Question about Sport & Outdoor - Others
My treadmill is showing error e1 and the motor won't run its a hyper extension 50001
  • 64 Answers
SOURCE: Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
Posted on Jun 08, 2009
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
  • 33 Answers
SOURCE: I have a BH treadmill that has an E1 Error messgae...
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
  • 33 Answers
SOURCE: E1 error code
Your problem might be that the sensor magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
  • 33 Answers
SOURCE: Describe your fitstride t 890
Good luck.
Merit 725 T plus reading E1
If you wish to get some details about treadmill error codes and repair; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 28, 2016 | Exercise & Fitness
MY AF 843M AEROFIT TREAD MILL IS SHOWING AN ERROR E1 AND SOMETIMES E6. KINDLY GIVE US THE SOLUTION
You have to check the Speed sensor and its position.Normally you will find the speed sensor near motor pulley. In almost all treadmills E1 Error is related to speed sensor.
If you wish to get some details; check the site linked here. Pull up older posts.
Jan 04, 2014 | Exercise & Fitness
Get an e02 error every time I press start on my hyper extension treadmill
Replace the old battery from display board
2) clean the contacts batteries+adjust the REED swithc see diagram
3) tight the ribbon cables and clean it
4) LUBE the deck belt and rollers bearing
5) Test the motor and see the control motor board see the b.diagram
Mar 05, 2013 | Exercise & Fitness
My treadmill showing E1 error code
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Tes the s. sensor for open or faulty. Clean it + tight the connector very well and try again. see the diagram for adjust.
God bless you
Feb 04, 2013 | Quantum Exercise & Fitness
Error code 3
1) lube the deck belt
2) lube the rollers bearing
3) measure the voltage input motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram.
God bless you
Jun 29, 2012 | Exercise & Fitness
I got dkcity treadmill model number- DK5320HRP ' When we press start button the motor does not turn and after few second an error E1 showing on the display. plaese if anyone can solve this proble
I got dkcity treadmill model number- DK5320HRP ' When we press start button the motor does not turn and after few second an error E7 showing on the display. plaese if anyone can solve this proble
Jan 02, 2012 | Exercise & Fitness
My tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 16, 2010 | Exercise & Fitness
E1 error code
Good luck.
Jun 20, 2009 | Exercise & Fitness
Lites on control board read ( L 5 ) when machine is turned on.
the e1 symbol is an engineering error code for an electronics malfunction (actually is senses the motor not turning and giving an error. The most likely cause is the motor control board
www.twincityrepair.com
Mar 02, 2009 | Landice L7 LTd Pro Sports Trainer...
Sport & Outdoor - Others Logo
90 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
