Question about Acer Aspire 3050-1733 Notebook
Can't connect to wireless networks. Comes up no neteork connections check your wireless is turned on. How do I turn it on?
    Sergeant:
  • 296 Answers
Fn + Wireless key usually the number key 5.
Alternatively, you may need to install the proper driver.
Posted on Mar 22, 2011
No networks available
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel.
2. Analogue video senders used to send audio and video to other TVs in the home.
3. Microwave ovens emit interference in the 2.4GHz band.
4. Wireless speakers and console controllers can cause interference with the wireless router.
5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem.
6. Power cables located near the wireless router can cause dropouts and speed reduction.
7. Fish tanks and mirrors will cause massive Wi-Fi shadow on the other side of the tank from the wireless router.
8. Depending upon the location of large mirrors will reflect wireless signal away your computer.
9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances.
10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
May 23, 2013 | Computers & Internet
My son gave me an older computer and wireless Linksys-G model WRT54GS router. I bought my wife a ipod for christmas and in the setup of the ipod it is asking for a password for the router. My son does not...
Reset the router to default....the default username and password is usually on the bottom of the router..then open a web page on your pc and connect the router with a network cable..type 192.168.0.1 or 192.168.1.1
Use the generic name and password to logon....once logged in, configure username and password and wifi...once setup..save and exit..disconnect and connect router to internet modem...log onto pc and look for your wifi neteork name..cheers
Jan 24, 2018 | Linksys Wireless-G WRT54GS Router...
My Belkin Wireless Router is experiencing problems when is comes to conecting to internet on my laptops . that ''wireless'' light is amber and blinking . any help?
Once its connected you will have the blue light in the belkin router
1.Turn on the wireless switch in your laptop
2.Click on start menu--->control panel--->Network and internet--->Network and sharing
3. In the right hand side click on "Change adapter settings or Manage network connections"
4.You will see the wireless network connection
5.Right click on wireless network connection and click on Connect/Disconnect
6.you will be able to see the network name,try to connect it.
7.it will be connecting and then connected
8.try to able to go online in the laptop
Regards,
Ayyasam
Dec 30, 2009 | Belkin (F5D7231-4) Wireless Router
Where is on switch for wifi button??
a lot of computers, like myne for instance, use a proram either natve to the computer like wndows, or something like intel PROSET wireless. i would recommend doing a computer search for these or other programs like these.
Nov 13, 2009 | Gateway 400SD4 Notebook
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
Wifi issues
i think there is some kind of block from the network administrator
usually you can access wifi easily with out any problems.
di u install any third party application in your phone recently??
Sep 17, 2008 | HTC Touch P3450 Smartphone
How to get hp wireless assistance
If you need to find the Wireless Utility to scan for available networks, it should be in Start > Programs under HP Wireless
If you need to turn your wireless adapter on:
First, check to see if there is a button on the keyboard that looks like an antenna. It usually hasF a blue light on if it is enabled. If not, press it. If you are using Windows XP Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections
Click window opens. Network Connections. The Network Connections window opens.
Right-click Wireless Network Connection.
Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
May 28, 2008 | HP Computers & Internet
Help
First, check to see if there is a button on the keyboard that looks like an antenna. It usually has a blue light on if it is enabled. If not, press it. If you are using Windows XP Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections window opens.
Click Network Connections. The Network Connections window opens.
May 28, 2008 | Computers & Internet
Laptop Idiot
May 27, 2008 | Computers & Internet
Wireless radio switch
Page 13 will show you the radio switch. It is the 4th button.
Wireless switch Turns the wireless feature on or off, but
does not create a wireless connection.
✎ A wireless network must be set up in
order to establish a wireless
connection.
http://h10032.www1.hp.com/ctg/Manual/c01035586.pdf
Dec 25, 2007 | HP Pavilion dv9000z Notebook
Acer Aspire 3050-1733 Notebook Logo
56 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
