Had a #2 key fall out complely including the cap,now I want to know how to replace it ( I have the new key complete,hinge and all that stuff) but i don't know how to replace and install it please show me a video that I can print.
    Problem Solver:
  • 12 Answers
Set aside the key and retainer that have fallen off. If you lost the key, retainer, or both, you will have to order a replacement from the computer's manufacturer. As an alternate, you may be able to get a replacement from someone who has a non-working laptop of the same model as your own.Carefully pop off another key from your laptop. Choose one that you don't use frequently, and remove it with care so its retainer stays in the proper place. You will be using it as a model for your repair.
Note how the exposed retainer is connected to the keyboard. It will probably be connected at four separate points. This may vary, based on the make and model of your specific laptop. Study it until you feel confident replacing the retainer in the correct manner. Replace the retainer that popped off your laptop. Once you have it secured in place, pop the missing key onto it. The key should snap firmly into place onto the retainer. Replace the key cap on the retainer that you used as your model. Like the other key, it should snap firmly into place, and both keys should now be ready for use.
Posted on Mar 22, 2011
Dust cover falls down
You'll have to flip your turntable upside down on a pillow or beanbag, remove the feet & all the screws including the harder plastic underside to get to the hinges where by which you can estimate whether there was wear & tear & needs replacing or whether it was a simple fix by just tightening up the screws that hold the hinges in place.
Feb 09, 2014 | Technics Audio Players & Recorders
Missing Hinge, How to fix for Free?
paper clip.... make 2 notchs one in bottom of screen and one in top of computer base. and then fold the paperclip to make it difficult for it to fall back.or..tape it on the back with strong tape when its open the farthest you want. if you wanted it open to 90 degrees youd tape it there on back with duct tape and then when it trys to slide back the tape will be so tight its unable to without force. if this works let me know
Jun 15, 2013 | Dell Inspiron 1525 Laptop
I got problem with key pad of *,5,C, and center joystick button on my sony ericsson k770i...can u help me on how to solve the problem..?? tqvm...
emove sticky tape securing the keyboard cable to back of the keyboard.Part of the keyboard cable is glued to the keyboard. Carefully separate the cable from the keyboard.Start peeling off the aluminum protective film Remove the protective film. After the protective film is removed it's really hard to attach it back to the keyboard because it's deformed.Most laptop keyboards have some kind of plastic separators.
These separators secured on the back of the keyboard.
Plastic pins are melted on the back of the keyboard and retain separators in place.Push all plastic pins though wholes on the keyboard.Start removing the separator.The plastic separator has been removed.
Now you'll have to remove all key caps.
Before you start removing key caps, make a picture or xerocopy of the keyboard so you know the order in which keys are attached to the keyboard.In order to remove the key cap carefully lift it up with your fingers.Remove the key cap so the hinge underneath stays connected to the keyboard.
Some big keys have a different design.
In addition to the hinge, some big keys (Back space or Space bar for example) might have an additional support bracket.Remove the key cap with the support bracket. As you see, the key hinge stays connected to the keyboard.Some laptop keyboards might have blank covers on the left and right sides from the up arrow key.Lift up and remove the blank cover.All keyboard key caps and plastic separators have been removed.Now you can start removing key hinges - key lifting mechanisms.Carefully separate the key hinge from the keyboard.
Each key hinge has two parts - external and internal pieces.
When you remove the hinge, try to keep these parts connected to each other the same way they are connected on the keyboard.If the external and internal pieces got separated, you can assemble them together.If you following this guide to repair the keyboard, I would recommend to keep all hinges in the right order.
The keyboard has two sheets laying one on the top of another.
Remove the sheet with silicone (or rubber) nipples.Remove the second sheet with traces.Both sheets have been separated from the keyboard base.The sheet with traces has two layers and all traces are running between these layers.In order to access and repair traces you'll have to separate to layers from each other.The keyboard has been disassemble.
As you see it's not easy to disassemble a laptop keyboard and even harder to put it back together.
Is it worth repairing? Probably not. These days you can find a new laptop keyboard very cheap.
Oct 17, 2010 | Computers & Internet
How can i repaire my kerboard of aser 5920
Remove sticky tape securing the keyboard cable to back of the keyboard.Part of the keyboard cable is glued to the keyboard. Carefully separate the cable from the keyboard.Start peeling off the aluminum protective film Remove the protective film. After the protective film is removed it's really hard to attach it back to the keyboard because it's deformed.Most laptop keyboards have some kind of plastic separators.
Oct 17, 2010 | Acer Computers & Internet
Need to replace broken key on keybord. plastic appartus on key underside broke
Oct 17, 2010 | HP Pavilion ZD7140US Notebook
1940 9n will not start, have replaced the points, condensor, 12 v coil, wires, new carb and the stark plugs. The only thing happening is gas coming out of the itake from the air cleaner. Also I replaced...
Is it cranking? Is there a spark? If there is no spark. I would look at the points again; unless you mean you replaced them now instead of in the fall. Look at the points and if they look frosted then try sanding them or replace them again. They can go bad quickly if there is moisture in the cap. Recheck the gap. It is possible that you got a bad condensor if the points are good. Check the cap and rotor for corrosion and remove this coorosion or replace them. Check that you have voltage at the coil. It might be a bad ignition switch. If all this is good turn the crank till the points close, turn the key on and check for a spark with the coil wire within a 1/4" of a ground when you open the points with a screwdriver. If it has spark; try spraying a little starting fluid into the carb. Let us know what you find out.
Feb 15, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
N key problems
if a letter of the keypad of your laptop has been popped off, u need to request the key pad which includes the complete panel of the keys including the touch pad. You need to check your warranty and get it replaced.
Jun 20, 2009 | Computers & Internet
Hinges on Pavilion zv5000
Hinges are 2 seperate pieces that are attached to your LCD screen and then attached to the base of your laptop. I wouldn't be surprise that $160 is the repair cost. Hope this includes labour cost cuz its time consuming to open the laptop and take it about just to replace them.
You do this yourself by finding the same hinges on ebay and doing it yourself if you feel comfortable. If not leave it to a computer nerd who know how to.
Aug 21, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Battery compartment cover
They really want you to buy a new camera instead!
TAPE it shut!
Otherwise you can sometimes find equipment sold 'as-is' for parts on eBay or other internet sites.
Do a web-search for it.
Nov 01, 2007 | Fuji FinePix S602 Zoom Digital Camera
Computers & Internet Logo
48 people viewed this question
Alun Cox
David Payne
David Payne
