Question about Fisher and Paykel Washing Machines
My FP washing machine has starting leaving brown sludgy marks on my clothes. Do I need to descale the machine? Im in New Zealand and the water isnt particularly hard. Thanks for your time, Emma
    Habit-Forming:
  • 17 Answers
I'm guessing you use fabric softer....Get some finish dishwashing powder and put a wash on with high water level with no cloths in it. let it do it's normal wash but before it drains any water out, pause the wash let it soak over night. next day unpause it and let it finish. Repeat if needed and do the same thing again with out any dishwashing powder in it to make sure it rinses all the soap out.
The black sludge is cause by using fabric softener. The costic in the finish powder will eat in to the sludge and soften it. If its really baked on it my need to soak for longer, more powder or it may need to be stripper and cleaned.
Posted on Mar 22, 2011
  • Mark Davis Mar 22, 2011
    This is for a top loading washing machine.
How to stop brown **** marks from washing machine
too many cloth at once and need to clean the glass and seal alot
Aug 11, 2014 | Washing Machines
How to stop brown **** marks on my clothes
Go to the store and get Tide Washing machine Cleaner . and if this does not help . You may need to put a filter in the lines to the washer . You have to much iron in your water . I had to put a filter in for my wives Aunt new house . She had the same problem . Hope this Helps!!!! Grant
The problem is the wash comes out with brown flecks all over it. I have taken out the agitator and cleaned it, this hasn't changed the result, still brown flecks all over wash
WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature
according to soil type. For example, blood and mud are better washed in cold water, while sweat
and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will
wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent
than soft water.
9.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the
instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus
detergent and left to soak.
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
Jun 14, 2012 | Fisher and Paykel IWL12 Top Load Washer
Brown sludgy marks and particles on clothes.
fill the tub with only water! use pinesol and bleach! half a gallon of each run through wash cycle 3 times before ever letting it spin out! then complete all cycles that should do it! if not them you need to remove and clean under tub and re install
Jan 13, 2010 | Hotpoint Washing Machines
Starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
WHERE IS THE FILTER
this sounds more like grease marks rather than sludgy marks,i bet you the bearrings have worn out,check this out by opening the door and the silver drum inside will have a knocking noise as you lift it up and down,when bearrings have worn out this causes a sludgy diposite,rgds,paul
Jul 07, 2009 | Hotpoint WMA64 Front Load Washer
My Whirlpool Calypso top loading washer (purchased in June of 2002) is starting to leave brown or dirt colored marks on clothing and sheets (I think they are permanent!) - I don't see any obvious place...
Run the washer empty with vinegar on the hottest, longest cycle. Usually this is caused from fabric softener and liquid detergent build up. Use powder detergent only and don't use cold water to wash in all the time. Only use cold water for your bright, finer cloths. Cold water use causes detergent build up.
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Brown, rust-like marks on washing
Hello I got a Bosch ClassXX5 and got the same problem, white clothes seemed Grey and some clothes seemed washed but not perfectly, until I discovered that the washing machine did not heat water anymore; after the end of the wash cycle the clothes were cold as the program was initially setup to 40C°.....
I used to think soaps were not up to the task and changed brand often, sadly a Bosch product letting me down was not on my mind, since that brand for me was above the rest, quality, strong, during in the time, having electric tools from Bosch without any problem for years!
Oct 11, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Cleaning
deacaled it use a special descaler produit not vinegar 1 part descaler 1 part water fill up water tank start let it drip for few second turn off leave it for 15 minute repeat untill empty after rinse very good very corosif stuff that descaler the machine is gonna work fine the brown stuff should come of but coffe is like dye calcium in machine is a killer brown stuff is not nice but the coffee is great cheers
Feb 03, 2008 | Coffee Makers & Espresso Machines
Washing Machines Logo
488 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
