Nokia 6288 Cellular Phone
Problem for Nokia 6288 Cellular Phone
Nokia 6288 unlock
By amewsing on Aug 03, 2008
Hey mate, I saw that you helped someone else with this problem; I have a nokia 6288 with three network (australia) that I need unlocking. I only have the five attempts as did this other user.
IMEI: 359 551 010 325 826
Any help is greatly appreciated!
Same Problem
May 10, 2009
-   hey i got a 6288 and it is locked in to 3 network and i cant find a restriction code to unlock it. can u be abke to help -   Guest
Feb 09, 2009
-   how to unlock 6288 phone -   heat1947
Jan 28, 2009
-   cant get the restriction off my phone 6288 nokia on 3 network-   Guest
Jan 16, 2009
-   my security code is forgotten how can i solve this problem? -   rhianna08
Oct 01, 2008
-   Hi I have the same ,
nokia 6288 ,got it of ebay and it will not work with optus
it was vodafone
needonebadly@hotmail.com
emei 353226011171620
thanks Bruce
-   needonebadly
Best Solution
posted on Oct 05, 2008
Helpful)
jotercoy
Rank: Apprentice
Rating: 91%, 6 votes
Hi, I have a Nokia 6288 locked to the 3 network. Is there a code to unlock this phone?
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 06, 2008
Helpful)
nokurajesh
Rank: Guru  Nokia Phones & Accessories  Expert
Rating: 85%, 91 votes
How can i unlock nokia n75 - FixYaBookmark & ShareFixYa
Email Favorites
Google Del.icio.us
Digg Reddit
StumbleUpon Twitter
Facebook MySpace
More ...
To:
Note:
Technical Support, Instructions & Repair ServiceHome | My Products | My Profile
| Sign Out
Back to: All Products > Nokia > N70 Cellular Phone > Troubleshooting
Tags: how to get code, unlock code, unlock, phone unlock, codes F 1
How can i unlock nokia n75 (by 2 users)posted by 916vito on Apr 18, 2008Report
abuse
i bought nokia n75 , usa cingular provider, can you help me to unlock this
phone, IMEI:354815010436155Have the same problem? Click Here
XThis Problem has been added to the Share Your Expertise Page under "My Work
Queue".
OK1 Other User Has The Same Problem
Comment by ritz061086, posted on Jun 28, 2008
i have n75 from usa and i get it lock in india so how i can unlockBest
Solutionposted on May 07, 2008
adiya
Rank: Apprentice
Rating: 92%, 4 votes
Some one can help me to unlock nokia n 75 IMEI #354815012823285
Was this solution helpful? Show your Appreciation by rating it:Inappropriate
Thanks for Trying Helpful FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on how can i unlock nokia n75:
I don't want to Accept this solution Solution #2posted on May 13, 2008
PauldLucky
Rank: Guru
Rating: 86%, 92 votes
A word of advice dont publish your imei somebody can mess it up like a pie for
all seasons.
Before trying anything else, contact your service provider and ask for an unlock
code.
Usually, if you've been a customer of theirs for some time, they will provide
you with an unlock code for free. This is, by far, the best way to get your
phone unlocked.
Download software to generate the unlocking code. Software is available on some
websites for free and some pay websites that also offer support if things go
wrong.
See external links below.
Find the Serial number of the cell phone, also known as your IMEI number.
Using the software you have downloaded, enter in your Manufacturer (which is in
this case Nokia), your model number, and your IMEI number.
Also enter your country and the Network. Calculate the code, this may be
different depending on which software you are using. If your phone is the Nokia
N70 phone, select the model N70, they are the same phone.
#pw+403927744443466+7#
Remove the SIM card from your Nokia phone.
This is typically done by removing the back cover of the phone and removing the
battery and sliding the card out. Put the battery back in and power the phone
on.
You will see a message "Insert SIM Card".
Enter all of the characters you see in your code, including the # symbols.
To get a 'p' press * 3 times, to get a '+' press the * key 2 times, to get a 'w'
press the * key 4 times.
Disregard any spaces in the code.
In order to unlock your phone you generally need to enter only one code.
Start with the first one. If your phone is not unlocked by typing the first code
(MCC+MNC), use code "7" (Multilock)
Once you have finished entering a code that works you should see a message that
says "SIM is not restricted" or "Restriction off" message depending on your
model.
If not, try entering another code. Message "Cannot undo restrictions" means the
phone is "hard-locked" and cannot be unlocked by code.
Tips
Unlocking only applies to GSM phones, phones using other cellular technologies,
cannot be unlocked without special software and hardware.
Switch off the phone. Hold the keys "3", "*" and "Call" and switch the phone on.
Keep the buttons held down till you see the word "Formatting..." on the screen.
Make sure that the battery is full charged before you attempt this. This should
reset the phone lock code.
Warnings
Attempting to unlock your phone is done at your own risk.
Although unlocking your phone is legal, some cell phone operators might choose
to void your warranty should you unlock your phone (then again, some cell phone
operators won't mind).
Most phones only allow you to try a certain number of unlock tries, Nokia phones
have a limit of 5 tries.
After that, the phone becomes "hard-locked", meaning it cannot be unlocked
without using special equipment.
Most of the newer phones will not work with the codes generated by the free
unlock programs.
You can get a free unlock code generatoe software free from here :
http://unlock.nokiafree.org/
You can also download from here :
http://unlock.nokiafree.org/NokiaFREE_v310_Nokia_unlock_codes_calculator.zip
You can check this :
http://www.wikihow.com/Unlock-Your-Nokia-Cell-Phone
Good Luck.
Live, Love, Laugh.
Inappropriate Thanks for Trying Helpful FixYa!
