Question about Radio Shack Pro-2055 Base Scanner
Looking remove all stored channels from scanner and start over.
    President:
  • 2,761 Answers
Initializing the scanner will erase all programmed information and return your scanner to its original factory settings. To initialize your scanner:
- Power the scanner OFF.
- Power the scanner ON. "Multi-system Trunking Scanner" appears on the display.
- Press 0 (zero) while the above message is displayed.
- Press 1.
- Press ENT. "Initializing please stand by" appears on the display.
DO NOT power the scanner OFF until the initializing process is complete and the display shows "M000 Bank0 Ch00"
Bill B.
Listening in professionally since the 60's
Posted on Mar 23, 2011
Channelslockedout
Hi Barney,
I take it that you have frequencies programmed into the scanner, so this is the solution to your problem.
On the keyboard of your radio scanner you will find a button marked L/O or L/Out, when your scanner is in scanning mode, press the Mon or Hold button, this will stop it from scanning.
Now select the channel of your programmed frequencies, starting with Channel 1. To do this press Hold followed by 1, if this channel shows a L/O icon on the LCD screen, press the L/O button and the L/O icon should go out. continue through each channel, until you undo the L/O from each channel by following the steps I have described above, once you have removed the L/O icon from all the channels that were locked out you can then press the Scan button and you'll be listening to the frequencies that you programmed into your scanner.
Note: If you have not programmed any frequencies into your radio scanner, then you will not be able to hear anything, as nothing programmed to hear and L/O is the default setting on all channels, until each one is programmed with the frequencies of your choice.
How to Program a frequency?
Press Prog button, select channel to store frequency, E.G:Ch:1 168.5000
Remember to always press the (.) decimal button in the correct place, else you will get ERR message on the LCD, now press Enter button, you now have the first frequency stored in you radio scanner on Channel 1, now press the Delay button, so that it doesn't start scanning for 2-3 seconds after a transmission is received.
Continue with the above setup one channel at a time until you have programmed your radio scanner to your liking.
I hope I have helped you in finding the solution to your query.
Regards,
Peter
Feb 22, 2013 | Radio Shack Pro-2096 Base Scanner
How to program a pro - 135200 channel hand held scanner with out charging me .
  1. 1. Press "MAN."
  2. 2. Press "ENT/PGM" to put the scanner in programming mode. You will see PGM appears.
  3. 3. Use the number keys to enter both the channel storage bank and the channel number you want to assign to a frequency.
  4. 4. Press "MAN."
  5. 5. Use the number keys to enter the frequency and don't forget decimal point.
  6. 6. Press "ENT/PGM" to store the frequency into the channel.
  7. 7. you just stored a frequency into a channel. Repeat steps above until you have your scanner programmed how you want.
  • Hope this helps...
Nov 26, 2011 | Radio Communications
Cant get any frequencies to program
hi select a bank ,Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears. 2. Use the number keys and to enter the frequency (including the decimal point) you want to store. 3. Press E to store the frequency into the channel. Notes: • If you entered an invalid frequency in Step 2, Error appears and the scanner beeps three times. Enter a valid frequency. • The scanner automatically rounds the entered number to the nearest valid frequency. For example, if you enter 151.473 (MHz), your scanner accepts it as 151.475. • When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning
Mar 18, 2011 | Uniden BC72XLT Handheld Scanner
I have a radio shack hyperscan 200 channel pro-2039 programmable scanner. How do I erase ALL the stored frequencies so I can start over again?
You can initialize the scanner to delete all information that you've programmed into it and return it to its original factory settings. To do this:
1. Turn the scanner OFF, then turn it ON again.
2. Press and hold down the CLEAR key and insert a pointed object, such as a paperclip or the point of a pen, into the RESET opening in the back of the scanner, and press the button inside the opening.
3. Release RESET. When information reappears on the scanner's display, release the CLEAR key.
NOTE: You must release the RESET button before releasing the CLEAR key.
