Question about LG WM1812C Front Load Washer
My washing machine door is stuck. The lever to open is probably broken. Is there any way to open it or calling the service mechanic the only option
There is actually a child lock that may have been enabled on your washer have you checked to see if its on? If this is on it will keep the door locked.
Posted on Mar 22, 2011
  • Kosuru Venkateswara Rao
    I might have got the model number wrong. There is no child lock on the machine. I am sure that the lever release ( the plastic flap ), the one to be pulled to release the lever, is broken.
The lever on my machine for dwing backwards seems to be stuck or broken
then it would be a good idea to have the machine serviced
to find out if the lever is broken or stuck.
Feb 22, 2013 | Janome 1600P-DB Mechanical Sewing Machine
We have a whirlpool duet front load washing machine door is stuck closed. i have unplugged machine still wont open?? any solutions i can try myself before i call a repair person??
You can manually unlock it. Unplug washer. On the lower panel there are 3 screws, either 1/4 inch or they are the hex bit. Remove these screws and the panel will come off. Reach up on the inside on the right side. You will be able to feel the door lock mechanism, near the bottom of the mechanism is a pull release lever, pull down on it and the door will unlock. The door lock may need to be replaced. I hope this helps
Feb 28, 2011 | Washing Machines
The drum in the washing machine has opened during a wash cycle and is now blocked. how do i release it?
Hi.
I guess that when you say that the drum in the washing machine has opened you mean that the washing machine door has opened, and that the door lock is now stuck.
Try tripping the circuit breaker or disconnecting the power cord for a couple of minutes, to see if this can reset the appliance and unlock the door. While the machine is disconnected , remove load and empty water using a sponge.
If disconnecting power does not fix the issue, and the door is still stuck , then you may need to replace the door latch mechanism and the solenoid that may had been damaged when opening.
In that case call the manufacturer at the number listed on the owner manual.
Nov 16, 2009 | Washing Machines
Lg washing machine wm-1460fhd door locked wont open
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Jun 10, 2009 | LG WM-1480FHD Front Load Washer
Asko washing machine w6342 showing f3 and cant open door or operate?
Make sure the programme selector switch is at an end of wash position as these door locks are interlocked to prevent accidental opening during operation. There is also a 2-3 minute time delay after the was finishes so disconnect for say 5 minutes and try again.
If it still doesn't open you will need to get access to the mechanism dependent on what type of relrase mechanism you have;
if it is a push button release with a cable to the lock sometimes you can remove the top panel of the machine and pull on the cable or linkage to open.
If it is a lever type release mechanism this is more difficult to open but you can sometimes reach and release it by the same method.
Always disconnect the machine from the electricity supply before working on it.
Oct 13, 2008 | Washing Machines
Washing machine door
if the machine is full of water pump blocked or broken if machine empty needs new door interlock or pressure switch blocked or broken
Aug 23, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Wahing machine Tricity Bedix AW1260W-Door problem
probably handle mechanism broken. to open is a bit difficult.
disconnect from mains and take top off.
feel down the cabinet front on the side where the door handle and opposite the door handle you will find the door interlock. in the door interlock, you will find the end of the door peg. force this towards the middle of the machine and with luck the door will open.
anothetr method is to break the handle off and use a small screwdriver on the door peg
Jul 21, 2008 | Tricity Bendix AW1200 Front Load Washer
Whirlpool AWZ 412 - Door not opening..
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Apr 13, 2008 | Hotpoint WD52 Front Load Washer / Dryer
Help needed indesit washing machine
well it would help to know brand/model#
Oct 03, 2007 | Washing Machines
LG WM1812C Front Load Washer Logo
126 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
