multimedia Projector
Orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Nov 12, 2007 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
ViewSonic PJ503D Projector Lamp Logo
174 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
