Question about Canon ImageCLASS MF4350d Laser All-in-One Printer
Hello, Need some help withy my fax mf4340d ,always when i recive fax there coming a text on screen "use current size" and press yes or no. After i press yes he print same document again and then other pages. Every time when fax is coming he asking me that and i need to press button. I cant find a solution and i need some help if is posibble Tnx alot, Damir
  • skladiste_za Mar 23, 2011
    This is not helping me,if u can type here what to do
    Thanks
SOURCE: Repeated Fax TX report printing
Canon tech support walked me through this. Turn unit off. Unplug for 30 sec. Plug in, turn on. Memory should be cleared.
Posted on Mar 03, 2008
old marine
  • 2144 Answers
SOURCE: Scanning Legal Sized Documents
1. From the MP Navigator screen, select "Scan with Scanner Driver" in lower left corner.
2. When in ScanGear MP, select the Advanced Mode tab
3. At Input Settings, select Document (ADF) for document type
4. Set paper size in next window
5. Click Scan button at bottom
Posted on May 08, 2008
canontech
  • 1219 Answers
SOURCE: Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Posted on Jul 22, 2010
SOURCE: printer keeps saying 'use current size?' after
printer keeps saying 'use current size?' after each page is printed, if i hit 'yes' then it prints the previous page again. how do i solve this
Posted on Aug 17, 2010
sabuv
  • 113 Answers
SOURCE: I defined the paper size
go to printers and faxes right click an d select printing preferences on 4350d and select paper as A4 . Press apply & ok. Now try printing on A4
Posted on Apr 11, 2011
Testimonial: "Thank you very much, it helped"
Text size on home page, yahoo mail and print is so small i can't read how do i enlarge. I have gone to veiw ,text size selected largest with no result
Hello nancyedawley,
The text size can be enlarged by holding down the [Ctrl] key and pressing the [+] key. The text can be made smaller by pressing the [Ctrl] and [-] key combination.
If this solution is helpful please click a thumbs-up rating.
Have a great day,
martyshaw152
Apr 26, 2011 | Computers & Internet
Tip
A Simple Way to Increase, or Decrease, Text Size
An easy way to increase or decrease text size on most any type of Windows software is to rest your cursor over the software you are using, press and hold the Ctrl key, and then scroll the wheel on your mouse forward and backward. Pushing it forward increases text size, and going backward decreases the text size. You can also press and hold the Ctrl key and then hit either the "+" or "-" key for the same results!
on May 24, 2014 | Computers & Internet
There is a "sun" sign
the sun sign is unrelated to the problem. the sun signifies daytime setting pertaining ringing sound asf..
press DIAL immediately and listen whether it is engaged. If yes, fix your phone line.
if no, dial manually. if still unsuccessful come back here.
Apr 01, 2011 | Philips Magic5 Voice DECT Duo - Fax /...
Hi Everybody, My 6322DN says "printing...", you
First ckeck the line of the telephone,put another printer and see if you recive the fax on other printer.If you not recive fax possible fax board may be faulty.
Mar 16, 2011 | Samsung SCX-6322DN All-In-One Laser...
How to change drum to a Brother Super G3 Fax Machine instruction state to change drum, and with door open, hit the clear button until "Replace Drum?" appears, then hit 1,,,,,,well there is no...
With door open, press "Options." Screen reads, "Change Drum?" Press 1 for yes. Screen reads "Accepted." Place drum/toner in, close door. Done!
Feb 03, 2011 | Brother IntelliFax-2920 Fax
Copys and faces reciving from the same side, where use to copys come out (left), faxes we were reciving on the right, but now they all coming on th left side and all mixed up
Hi, let me help. Hope you are well. Locate the "additional functions " button locaed near the 9 key pad to the right of the display. Press it and select "commom settings"which should be the top upper left button .Select it and scroll till you get to "tray designation". Here you can choose what items (fax, print, copy, other) will be output. Just make sure you dont have ,for example, fax coming out in more than one spot.This is unfortunately easy to do. Just select which ouput item you wish to exit where. Press "ok". You will need to power off the machine after this using the switch located on the right of the machine, very back, about halfway down. Wait a sec and power up. All should be good. I wish you well.
Jan 11, 2011 | Canon imageRUNNER 4570 Copier
I CAN FAX BUT I CANT RECIVE FAXES ON MY DELL PHOTO 964 ALL IN ONE PRINTER
Make sure Auto Answer is turned on or is currently within the scheduled on period...... On the main screen in Fax mode, use the up and down Arrow buttons to Auto Answer...... Using the left and right Arrow buttons... Select...... to scroll... choose Yes or Scheduled and press... If you selected Scheduled, the Auto Answer Schedule screen appears...Using the keypad, specify the time you want Auto Answer to be turned on and be turned off
Sep 25, 2009 | Dell Photo 964 All-In-One InkJet Printer
Sending text messages takes too long
out of curiosity,
what kind of sidekick was it?
and also, have you tried to give it a soft reset, yet? if not, then press it all keys down ( @ + 1 +0 ) without the + part.
and let me know its fixed.
if not, then you will have to force to do a master reset. (and yes, you will lose everything for a while. but, no worries, everything will come back in a fews as everything is in dangers backend sever as always, except, text parts)
here how: -press all the keys down at once ( @ 1 0) without quotes -when you see all 4 keys button come up on the screen, hold down the "R" and dont let it go until  you see the screen come on, let the "R" go and it will reboot once again. -and wait until everything come back and then try again to send yourself a text and see if its been sent sucessful.
good luck and let me know if works.
Mar 07, 2009 | T-Mobile Sidekick II
Must have pressed the zoom by mistake and my mail screen is far too large. How do I get the screen back to "normal" using the mouse. Thanks
HI HAVE YOU CHANGE JUST THE PAGE SIZE ALL THE SCREEN SIZE
PAGE SIZE IS EXPLORER VIEW THEN TEXT SIZE.
SCREEN IS RIGHT CLICK DESK TOP THEN PROP THEN SETTING THEN CHAGE SCREEN RESS
Dec 03, 2008 | Computers & Internet
I am using a fax machine Canon L80 and waiting to receive a fax ... it's blinking between and says "received in memory" and "check paper size" ... not sure what to do.
"Check paper size" means that the paper in the machine doesn't match the size selected in the setup.
To change the paper size:
1. Press the Function button.
2. Press the Data Registration button.
3. Press Set button.
4. Use up or down arrows until you see PRINTER SETTINGS.
5. Press Set button.
6. Use up or down arrows until you see PAPER SIZE.
7. Press Set button.
8. Use up or down arrows until you see type of paper in the paper tray (LTR, LGL, A4).
9. Press Set button.
10. Press Stop/Reset button.
Machine should now print out the fax that was received in memory.
Jun 20, 2008 | Canon Office Equipment & Supplies
Canon ImageCLASS MF4350d Laser All-in-One  Printer Logo
101 people viewed this question
old marine
old marine
