Tv wouldn't turn on this morning after the night. Amber light blinks three times, pauses, and repeats. I've checked the capacitors for bulging or any sign of loose wires and/or signs of a shortage. My tv is a 37LX96. I've heard it's a common problem for these to have the main video board go out but i'm not sure what would be my best course of action or if that's even an accurate guess. Thanks for the help
  • johnsonsr324 Mar 22, 2011
    I'm not too television savvy so could you help me locate where the connector is that I have to measure? Also, if it is indeed your solution, where would I go about getting the parts needed for repair and how would I install them? And if it is the video board, where do I get one of those? Sorry for the plethora of questions I'm just not too familiar with board level components of televisions.
    thanks again
  • johnsonsr324 Mar 23, 2011
    I don't have the money to have somebody else diagnose the problem for me and pay for a new power board, so I have one last question, how do i go about measuring the voltage now that i've located the P809B connector, i have a decent idea how to do it, but like you said if i mess it up i could screw the whole tv up.
    President:
  • 1,654 Answers
My answer for your best course of action so as to not throw good money after bad is to at least get a tech to look at it, give you a diagnoses and then we can procede from there. They will give you an estimate on part prices as well as what it will cost to fix. You can then decide if you want to spend that money on a repair or a new set. If you wish to repair the set yourself with parts you buy yourself with my help I can do that. But I don't want you or me guessing with your money. There are a multitude of issues that can cause things like this from bad power cords to switches to boards, the flashing light tells me that it is at least seeing a problem but unable to get enough voltage to power up. Is this a Toshiba? I am guessing by the numbers. This manufacture has had problems with the T con board, it sets directly over the power supply and heat kills it. Great design.
But I can't tell you from here which board it may be with out getting my hands on it. Anyone else who says they can are feeding you some junk and they just get lucky now and then but you have to pay for their mistakes. I don't want to do that, so If your wanting someone to nail it on the first shot and get your set going without ever seeing it. Then I can't help. But if you can narrow it down for me I can help a great deal. Thanks
Posted on Mar 23, 2011
  • 11,800 Answers
Yes, the video board on these isn't very reliable, but most likely this isn't your case: 3 blinks indicate a failure in the power source - either one of the rectifiers or one of the filtering capacitors have shorted.
To confirm that measure the voltages on the P809B connector - if the 5v-1 and Power ones are below 5 you will know for sure.
Posted on Mar 22, 2011
  • Azrael SRL Mar 22, 2011
    The connector is situated on the power board, clearly labeled: each pin has its correct value printed next to it. In the picture from the link below it's situated on the right, just aboce the yellow transformer.
    The board is easy to replace: you just disconnect the cable connectors and unscrew its fixings. You can get a replacement from here
    http://www.partstore.com/Part/Toshiba/To...
    But, since diagnosing a switching power supply is a complicated job and you lack even the basic experience, i strongly recommend that you call a pro - if you touch something you shouldn't by accident you can fry the entire tv. If you still want to do it yourself then be extremely careful.
  • Azrael SRL Mar 23, 2011
    Use a good voltmetre - with fine control probes, detach the board from the tv but leave it connected, flip it and support it with some insulating posts as to have an easy access to the points, attach the ground probe securely and touch the point that you want to test only after you have identified with precision - do not touch anything else. A basic tutorial on how to diagnose it can be found here
    http://www.repairfaq.org/REPAIR/F_smpsfa...
Toshiba TV you when I turn it on it runs for 10 minutes then it shuts itself off light blinks three times pause three more blanks then it turns itself back on runs for minute then repeat
Use a canister cold spray and take a wooden pencil and manipulated some parts on the print , resoldering parts and coils and lalso ook for top/bulged capacitors to replace .
Feb 20, 2016 | Toshiba Televison & Video
REGZA 47HL167 TV is difficult to turn on. when powered on the amber lite flashes 3 times then pauses for 1 second then repeats the 3 amber flashes. If I keep pushing the power button on the side,...
3 flashes of the led light at the front panel is means that the unit is in booting process. The symptoms you've mentioned is caused by faulty electrolytic capacitor in the power supply section.
Look for faulty capacitor with bulged, dome at the top and then replaced it with same ratings. If you have a capacitor checker, it will make you more easy to identify the faulty capacitor without a physical indication of fault.
http://www.youtube.com/watch?v=oDGjWOabJ2E&feature=related
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1&feature=fvwp
Oct 07, 2011 | Toshiba REGZA 47HL167 TV
Green light on red light flashing not going on
Red blinking light is an error code and how many time red light blink shows problem section of tv, please count red blinks after three seconds long pause and let me know to provide you helpful info to solve tv problem.
Thanks.
Mar 09, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Before i changed the bulb it powered up and cut of after about 5mins.Now bulb is new but wont light up and red light blinks three time and then pause and repeats
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem.
Hope this helps and Good luck.
Kaufman605
Dec 12, 2010 | Sony KDFE50A10 50" HDTV
Tv light flashed and cut off . turned back on and green light turned red and blinked 6 times pause then 6 blinks etc... tv will not power on. checked lamp seems to be ok. checked power supply board and...
Your power supply board is not yet dead, u know basic electronics' and soldering? You have to open the back cover of the television check for dry soldering on the printed circuit board , if found resolder but if not Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem...
Nov 29, 2010 | Televison & Video
Timer/stand by light in the front panel is blinking. The picture is all red and only stays on for about 20 seconds and then shuts the tv off. The light is blinking 5 times. Is there a home fix for this or...
dodgebrat250,
By blinking 5 times I will assume that you mean the standby light blinks 5 times approximately 1 second apart, then pauses for 3 seconds and repeats. If this is true then you have a fairly complicated problem which could be anyone of three different areas. If you are not trained in electronics you will probably need a technician to solve the problem.
The problem is on the A or C board or it may need the screen drive turned up. One the C board check Q705, 732, 761 and all associated components. Look for bulging capacitors and replace as necessary. On the A board check Q218, 219, 220 and any associated components. Also look for bad electrolytic capacitors as above.
This is only a small part of what the problem could be and without actually looking at the set and doing testing it is difficult to recommend any further action.
I have a tip at http://www.fixya.com/support/r4425498-basic_standard_tv_troubleshooting which might help track the problem down.
Thanks for using FixYa and for the generous rating.
hardrocko
Sep 12, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Rca hd52w59 tv. power light blinks three times in
Thats usually caused by the CP150, CP114 and CP120 capacitors which will need replacement. You can get that repair kit at www.tvrepairworld.com and the kit contains the CD with instructions for the repair.
Dec 14, 2009 | Televison & Video
Scandisk Cruzer micro 1.0 problem - three blinks, three blinks, etc
It means a problem in vista
I'll post if I find the solution , working on it right now
the good news is , it's not broken , it's just vista being a pain.
Aug 28, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Video
How many times does the light flash?
Sep 28, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
