Question about Sanyo Televison & Video
31 inch sanyo lcd tv.. switches off after 2 seconds
  • 8457 Answers
SOURCE: We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Posted on Jan 15, 2010
Testimonial: "Have tried turning on/off a few times but still doesn't work. thanks anyway"
  • 8457 Answers
SOURCE: Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 02, 2010
alpug
  • 1961 Answers
SOURCE: Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Posted on Jun 04, 2010
  • 22 Answers
SOURCE: my Samsung LCD TV (40A450) 40 inch, when switch
The capitors on the back might be bad this I have fixed on these tv's many times. That could be one of the problems and the capitors are on the power board inside the tv. If you do not know how to work on electronics I would have a pro do it they contain hight voltage so be careful if you try to fix it yourself.thanks
Posted on Oct 06, 2010
  • 608 Answers
SOURCE: when i turn on the tv , it shuts itself off in 2
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
Where is the reset button
Sanyo Service Menu - Factory-Reset.com
factory-reset.com/wiki/Sanyo_Service_Menu
Jump to Sanyo TV Service Menu Method 2 - Unplug the power cable. Press and hold the {VOL -} button on the TV while plugging the power cable back ...
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... I have a Sanyo TV, I accidentally hit the reset button twice. I ...
Aug 6, 2012
36 inch sanyo tv won't change off video 2?
Apr 17, 2010
I accidentally hit the 'reset' button the remote of my sanyo tv ...
Jan 6, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
Nov 29, 2015 | Sanyo DS31520 31" TV
My 31 inch LCD switches on for 3 seconds and then shuts down
the best thing to do is u need someone can fix that problem."go to your nearest sanyo service center....'
Mar 22, 2011 | Sanyo DS31520 31" TV
I have a Sanyo 42 inch T.V. and it suddenly shut off. I tried turning it back on by using the remote. the green light comes on for a few seconds and shuts off again.the screen never powers up.
call to the tv service center and do the required things my dear..........
plz dont try to repair it without any experts becoz tv when switched off also contains many voltage in it...
Jan 22, 2011 | Sanyo 42 in. LCD TV
We are getting a picture but no sound.
First go to menu make sure audio is not turned off CK speaker . then audio output IC.
Feb 15, 2009 | Sanyo DS31520 31" TV
31'sanyo tv analog has a white horizonal line thru it
There is a failure in the vertical amp section. This can be the main output IC, or any of the support components in this area.
An experienced tech can troubleshoot the set, and determine and service the fault.
Jerry G.
Apr 27, 2008 | Sanyo DS31590 31" TV
Sanyo t.v. 31 inch
This is most likely a scan amp, and or power supply failure. You will have to bring the set in for service.
Jerry G.
Apr 03, 2008 | Sanyo DS31590 31" TV
My Sanyo TV
Yes, go to remotes.com for a replacement. Around $40.00
Dec 26, 2007 | Sanyo DS31520 31" TV
Sanyo 31 inch dbx mts color monitor (1992-93?)
Your TV is in the demo mode. Try this: Press the MENU button and hold it down for about 10 seconds.
Aug 14, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
