Question about HP Color LaserJet 5500 Printer
HI I M KAMRAN I HAVE CLJ5550N PRINTER ERROR ARE COME 59.30 I REPLACE TRANSFER KIT BUT ERROR STILL 59.30
    Champion:
  • HP Expert
  • 202 Answers
Hello ,pls check as describe,
Reconnect the connectors J18 for
the fuser motor and J1101 on the
DC controller PCB. Replace any
damaged parts.
2 Replace the fuser drive assembly.
3 Replace the DC controller PCB.
Calibrate the printer after replacing
the DC controller.
Posted on Mar 22, 2011
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
SERVICE PRINTER ERROR: 934 ON LEXMARK OPTRA S 1620
These error codes indicate a problem with the mirror motor circuit
in the printhead assembly or the mirror motor cable to the engine
board cable or engine board assembly.
The mirror motor cable or engine board would possibly needs to be replaced. Please contact our technical support team for assistance.
Sep 24, 2012 | Lexmark Optra S 1620/1625/1650/1855 Fuser...
Lexmark x502 printer shows tray 1 missing
hi...........
pls do the following :-
Tray Missing: Insert Tray Tray 1 and/or Tray 2 is missing. Insert the specified tray(s) into the printer. TR Belt Life: Replace Transfer Belt The transfer belt is exhausted. Install a new transfer belt. TR Kit Life: Replace PQ Kit The transfer roller and transfer belt cleaning roller are exhausted. Install a new transfer roller and a new transfer belt cleaning roller. TX Comm Error An outgoing fax transmission error has occurred. Resend the fax. Warming up Wait for the message to clear....
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 29, 2011 | Lexmark C532n Color Laser Printer
Hi i have a problem with printer hp color laserjet 3500.my printer is error sms "printer error 59.99".what is a problem?
An error occurred in the secondary transfer
engaging mechanism.
1. Faulty secondary transfer engagement
sensor. Replace the secondary transfer
engagement sensor.
2. Faulty secondary transfer engaging
solenoid. Replace the secondary transfer
engaging solenoid.
3. Faulty feed motor. Replace the feed
motor.
4. Faulty DC controller PCB
Action: Replace the DC controller PCB.
Feb 23, 2011 | HP Color LaserJet 3500 Printer
Hello there, can u help me?my hp laserjet 3500 gives me 59.99 printer error.i junst replaced a new transfer kit. but still not working
The manual states:
59.99.00
engaging mechanism.
engagement sensor.
engaging solenoid.
motor.
But experience shows that you should look at the Swing Plate assembly. If the gear on it is skipping, it will cause these errors. It is located in the back left under the fuser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 26, 2011 | HP Color LaserJet 3500 Printer
I am facing error code C7=10, and f5=02 please tell me what can i do for removing those error code. i am waiting your positive reply kamran form pakistan.
The F5 normally means your lamp is bad. Or the CCD assembly Behind it. At any rate you would have to replace the lamp carriage assembly.
Aug 17, 2010 | Sharp AR-M160 Black and White Copier
I have replace a transfer kit but the printer show error 59.99 printer error HP LJ3700
That error is a secondary transfer engaging mechanism error. Usually I find that to be an issue with the image drive assembly in which it would need to be replaced, or something broken on the inner or outer right side of the printer "usually plastic" preventing engagement or disengagement.
Jul 23, 2010 | HP LaserJet 3700 Printer
Getting a 80 Maint. Error. Replaced the fuser. How do I reset the paper count?
Go to Config by turning off the printer. Then press and hold Select and Return buttons while turning on the printer. Once in Config Menu, choose Reset Maintenance Count.
NOTE: The error indicates that the printer has already printed 300k pages, worn out transfer and charge rollers. You should've replaced the maintenance kit = fuser, charge roll, transfer roll and pick tires. Otherwise, you'll ge having print quality issues.
Jun 15, 2010 | Lexmark W840 Printer
Getting transfer kit error
I can send you a new transfer kit for 150 € + shipping cost.
comercial@ofiexpertos.com
Feb 19, 2010 | Tektronix Phaser 750N Laser Printer
"replace transfer kit" for Konica KL-3015
Hi Hexus, http://www.kmbs.konicaminolta.us/eprise/main/KMBS/Support_Center/Manuals/Pages/Attachments/3015gs.pdf Download that manual the directions with diagrams for replacing the transfer kit are on page 40 (in the page numbers on the docs themselves, the Acroreader page number is 51) Hope that helps, El Duderino
Nov 21, 2006 | Konica KL-3015 Laser Printer
HP Color LaserJet 5500 Printer Logo
102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
