Question about Acer Aspire TimelineX 5820T-5951 Notebook
My acer 5820t just died! just stoped! when first pluged into power and awitched on the light on the power pack and Laptop come on but as soon as you press the Start botton, lights go out, nothing happens!
usuallyno
  • 13 Answers
SOURCE: acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Posted on Aug 23, 2007
  • 110 Answers
SOURCE: My Acer Aspire 5920 is not booting up. When the
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Posted on Sep 08, 2009
Testimonial: "Thanks for the reply! This just confirmed what I had been suspecting looking at other sources on the web. "
parrotheadpc
  • 2600 Answers
SOURCE: acer aspire 5920 wont start. light in AC chrger
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
  1. Unplug the computer, then take the battery out, push the power button and hold it for about 30 seconds. Plug the system back in (leave battery out) and push the power button. If it starts, Great! If not unplug go to the next step.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like this its the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
  3. Pull the memory out and find the screws that hold the keyboard on. There are symbols in the plastic there should be 2 screws holding it in. Now in the battery compartment, there are several screw at the back edge of the computer take them out and also the ones in the battery in the center strip. Some are silver and some are black. Once you have the screws out of the battery area flip the computer over and open the lid. The strip just below the LCD with the power button and controls will now be able to be lifted up. You will probably have to lightly get an edge started before it will come up. There should be several little cables hooked to it. Flip the control panel over and look for some screws holding the keyboard in. I think there's 2. Lift up the keyboard. Making sure there's nothing touching anything important and then plug the computer in. Carefully hit the power button and see if the computer tries to start. If it does try it will probably beep at you. Unplug it and put a stick of ram in it. Plug it in and try to start it again. If not, unplug the computer and Go to the next step.
  4. Carefully put the keyboard and control strip in place. Flip the computer over and loosen all the screws that hold the computer together. Flip the computer over again and pull the keyboard and control strip up again. Flex the inner aluminum plate that was under the keyboard lightly. Plug in the computer and then hit the power button. If it tries to start, Great! put it together again in the reverse process.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
Posted on Oct 12, 2009
hakimmadina_
  • 155 Answers
SOURCE: My acer aspire won't power up
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Thanks
Posted on Nov 27, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: Battery Wont Charge
Hi there as per your information there is a chance of battery damaged. So i suggest you use your battery in others laotop for confirmation. If your found the same problem then buy a new battery . Thanks & waiting for your feedback.
Posted on Mar 17, 2010
I can't open my disc drive on my Acer Aspire 5820T without using a pin. How do I get the eject button to work?
I suggest that you can use the other method to eject: press start and go to my computer, select the disk drive and you should see an eject option in the menu bar.Remember that disk drives are subject to computer admin and do not respond quickly to a button press, especially if a disk process in taking place...
Mar 03, 2012 | Acer Aspire TimelineX 5820T-5951 Notebook
I can not power on my acer timeline x 5820t. No power at all. Had this issue before and after two days all of a sudden the laptop pwer switch worked again. Now no power again. Tried without battery and...
Then your motherboard is problem, so take the motherboard to refix.
Note: Pin board can be refix (work on), while pinless board cannot not be repair.
Best regards.
Jun 28, 2011 | Acer Aspire TimelineX 5820T-5951 Notebook
Where can I find a manual for the Acer Aspire TimelineW 5820T series laptop. I just received my new computer and I never had a laptop before and I need a manual to learn how to use it. Thank you
Here is a link: http://www.acer.ca/ac/en/CA/content/drivers
From here, choose 'Notebook', then 'Aspire', then on the next box that appears, scroll down to '5820T'. A new window will appear; click on the 'Document' tab, and the first listing is for the Generic User Guide (click on the orange arrow on the left of the listing).
Hope this helps.
May 27, 2011 | Acer Aspire TimelineX 5820T-5951 Notebook
I forgot the password for bios.Can you tell me please how can I restart my computer? Acer Aspire TimelineX 5820T
Most of the time the bios password can be reset by simply pulling the CMOS battery out of the motherboard. The CMOS battery is the little watch battery the resides on the motherboard.
Beings that its a laptop, it may be harder to get to it. Try looking in the manual on how to get to the battery, this should provide all the information you need. If you need more help please reply and i will do my best to help.
Mar 28, 2011 | Acer Aspire TimelineX 5820T-5951 Notebook
I just purchased an acer timeline laptop (5820t) the touch sensitive mouse has a scrolling feature on the side that was working properly but now does not work at all, is there a quick solution to this...
michaelcarna
It is possible that there was just a problem with the drivers. The link below is to the drivers for the Touchpad on your computer. I would download and reinstall them on your computer. If you still have trouble after doing this I would return the notebook.
TouchPad_Synaptics_14.0.6.0_Win7x64.zip
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Dec 17, 2010 | Acer Aspire TimelineX 5820T-5951 Notebook
Acer 3860 no power
Contact your manufacturer for further assistance.
Jul 29, 2010 | Acer Aspire 3680-2682 Notebook
Laptop battery went dean charged up pc stioll not turning on battery light just shuts off when press power button and stays off until power cord unpluged and then pluged back in
With power off and unplug from the power supply, remove battery pack from your laptop for a few minutes to force it to 'hard' reset.
Hope it works for you!
Try again and let me know.
Jan 01, 2010 | Acer Aspire 5500 5570-2609 Laptop
Power supply flashes green and no lights on laptop
Remove battery pack, press and hold power button for 5 seconds, then put battery pack back in and restart pc. This should take care of it. A bad memory stick can cause problems like this as well.
Nov 12, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Laptop does not turn on.
it is the problem of you power cable pluged into the laptop from adapter which does not supply the steady current to your laptop the it causes the disconnectivty
Jun 01, 2009 | Acer Aspire 5500 5570-2609 Laptop
Computer stoped working
If you're certain that the battery is fully charged, then there could be an issue with your hard drive, or possibly motherboard.
Has the laptop ever been wet, or outdoors overnight?
See if you can boot from your disk drive by inserting your operating system disk in the drive when you turn it on.
Also double check that the outlet you're using is actually supplying power, I have bad outlets in some parts of my house where my laptop won't charge up.
Hope that helps, keep me posted
Dec 11, 2008 | Acer Aspire 3680 Laptop
Acer Aspire TimelineX 5820T-5951 Notebook Logo
347 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
