Question about Mitsubishi VS-55601 55" Rear Projection Television
Convergence red and green are seperated.
  • KingGeorgeII Aug 06, 2008
    My TV convegence went off during a storm. I tried to fix it using the remote but it doesn't respond. Everything else works fine. I can still look at the TV but everything is double. Help!
    Champion:
  • 317 Answers
Need conv rebuild by repairman.
Posted on Aug 03, 2008
Sitting here watch tv and suddenly the picture went warped and discolored. Picture looks like the colors are seperated. blue green and red.
Your TV has convergence chips that need to be replaced by a tech. These keep tour red green and blue lights in sync with one another in order to give you a sharp color picture. When they fail your colors seperate.
Nov 07, 2010 | RCA D52W23 52" HDTV CRT TV
Blue and red colors are seperated on tv screen
problem with unit is convergence-find that in the menu-try to adjust red untop green then blue ontop green.if they will not adjust gonna need parts-try to adjust it .if you need more help please list the model number
Sep 07, 2009 | Televison & Video
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Color seperation and red drooping line
You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
Jul 14, 2009 | Zenith R45W46 45" Rear Projection...
Green color seperation multiple images convergence will not fix
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 14, 2009 | JVC AV-48WP74 48" Rear Projection...
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Red and Green
check video IC or tv convergence sometimes yoke
Aug 12, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red Convergence will not line up
YES in this set there are two convergence ics called stks...on for red and one for blue...and green is controled by both.
Apr 28, 2008 | Samsung HCN653W 65" Rear Projection...
AUSTRALIAN PARTS
the convergence board has nothing to do with tuning of tv, the convergence board put three colour gun (red, green, blue) to work with each other, else you get three image, of red , green,  blue or mixture of all as seperate image, the convergence board for american tv and Australian tv is possibly the same what you check to see the board  part number is the same you possibly need to see if the convergence board has got the memory i.c. if that is the case, you need to tune you t.v reset the channel etc good luck.
need more help let me know.
Oct 09, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Arched picture at bottom seperating the green and red
Your tv has a convergance failure. the convergance ic's need to be replaced. Upgraded part # STK392-150 or STK392-160. Both ic's should be replaced to prevent future failure of other colors.
May 20, 2007 | Toshiba 43H70 43" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
