Question about Transcend 8GB SSD, 2.5- Inch, IDE, SLC Hard Drive
Xp setup can't access my drive - Transcend 8GB SSD, 2.5- Inch, IDE, SLC Hard Drive
  • 4 Answers
set the jumper as per the hard disk . it will shows in hard disk upside.
Posted on Mar 22, 2011
Format hard drive
Hi
To "format C" means to format the the C drive, or the primary partition that Windows or your other operating system is installed on. When you format C, you erase the operating system and other information on the C drive.
However, it's not a straightforward process to format C. You can't format the C drive like you can format another drive in Windows because you're within Windows when you perform the format. To format C from within Windows would be like lifting a chair in the air while sitting on it - you can't do it.
The solution is to format C from outside of Windows, meaning you need a way to format a drive from somewhere other than your Windows installation. The easiest way to do this is to boot to an operating system (with formatting abilities) from a CD/DVD/BD drive, flash drive, or floppy drive.
This might all sound very complicated but it's actually quite easy to format C. Below are 5 completely free ways to format your C drive:
Note: If you're trying to format your C drive because you want to replace or reinstall Windows, you do not need to format C ahead of time. Formatting is done automatically during the Windows installation. Skip this article entirely and instead see How To Clean Install Windows.
Important: Formatting your C drive does not permanently erase the data on the drive. If you want to completely erase the information on the C drive, see Option 5 below, Wipe the Drive Clean With Data Destruction Software.
1. Format C From a Windows Setup Disc
The easiest way to format C is by completing part of a Windows installation. It's not easiest as far as number of steps goes, but since most of us have a Windows Setup DVD lying around, we have easy access to a means to format drives outside of Windows.
Important: You can only format C this way using a Windows 7 Setup disc or a Windows Vista Setup disc.
However, it doesn't at all matter what Windows operating system is on your C drive, including Windows XP. The only requirement is the disc you use to format C - either a Windows 7 or a Windows Vista Setup DVD. Feel free to borrow a friend's disc if you'd like to try this method but you only have Windows XP... or some other operating system.
2. Format C From a System Repair Disc
If you don't have access to a Windows Setup DVD, but you do still have access to a working copy of Windows 7, you can create a System Repair Disc and then boot to that disc and format C from there.
You can only format C using a System Repair Disc if you have access to Windows 7 to create the System Repair Disc. If you don't have access to Windows 7, find someone who does and create the repair disc from their computer.
Note: A System Repair Disc created from Windows 7 can format a C drive that has any Windows operating system on it, including Windows XP or Windows Vista.
3. Format C From Recovery Console
If you have a Windows XP Setup CD, you can format C from the Recovery Console.
The biggest caveat here is that you must also have Windows XP installed on your C drive. However, if you don't have access to Windows 7 or Windows Vista, this option may be your best to format C.
This Recovery Console method to format C also applies to Windows 2000. Recovery Console does not exist in Windows Vista or later, nor does it exist in Windows ME, Windows 98, or earlier.
Dec 14, 2011 | Samsung R580JBB2 Notebook
Have a simpletech portable drive300 gigs-worked fine with windows xp-new computer has windows 7-suddenly cannot access drive anymore-windows 7 sees the drive but says drive is inacessible
Hi ,
This is neo , When did the setup for win XP the file system would be FAT32 . FAT32 is not supported in windows7. You can format the external drive BUT note the files in the drive will be deleted.
Nov 01, 2010 | SimpleTech SimpleDrive 160 GB External USB...
Windows Xp Setup Problem : "setup cannot access the disk". I have HDD: Maxtor Diamondmax Plus 9 80GB ATA/133 HDD.
try doing a F disk on the hard drive first then format it and make it the active drive and then try installing the xp software. if it has had another operating system say for instance windows ME it will not install on that drive without removing it. You can also go to www.maxtor.com and download their free hard drive tools to see if there is a problem that thier software can fix. the software is for free.
Jan 06, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Acer aspire 1 will not load XP
If this a new drive you need to prepare it using a hard drive utility before windows will recognise it. The drive manufacturer may provide this for you. Maxblast is one such program as is Datalifeguard from Western Digital.
May 05, 2009 | Acer Aspire 3000 Notebook
Emachines laptop XP setup cannot access HDD
Hi there.
Now, turn on your friends laptop, and access the BIOS/Setup menu. Have a look through the options, find the one that says something like Boot Virus Protection. Disable it. You can't install any operating system if this is Enabled. Then look for the Boot Priority or Boot Devices option. Change this, so it boots from CD-ROM first. Then try to install XP again.
Let me know if this works.
Apr 10, 2009 | Gateway Computers & Internet
My PC need help
one chance is there for you. just do a repair which HDD drive is detecting win32 missing. just follow these steps.
Please read carefully and make sure you followed the warning links before initiating
the Repair Install. You can print a text version for reference. repair.txt
1. Boot the computer using the XP CD. You may need to change the boot order in the
system BIOS so the CD boots before the hard drive. Check your system documentation
for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup.
do not choose "To repair a Windows XP installation using the Recovery
Console, press R", (you Do Not want to load Recovery Console). I
repeat, do not choose "To repair a Windows XP installation using the
Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows
installations.
5. Select the XP installation you want to repair from the list and press R to start the
repair. If Repair is not one of the options, END setup. After the reboot read
Warning
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any
key to boot from CD when the message appears. Setup will continue as if it
were doing a clean install, but your applications and settings will remain intact.
Apr 05, 2009 | Computers & Internet
My laptop is not switching on
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
  3. Press Enter to start the Windows Setup. note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" border="0" height="21" width="15" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Oct 22, 2008 | Toshiba Computers & Internet
Problem installing windows XP
This is going to be either a bad disc or a bad hard drive. Do a hard drive test in the bios, if any part of it fails, then you will need to replace the hard drive. If the hard drive passes, then try a different operating system disc.
Aug 13, 2008 | Dell Inspiron XPS M140 Notebook
Instructions on how to downgrade aspire 3680 to XP
First, get XP hardware drivers from maufacturer website. Next, you need a Windows XP cd. Then, in the cmos setup (BIOS), set your system up to boot off the CD/DVD drive. Restart system with Windows XP in the the CD/DVD drive to insall.
Apr 01, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3610 laptop - Windows XP error
on a friend's Windows 98 SE or Windows ME computer, create a floppy "Startup disk". Insert in your pc floppy drive and turn on. If floppy drive was not accessed, then get to BIOS and ensure "Boot from floppy drive" is set prior to "boot from hard drive". Once at first screen, select "Boot with CD-ROM driver". Insert CD-ROM and initiate entire re-install of Windows. Windows may do some self-restarting. At first restart do this: get to BIOS and ensure "Boot from hard drive" is set prior to "boot from floppy drive".
Jun 05, 2007 | Acer Aspire 3610 Notebook
Transcend 8GB SSD, 2.5- Inch, IDE, SLC Hard Drive Logo
41 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
