Question about Dynex 4-Port 10 Mbps Ethernet Hub
This tells me that local area connection does not have valid ip config the default gateway is not available
    Sergeant:
  • 187 Answers
Check your internet options and apply these settings.
Or...
Open your network connection. Right Click>Properties Then click Repair.
Or...
Open Run. Then type CMD in it and press enter. Command Prompt window shall open.
1. Type in "ipconfig /all" .............then press enter
2. Type in "ipconfig /release"......then press enter
3. Type in "ipconfig /renew"........then press enter
4. Type in "exit"...then press enter
Posted on Mar 22, 2011
Connecting canon mx472 to new router. How do I do this?
You have to make sure that the I.P. address, Subnet and Default Gateway are set to match the new routers parameters. (i.e.) I.P.: 192.168.1.44 Subnet: 255.255.255.0
Default Gateway: 192.168.1.254 on the old router.
I.P.: 40.11.120.99 Subnet: 255.255.252.0 Default Gateway: 40.11.1.254
As long as the Subnet & Default Gateways and the I.P config is within the scope of the new router, you should be good. Just remember: All PCs/Laptops will have to reconfigured for the printer's new config also.
Sep 17, 2017 | Canon Office Equipment & Supplies
Tip
How to change a ip through command prompt
Netsh” is a nifty utility to change system networking settings, locally or remotely.
To run Netsh click on start then RUN and type CMD press ENTER.
When the command prompt comes up type Netsh, now you should be ready to execute commands. Simple huh. Just to warm up type “interface ip show config“ that will show up the TCP/IP network settings.
Now, how you change the IP address and Default Gateway settings? To change the Local Area Connection TCP/IP settings type the following command:
interface ip set address name=”Local Area Connection” static 192.168.10.42 255.255.255.0 192.168.1.1
on Dec 20, 2009 | Computers & Internet
Cannot access to router
First, your computer does not have a valid IP address from the iptime router. You need to make sure you are connected to the router, use a cable instead of wireless. Then try ipconfig command again...until you have the valid ip address in the same range as your router (192.168.0.x).
After that, you can try to config your router again.
Because of all these resets you've done , your router state/condition is uncertain.
Feb 16, 2013 | Computers & Internet
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
Laptop will not connect to wireless internet says it doesn't have a valid IP configuration. Have unplugged loads of times can get other wireless connections in the area but not mine.
In your laptop, try to put an IP Address, subnet mask, default gateway and preferred DNS server. (please see below)
example:
IP address: 192.168.1.13
Subnet mask: 255.255.255.0
Default Gateway: 192.168.1.1
DNS Server: 192.168.1.1
note: 192.168.1.1, is where your modem or your internet is connected (or the IP Address). This is the one that is provided/configured by your Internet Service Provider.
Jun 07, 2010 | Buffalo Technology Buffalo LinkStation...
How to configure my tcp/ip TP-link access point
The router has both a "WAN" (Wide Area Network) side
and a "LAN" (Local Area Network) side.
On the WAN side, most ISPs (Internet Service Providers) will provide the values for IP-address, subnet-mask, and gateway.
On the LAN side, you should just use the "default" values.
Connect your computer via an Ethernet-cable to the router,
and the router will supply values to your computer,
so that your computer can communicate with the router.
Nov 06, 2009 | Computers & Internet
Belkin54g default gateway problems and connecting to router page
reset your Router via pin whole at its back then set the config of TCP/4 and obtain Ip automaticaly and obtain DNS automaticaly... later set your settings according by 192.168.1.2 without changing IP and then turn off you router ... turn it on after 5 to 10 min .. thank you
Jun 24, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Hi, i need the gateway number for the d-link DES1008D can sombody tell me please how to find out the gateway number.
The D-Link DES1008D is an unmanaged switch. Hence it does not have any gateway address and none can be set on it.
If you are looking for the gateway address of your computer, here's how to find it.
In Windows 2000 / XP / Vista / 7, Open command prompt and type in ipconfig
Look for the IP address of the default gateway.
eg:
C:\>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
Hope this helps.
Regards.
Jan 09, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
No default gateway
You most likley have your Local Area Connection TCP/IP settings incorrect.
In windows XP go to > Control Panel > Network Connections > RIGHT CLICK on Local Area Connection > Properties > Click on Internet Protocol (TCP/IP) > Then properties > Make sure that "Obtain an IP address Automaticly" and "Obtain DNS server automatticly" are checked. Once you make the change, Reboot and you should be good to go.
Jan 08, 2008 | Computers & Internet
Dynex 4-Port 10 Mbps Ethernet Hub Logo
117 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
