Question about Acer PD726W Projector
We have a acer PD726 projector. We have replaced the bulb but now have white vertical lines appearing both when the projector starts up and when attached to a computer.
    New Friend:
The ballast may not be sitting in its guides properly. May want to recheck.
Posted on Nov 20, 2013
SOURCE: bulb replacement
u have to reset the lamp timer.
There is an menu entry to do that.
Thomas
Posted on Mar 21, 2008
Marrie
  • 563 Answers
SOURCE: White vertical line in the center of projected image
Hi there
This is a common Mainboard problem on Projectors.
The only way to get rid of it would be to replace the Mainboard or have it repaired.
Must warn you that it could turn out to be a expensive exercise !
Posted on Mar 26, 2008
SOURCE: White vertical line on left side of screen
omg, I just figured out why OUR projector was doing this! There was an adaptor plugged into it that we use to hook it up to cable to watch games/tv shows sometimes...once I unplugged that from the projector the lines dissapeared!
Posted on Oct 02, 2008
Marrie
  • 563 Answers
SOURCE: Thin vertical line appears on projector
Hi Martin103
This is a typical BenQ Mp Series problem , and will notice that it will start of intermittently , but later on the white line will appear every single time.
This can only be fixed by replacing the Mainboard of the MP710/720/721
Posted on Dec 12, 2008
  • 8 Answers
SOURCE: Vertical lines on projected image from a Dell Data Projector. White vertical lines are appearing at even spacing across the width of the image projected. At a loss to how to fix this. Any ideas as to
that is due to lcd filter units , try to align, precision work
Posted on May 25, 2009
There is a white vertical lines appearing every time we open Acer X1130P DLP Projector
means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD120
Nov 20, 2013 | Acer X1130P 3D Ready DLP Projector...
I plugged in the acer dlp and it came out a white vertical lines in the display,is it at the bulb? or is it in the settings?
this sounds like the DMD board on the light engine not working properly. It's not something that can be fixed in the settings, but it is a hardware failure. light engines are usually very costly to repair. if the projector is still under warranty have it serviced by Acer.
May 27, 2011 | Acer X1130P 3D Ready DLP Projector...
We have an ACER PB726 projector. We have replaced the bulb but there are vertical white lines showing on the screen both before a computer is connected and once the computer is connected.
try to go to BIOS then check if you can still see the vertical lines..if you can still see those lines most likely there some damaged on the screen..you may wanna call your manufacturer to check the service for your pc
Mar 21, 2011 | Acer Computers & Internet
Vertical line white, regular, blinking.
I don't think it's the bulb. Sounds like an LCD panel issue. Maybe one or more of the 3 LCD panels is either not working right or the unit has been dropped/jarred and the panels have moved (All three have to line up right optically to give the right colours). You need to take the projector to a qualified service centre.
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Apr 01, 2009 | Acer Projector Lamp for PD110, PD110z
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
Acer PD726W Projector Logo
252 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