Also note that this procedure may not be necessary. Programming a new frequency into a channel automatically deletes the frequency previously stored in that channel.
Bill B
Listening in since the 60's
Oct 05, 2010 | Radio Shack Radio Communications
I cleared my scanner pro-82 now how do i program the channels back. the bank1 is blinking and is on channel 1. i do not have any scan codes for local fd/pd in the 78801 area zip code.
For a comprehensive database of active frequencies in your area (they're really NOT codes), visit:
www.RadioReference.com
To program known frequencies into your scanner,
1. Press PGM. PGM appears. Then enter the channel number (1-200) where you want to store a frequency, then press PGM again.
2. Use the number keys and DELAY/. to enter the frequency (including the decimal point) you want to store.
3. Press ENT to store the frequency into the channel.
Your scanner automatically rounds the entered frequency down to the closest valid frequency. For example, if you enter a frequency of 151.473, your scanner accepts it as 151.470.
Press DELAY/.if you want the scanner to pause 2 seconds on this channel before it proceeds to the next channel after a transmission ends. The scanner also stores this setting in the channel.
To program the next channel in sequence, press PGM and repeat Steps 2 and 3.
Need the full manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
BillB
Jan 19, 2010 | Radio Shack Pro-82 Scanner
How do i program my realistic pro-2025 scanner
PROGRAMMING CHANNELS
1. Turn on your scanner by turning the volume clockwise.
2. The scanner might start scanning. If so, press MANUAL to stop the
scanning.
3. Enter the channel number that you want to program and press MANUAL.
4. Enter a frequency including the decimal point. The decimal point shows
up on the display as a -- (dash).
5. Press Enter to store the frequency.
6. To confirm the proper entry, press REVIEW. The programmed frequency
appears on the display one digit at a time.
7. To program more channels repeat steps 3-4.
Jun 03, 2009 | Radio Communications
Problem setting up bc95 scanner. any help would
Storing Known Frequencies
Into Channels
1. Press Hold. Then enter the channel number
to store.
Hope this helps you.
Apr 16, 2009 | Uniden BC-95 XLT Scanner
Scanning programmed channels
Not exactly. You can program channels however into the Private bank. To do so though you must search for the channel first...This may simply mean going to a channel you already know by using the band button to start searching...Push the hold button to stop it close to the frequency and then use the arrow keys to get to the exact frequency. then push the Prog button. After pushing it, push the Private button (you will see CH next to the frequency) using the arrow keys select the channel you want to store on and push Prog again. To scan the stored channels simply push the private button...Done! It can be a tedious process...expecially with 50 channels....but It's the only way I know how to do it...Good luck!
May 11, 2008 | Uniden BC350C Base Scanner
BC72XLT
Here is the directions to store frequencies in your scanner:
Into Channels
to store.
Notes:
Operation 2 seconds after the end of a transmission before
scanning proceeds to the next channel. To turn
the function off or on, press Func + Dly.
• If you enter a frequency that has already been
entered elsewhere, the scanner sounds an error
tone and displays the channel that was
duplicated. If you entered the frequency by mistake,
press then enter the correct frequency.
To enter the frequency anyway, press E to
accept.
4. To program the next channel in sequence, press
E then repeat Steps 2 and 3.
Dean
Rollin CBs
Feb 19, 2008 | Uniden BC72XLT Handheld Scanner
Reprograming
Hi, looks like page 24 of your manual covers that part.
3. Press ENT to store the frequency into the channel.Your scanner automatically rounds the entered frequency down to the closest valid frequency.For example, if you enter a frequency of 151.473, your scanner accepts it as151.470.
If you need a new manual, you can download it here.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000315_PM_EN.pdf
If your needing new freq's to use, you can go here and click on your state and county and get a list of freq's.
http://www.radioreference.com/apps/db/
I hope this helps you with your question, let us know,, Mechanic
Feb 14, 2008 | Radio Shack Pro-82 Scanner
Radio Shack Pro-2055 Base Scanner Logo
149 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
