Question about LG Washing Machines
Hi I have an LG 3 step Turbodrum washing machine (older mode) . It was fine when I took a load out put another in . It started flashing code PE . I don't have a manual and a company I phone said they could only advised if a technician came around ! Thx
    Brigadier General:
  • 6,277 Answers
Manual first!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Now 'PE'. That stands for pressure error and one symptom of a blocked drain filter. Try the following-
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 22, 2011
  • anne975 Mar 23, 2011
    Hi Retied Engishman in SW France .
    Thanks for the advice. I tried but besides finding part of a clip and a safety pin the problem still persists . I tried a couple of other things after speaking to the agents but obviously I am too "Blond "
    Will now go to plan B & C and ask for real time help .
    Regards and Keep well
    Anne
  • john_cross Mar 23, 2011
    Good luck! PS my wife and daughter are both blonde!
    J
I have a lg top loading machine model no. WF-T851 with a bE fault. What is this and how is it fixed.
There was a similar question that was resolved a few years back, perhaps it may help. Here is the link:
LG 3 turbodrum wf t851 bE error code
Jan 30, 2017 | LG Washing Machines
Users manual
The LG Canada website has it.
http://ca.lgservice.com/index_b2c.jsp
Click on "Owner's Manuals" on the left hand menu and fill in the details, model number WF-T8016TP. You'll need IE, not Firefox...
Jan 24, 2009 | LG WFT1071TP Top Load Washer
Lg turbodrum top load washing machine, just keeps filling with water, does not start the washing cycle! HELP
would ithe washer over flow if you didnt intervine.if so your presure switch hose has a hole in it.may be a mouse.happens all the time
Dec 31, 2008 | Washing Machines
Oily substance
most common is lint build up. a good hot wash with a good bleach...check your manual for manufacturer's recomendation. There's various products available..bleach is the most in-expensive and works well. make sure its set on high water level...pause machine for 10-20mins...let me know how you get on
Jan 03, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
157 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