Thank You!
I don't want to Accept this solution Solution #3posted on Apr 20, 2008
ahlrub
Rank: Wiz
Rating: 82%, 92 votes
cant do this here man,, u gotta go to the pro's they'll do it like this put
cables in phone , run the soft and open locks..... a word of advice dont publish
your imei somebody can mess it up like a pie for all seasons...
Thank You!
I don't want to Accept this solution Solution #4posted on Jun 15, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Supply nokia samsung moto Motorola unlocking card,software it is Very
convenient. Wvelcome Contact with me MSN:Linwenyang03@hotmail.com
Thank You!
I don't want to Accept this solution Solution #5posted on Apr 20, 2008
Raysagem
Rank: Wiz
Rating: 82%, 829 votes
The codes do not always work, due to various reasons, for example your phone
might have had a software (firmware) update. Or Cingular Pacific Bell Wireless
might have foreseen this, and they will have an extra bug in the device to
prevent it being unlocked. Good luck!
Usage:
To get code You need:
- Network code (network which locked the phone)
- IMEI number (15 digits)
- Phone model, ex: “Nokia 6310”
To enter the code to the phone (switch on without SIM card).
Input the Code in the phone as follows:
#pw+??????????????+1#
#pw+??????????????+2#
#pw+??????????????+3#
#pw+??????????????+4#
#pw+??????????????+5#
#pw+??????????????+6#
#pw+??????????????+7#
Here: ?????????????? You should enter generated code.
First code in the end of the string must be added + 1#
Code number 7 in the end of the string must be added + 7#
If you have proper software and You know on which lock, phone
is closed just simply enter proper CODE.
If YOU DONT KNOW – which lock is closed do the following:
1. Enter the first code, if it’s the wrong code – WAIT 30 seconds!!! And then:
2. Enter the code number seven this will open all locks.
How to get ‘p’ ‘w’ ‘+’ signs?
Press * several times on keyboard of phone...
Now a message should appear something like “Sim restriction off”. That means
your phone is now unlocked.
!!Warning!!
If the codes don’t work after entering 5 codes You will lock the ‘CODE UNLOCK
FUNCTION’ and it will be possible to unlock the phone only by using a
cable/device.
Network 31017000=CINGULAR - Pacific Bell Wireless;U.S.A.
IMEI 354815010436155
Nokia N75
Your code's are:
#pw+788160416653167+1#
#pw+075153702333051+2#
#pw+122404557046502+3#
#pw+345366571345760+4#
#pw+346226471424725+5#
#pw+446877070440073+6#
#pw+927512552537416+7#
Was this helpful?
Yes
No
Solution #3
posted on May 30, 2009
Somewhat Helpful)
muthumadhu
Rank: Wiz
Rating: 83%, 38 votes
Hai,
I unlocked my nokia 3500 using the instructions in the site mobileunlocker.In that site contains Unlocking instructions for all nokia models.If u visit that site You will get the solution.
Was this helpful?
Yes
No
Solution #4
posted on Jan 28, 2009
Not Rated)
shaggy067802
Rank: Wiz
Rating: 83%, 110 votes
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
Was this helpful?
Yes
No
Solution #5
posted on Jan 21, 2009
Not Rated)
yjk83
Rank: Wiz
Rating: 84%, 34 votes
Hi there guys, I think some of you might be getting your personal security passwords mixed up with the network unlocking...the network unlocking will allow you to freely change carriers...all you need is the unlock code...you can get the unlock code from
http://www.cellphoneunlock.net or http://www.cellunlocker.net
hope that helps
Was this helpful?
Yes
No
Solution #6
posted on Oct 28, 2008
Not Rated)
Yllrig
Rank: Apprentice
Rating: 0%, 0 votes
I have a Nokia 6288, and I cant open it because of security code
Was this helpful?
Yes
No
Popular Solutions for Nokia 6288 Cellular Phone
Questions and Unsolved Problems for Nokia 6288 Cellular Phone
Do you recommend Nokia 6288 Cellular Phone?
Answer
Answer
i forgot my security code of nokia 3600 slide..
Answer
i have a problem to install a password on my phone 0835412761
Answer
hi i have a nokia 6288 locked to 3g australia my imei number is 353226018378855, thanks
Answer
The "Voice message" icon is constantly displayed on my screen, When I check my voicemail... (More)
Answer
am 6288 si vreau sa blochez aplelurile unui nr,*** pot face asta???pls help
11 Other Users Have The Same Problem - Continued
Comment by baz_sam64, posted on Sep 09, 2008
do u have the code for this phone nokia 6288 thanks
Comment by Sacred Heart, posted on Sep 03, 2008
Heyy I need to find out the restriction code for my nokia 6288.
IMEI is 353226/01/689655/1
In New Zealand part of vodafone company
Please help if you can!
Comment by iHAVEYRFONE, posted on Sep 01, 2008
cant get this working 6288 help
i also have a lg prada that i cant get working
Comment by leorodion, posted on Aug 30, 2008
showing that i did not insert sim when there is. well cant read any sim on the phone, think this should be engine fault
Comment by bunny_grwals, posted on Aug 19, 2008
hello might i have nokia 6288 i want to unlock it please tell me how can i unclok it
Comment by tevits, posted on Aug 09, 2008
Hey Mate! Got a Nokia 6228 phone - 3 network australia with restriction code. Need your assistance.
Describe your Cellular Phones problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular Phone Experts
Top Cell Phone Repairmen
(800) 378-9668
Fixphonenow.com is your source for all of your...
FixPhoneNow Cell Phone Repair
(845) 363-6459
Cell Phone Repair - At Out of Warranty, we are...
Out of Warranty Repairs
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
