Question about Panasonic CQ-DPX151U CD Player
Where do I connect the yellow Continuous 12v DC and does it require a 5amp fuse?
  • 8,841 Answers
Hi, the yellow wire requires power all the time, because it holds the radio station presets. There is usually a hot wire in the factory car wiring harness for this purpose. This wire would be hot with the key off, and you could find it using a simple 12 volt test light. Alternatley, if you tell me your model and year of coa I can probably look up the car's wire color for you.
Posted on Mar 22, 2011
Replacing power supply in a Cuisinart CWC 1600 cooler
Remove the back panel, take out the internal power supply and replace it with another compatible AC 120v to 12v DC 5amp power supply. Often laptop power adapters will work. I used this one: 60w-12v-5A-AC-DC-Power-Adapter from the website mini-box. The peltier pad draws upwards of 5amps, but the rest of the system is super lower power. his power supply replacement takes about 20 minutes. You need: Philips screw driver, wire cutter and stripper, two 16 gauge wire nuts. That's it.
Dec 01, 2017 | Furniture
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
Can you tell me what is wrong with my valentine one radar detector please
Old thread but This is probably a fried DC/DC converter inside the detector. Fuses are good for shorts but connecting to double the operating voltage will kill your electronics every time. Valentine 1 is the best. I beat laser with mine. Mike Valentine stands behind his product but you broke it so they probably will charge you for repair. If you have 24V system for stereo then any plugs or terminals need to be obviously marked. Try using a color that you can't mistake like yellow. .Or use a 12v power amp and your neighbors will be much happier.
Nov 11, 2011 | V1 Radar Detector
I installed an older used stereo. I found the red wire is power, the black is ground, What is the yellow wire with the 5amp in line fuse for
The Yellow is your Ignition wire, It controls the stereo power when the vehicle is on/off. It can be spliced with the red wire, however I wouldn't suggest it unless all other options have been used.
Feb 25, 2011 | JVC AM FM CD DET FACE CAR STEREO
I have a TVDVD092 and have misplaced the cigar lighter adapter. I know I need a 12v adapter. How many amps does this device require? Thanks
Hi
A 5amp fuse should be ok in the 12v adapter if you are bying a new lead make certain you by the correct one as some leads have the center pin + and some have center pin - look on the set by the power input plug to find out the one you require, regards windyhouse
May 17, 2010 | Orion TVDVD092 9 in. TV/DVD Combo
I'm installing a gps tracking unit on one of our landscape trucks. It's a 97 gmc/chevy 2500. I need to connect it to the ignition(12v dc) and constant power (12v dc)
your looking for an orange wire for your ignition and a yellow wire for constant power i believe. it's easiest to find them behind your deck/cd changer. just cut the wires and slice into them before the connection point of your deck wiring harness
May 13, 2010 | 1997 GMC Sierra K2500
TRC520 CB wont power up
Hello, First of all you only have the Power wire Red, and the ground wire Black to connect for 12v DC to power the unit. If you memory power it is usually connected to a constant power source such as the cigarette lighter or continuous 12V dc powersupply off of the battery. These are the only connections that should be connected to provide power. Since the unit will not turn on I suspect that the CB's power supply and regulator have been blown. Another possible choice is that the radio was working and someone removed the antenna cable and the the RF power amplifier malfunctioned taking the power supply and regulator with it. To solve this problem, check the voltages on the wires before connecting them to the radio (these should be the 12 volt power off of the radio circuit, and the 12 volt power off of the continuous 12V connector (or the cigarette lighter). These voltages should read 12V. Connect the CB with it turned off and measure the voltages (should be 12V) Turn the radio on and check the voltages (should be a little less than 12V) If the radio does not come on then the internal power supply of the radio might be defective (In this case I would advise taking the CB to a qualified radio repair shop) I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 11, 2009 | Radio Shack TRC-521 CB Radio
I need to know the voltage of Mutsumi D359M3D floppy and where?
The power cable connector to the drive has 1 red (5v DC), 1 yellow (12v DC) and 2 black (common center or negative) wires feeding the required voltages from the main power supply source. The power connector will only go on one way. I hope this helps.
Mar 01, 2009 | Mitsumi (D359M3 SILVER) Internal Floppy...
Continuous power supply
get a volt meter or a test light and check which wires from the car are constant 12v and which are switched with the ignition. I think that usually the red is constant 12v and yellow is switched. You might want to try switching the two and see if that helps.
Jan 10, 2008 | Sony XPLOD CDX-GT200 CD Player
Panasonic CQ-DPX151U CD Player Logo
53 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
